Question about Cell Phones
Walkman 350a won't turn on - Cell Phones
How to open the file on the walkman
I have a similar model. The file itself needs to be the correct format, otherwise it won't open (this is a limitation on the software/encoding etc). However, once the file is on there, plug in a mini usb, access the walkman through your computer, then open it up that way
Sep 29, 2012 | Sony Walkman NWZ-S616F MP3 Player
Sony Walkman NWZ-B162F MP3 Player won't turn off
I was also facing the same problem, and while going with some hit and trials, was able to find a solution for this as following: power can be switched off by holding the main key for long, the key which is used to select the folders, that is, the center of navigation key. Hope it helps.
Jun 13, 2012 | Sony Walkman NWZ-B103F MP3 Player
Sony walkman Sony Walkman Bean NW-E305 (512 MB) MP3 Player won`t charge
Good morning, afternoon, evening or night; whatever time of day you are reading this solution post. Thank you for choosing FixYa to assist you with your problem. Your Sony Walkman Bean NW-E305 (512 MB) MP3 Player won't charge properly? Well Danish, we must use a method called troubeshooting to figure out and solve this situation. There are several reasons why this player may not be charging properly. The cause is either coming from the battery inside of your MP3 Player, a bad or faulty USB cable connection, or something (software) isn't installed correctly. Let's look at the first cause- The battery. The battery life may be gone. If it is, you will need to replace it if possible. Your device takes a
Sep 26, 2011 | Sony Walkman Bean NW-E305 MP3 Player
Sony walkman NZ-E353 was working fine both alone and attached too a docking station. Next day it won't come on and keeps flashing "HOLD" before turing off.Battery is fully charged. Please...
I'm sorry that the Walkman Player is not turning ON normally and displaying "HOLD" message. The "HOLD" message indicates that the Walkman player is set to HOLD mode by sliding the HOLD button on the right side. Please make sure that the HOLD switch is not activated.
If the issue persists after moving it from HOLD position, please reset the Walkman player by pressing the reset button using a sharp pointed object. The reset button is located on the rear of the unit.
Thanks for understanding. Please let me know if you require any clarification.
Jul 31, 2011 | Sony NWZ-E353 MP3 Player
Eureka HotShot 350A heats up great but no steam when I press button.
Remove water fill cap. Remove rubber washer under cap. Unscrew three phillips head sscrews, one on end of handle, two under rubber washer. Take handle apart. remove clip holding rubber hose onto steam flange. Unloosen plastic steam flange and remove. Using a large pair of pliers or channel locks gently squeeze valve together. It will only move an eighth to a quarter inch. Dove several times until you can depress the pin by hand. Reassemble.
Jan 18, 2011 | Eureka 350A Handheld Steam Vacuum
Cant play back tracks no data
Did you add songs to it yet? To add songs to it plug it in the your computer and import the songs to it. If it still won`t work rebuild your data base. Doing so well factory reset your Walkman and fix any bugs in your Walkman.
Jul 17, 2010 | Sony Network Walkman NW-E005 MP3 Player
I just brought a sperry dm-350A to test the switches on my dryer I thought they would come with instructions on how to use it but it didn't. Is there a place where I can go and learn what the symbols...
Just got mine from home depot. Stick the black wire into the COM port and the red wire in the V port on the right. The red wire is the positive and the black is the ground. Touch the red tip to the positive and the black one to a ground. Turn the dial clockwise to the right and you are measuring your voltage(i left it on 200).
Jul 11, 2009 | Measuring Tools & Sensors
Nwz-s515 won`t charge
Check for a reset option somewhere in the software, if after reset (or if there is no reset option) it still does not charge then the battery has died. You can call Sony for repairs, it may be under warranty still. If it needs repair head over to Sony's website for repair at:
http://eservice.sony.com/webrma/web/index.do
Jun 25, 2009 | Sony NWZ-S615F Walkman Video MP3 Player
Fuji s7000
Thanx to forum input I found a Quantaray qb-350a flash with a single contact on the hotshoe. By turning on "external flash" in the Fuji s7000 allows the Q350 to work beautifully and for about $40 bucks. It also works on earlier Fuji's like the 6200.
Thanx
Frank
Mar 20, 2009 | Quantaray QTB-9500A TTL Flash
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
