Question about E-Machines eMachines Desktop PC
The emachine w5233 shouts down after about 2 hours some times less it just turns off i have ran virus checker cleaned pcu out changer power cord pluged into different outlet i had a breif power outage backup power came on computer after this is when the problem has started i am running windows vista premiun computer is about three years old
  • 3,153 Answers
Taking into consideration it works for some time before it fails I suspect a thermal issue. I would pay particular attention to the CPU cooler. If you don't feel confident doing this yourself its a cheap repair at a good computer shop.
Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
I would suggest getting a can of compressed air made for computers
take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
While you are in there just check that the CPU cooler itself is not loose
If it is it will have to be re-seated.
If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem they have to be cleaned and new thermal grease put on ($2-5)
DON'T remove the CPU just the fan/cooler assembly.
You must clean both the surfaces without scraping anything off. Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
DON'T pour the alcohol over the CPU
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are
some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business
Posted on Nov 19, 2009
  • 541 Answers
I would suspect a power supply problem. Take the cover off and look through the power supply for capacitors that are bulged out on top. When they do this they start dropping their value and cause voltages to fluctuate. The values of the capacitors are marked on the side. Be patient and use a good soldering iron. Thanks for using fixya.
    Problem Solver:
  • 12 Answers
Sounds to me like you might have a problem with your hard drive. Try to run diagnostic stress test on your disk and see if it. Try something like this
http://www.pcstats.com/articleview.cfm?articleid=1583&page=7
Emachine w5233
keep the power button pressed until it shuts down
Jun 22, 2014 | Computers & Internet
My Acer Aspire 5517 keeps shutting off...
1. Check if the air duct inlet and outlet are free and free of dust.
2. If needed, clean it with a hard brush and vacuum cleaner.
3. Check if the fan is rotating, if not replace the fan unit.
4. Check if the fan is clean of dust, if so clean it.
Nov 16, 2011 | Computers & Internet
Emachines w2828 keeps shutting down reboot/Screen Freeze
I dont thing this is a virus problem but a heat problem. if you dont mind getting inside the box see how clean it is and put your hand on the power box case .. then unplug all the hardware except the mother board then turn the unit on, if it goes on then plug 1 hardware at a time.
Sep 04, 2009 | E-Machines eMachines Desktop PC
I had the same exact problem.
First power up the computer then press F8 key then if you see safe mode and other menu then enter in enable vga mode then go to control panel and change screen resolution to 1024*768.
If you can;t see safe mode and other menu.
Then open the cpu cabinet then refix RAM memory .
clean dust from circuit and RAM.
Pull cmos cell from motherbord for 15 minutes so all bios settings are defaults.
Then check.
Aug 01, 2009 | Acer AL1916W 19" LCD Monitor
Fan not going on and interface really slow
turn it off for an hour see if that works could be overheating
Dec 21, 2008 | Dell Latitude C400 Notebook
Scrambled Signal on LE 1938
Borrow another monitor from a friend and try that one. If it does the same thing with the second monitor then it is more likely the sound card.
Dec 18, 2008 | E-Machines eMachines Desktop PC
Vista
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W-Series&model=W5233
you can also try to go up 1 model to get xp drivers or go to manufactor to download drivers
May 12, 2008 | Computers & Internet
Phillips 64" PTV Issues
sounds like vertical problems see if you have bad solder connections then get back to me
Nov 02, 2007 | Philips 50P8341 50" Rear Projection...
E-Machines eMachines Desktop PC Logo
314 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
