Question about Sony KP-57WS500 57" Rear Projection Television
SONY KP-57WS500 TV is Dead and blinks 6 times. Any
SONY KP-57WS500 TV is dead and LED blinks 6 times. Any Suggestions? Thanks, Alltech Service
  • 1 more comment
  • Jeff
    Jeff Nov 19, 2009
    What I found is Q8038, and Q8035 both shorted on the D-Board.
    Is there a common cross part number for these parts?
    Thanks, Jeff @ Alltech Service.
  • Jeff
    Jeff Nov 19, 2009
    No I don't
    Thanks
  • Jeff
    Jeff Nov 19, 2009
    Ok Thank You for your time.
  • 10,594 Answers
6 times blink shows following error in TV..
Low B OCP/OVP
(Over current/Over voltage) +5 line is overloaded. (A, B Boards) or +5 line is shorted. (A, B Boards)
Above said is service manual description of 6 blinks error
Please check power supply +135V output and if its missing, replace IC6003 MCZ3001D and Q6005 & Q6006
Let me know your finding to move forward,
Thanks.
Posted on Nov 19, 2009
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Nov 19, 2009
    TV should show 2 or 7 blinks error on shortage of these transistors.
    Q8035 is H-Out and Q8038 is HV Out
    Check +135 volts as I think its much over volts that can damage above transistors.
    If HV Block is shorted that can also blow off said transistors. Flyback transformer is also can be cause of problem.
    Do you have schematics of Sony KP-57WS500 ?
    Thanks.
    OK, click HERE and download all 11 files and unzip with Winrar to get pdf format service manual copy that will help you as you are tech person.
    Download Winrar trail version if you don't have yet.
    Hope that will solve TV problem.
    Thanks.
    Thanks, you are fellow expert :)
Sony KDL-46S5100 As the customer was watching it he heard a loud crackel sound and went dead. now all it does is click when I press the power button. No Bad Caps. Any suggestions? Thanks. Alltech TV Repair...
Let me know does power light is blinking on KDL-46S5100 tv front when it refuse to turn On?
If yes, how many times it is blinking as there would be 3 seconds long pause between blinks so count pause to pause and let me know to diagnose possible cause of problem and provide you its solution.
Thanks.
Nov 15, 2010 | Televison & Video
Sony KP-57WS500 Rear Projection TV Problem
hello if you could tell me how many times it blinks i'll try and tell you the fault thanks
shaun
Oct 25, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony KP53XBR45 Customer was watching it and the picture just whent out but still had sound. Now when press power button the LED light flashes 7-times and won't turn on. Any suggestions? Thanks, Alltech...
Are you getting sound? If not, then your power supply is faulty. If you sound but no picture, then an IC or STK capacitors are faulty depending on what type of tv it is.
Sep 23, 2009 | Sony KP-53XBR45 53" Rear Projection...
KP-51WS500 Flashing 6 Times
Well, it's DEFINITELY the High Voltage power supply is DEAD! Won't start up...or goes into OVERVOLTAGE SHUTDOWN....
Most of the time it's overvoltage problems...
The KEY to knowing which one is actually occurring is the amount of time it takes before the 6 blinks occur...
A DEAD HV circuit takes a lot of time, while the OVERVOLTAGE will take less than 40 seconds for it to register the 6 blink code....
In this case (overvoltage) replacing the HV oscillator/regulator IC is mandatory...
A dead HV circuit could be anything in the HV circuit, from the Regulator IC to the HV splitter...
It's really wiser to consult a TV technician on this....
Mar 25, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500
YOU HAVE A BAD CRT. CRTS ARE NO LONGER AVAILABLE FOR THIS SET. REPAIR COST WAS $1200-$1500
30 YR SERVICER
APGONZO
Jan 07, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57 in. Rear Projection Television
THE LED ON THE FRONT OF THE SET SHOULD BE BLINKING IN A SERIES OF BLINKS THEN PAUSE AND REPEAT THE SEQUENCE. IN ANY CASE IT NEEDS TO BE SERVICED BY A SONY AUTHORIZED SERVICER.
Dec 27, 2008 | Sony KP-57WS500 57" Rear Projection...
I'm not sure about the reliability of the information you got. According to the service manual, 6 blinks on this set (KP57WS500) indicates a low B+ condition, a short or load on the 5 volt line, probably on the A or B boards. Start by checking IC2 on the A board, this is the 5 volt regulator. If it is good, then you have to start disconnecting things to see what's loading the line. I would suggest the video driver IC's which are on the CRT pcbd's, you can disconnect them one at at time and monitor the 5 volt line to see if it comes up. Remember to rate this soltuion please. Thanks!
Nov 03, 2008 | Sony KP-57WS500 57" Rear Projection...
Six (6) blinks on the Timer/Standby led
6 blinks means lamp thermal fuse blowing, replace thermal fuse.
See here
Aug 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony kp-65xbr10w led light blinks 5 times
i have a sony tv model kv36fs17. led flashes 5 times. tv works but no red color. would could be the problem? thanks
Jan 23, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
169 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
