Question about Nokia 5300 Grey Cellular Phone
5300 fell in water
My Nokia 5300 fell in water for about 5 secs... As soon as i picked itup i asaw that my screen was bluring, then i tried to switch it off by the phone was frozen. so i removed the battery, tried to blow and suck out as much as water i could. then i held it under the blow dryer.
I have still not put back the the battery and see that there is whitish patch surrounding my screen.
please advise.
  • 67 Answers
Re: 5300 fell in water
Open up yor phone clean the phone with the isoprophyl alcohol dry it using the hair dryer avoied heat going to the lcd avoid ipa going to the lcd. advice by dogy
Posted on Jan 11, 2008
0 characters
3 Points
Hi there, I just dropped my nokia e63. The moment it fell down its battery just came out. I think it fell on snow and the water may have gone inside it. After re-assembling my phone I just opened my Music...
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Dec 31, 2010 | Nokia E63 Cell Phone
Shows main screen w/date time mins. etc for 5secs, then goes blank and shows the 2 hands touching and the word Nokia, then shows TRACFONE, then shows when due date is, then shows main screen w/date time...
May I ask if your fone may have fell into water, beverage, washing machine etc?
well, I believe that the reason for the loop is because the circuit has corroded and made contact with other parts of the mother-board. It may not be too late to see a cell-fone technician and have it cleaned out.
Hope this solves your problem. :)
Oct 20, 2009 | Nokia 1100
there must be a problem in the battery or it's just low battery... those can be simple. Have them a look at the store where you bought it
Jun 20, 2009 | Nokia 5300 Grey Cellular Phone
Nokia 5300 Blank Screen
hi there,
I think its a Flexible cable or LCD problem.
if the fone still in guaranty, just send it to your nokia service center. Or you can send it to repair shop for faster paid solution.
Aug 05, 2008 | Nokia 5300 Grey Cellular Phone
Nokia 5300 Problems!
i had that same problem with mine. hehehehe. i think you should try holding the button for lik 3-4 seconds and instead of the screen listing, it'll hopefully switch off for you.
Jun 05, 2008 | Nokia 5300 Grey Cellular Phone
How to format the nokia 5300 phone memory
just remove your MMC n just type *#7370# n will ask u the security code.type it out (default code is 12345 )
NOTE: battery must b full, else if format is disrupted by low batt, consequences will b disastrous
I heard the code *#7780# works too, pretty much the same i think.
but back up everything before doing this onto ur computer or MMC.. dont forget to rate me.. thank you sir
May 11, 2008 | Nokia 5200 Cellular Phone
Crack screen
HI fllow the step plz. open the uper body > open 4 screew > pick the protection plate > u see a jeck of display > plz open with carefully > place a new display > push the jeck tightly > place the protiton plate > put the screew > tight carefully > place the body. keep voteing THANKS.
Mar 22, 2008 | Nokia 5300 Grey Cellular Phone
Phone restarts on its own
I tried to switch on my cell with the data cable already attached.It kept on beeping on my pc but cel did not switch on.I detached the cord and switched on my cel.It showed the nokia logo and kept switchin on and off.Later i removed the battery,replaced it back and switched it on.And BANG!!! After 5 minz it switched on!!!!!!!!
Feb 11, 2008 | Nokia 5300 Grey Cellular Phone
Nokia 5300 Grey Cellular Phone Logo
144 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
