Freecom Classic Ext HD 250gb OK for 2 years or more, not now recognised by Windows XP when plugged in to USB port. Will not install via Hardware Wizard. BluE light on unit flashes, but unit makes more clicking sounds than it used to.
  • daveh701 Nov 20, 2009
    Thanks - at least I've now got something to
    work on.
  • 19,396 Answers
Hi.
Clicking noise is a bad symptom. When a faulty hard drive keeps clicking and it is not detected, that is often because of broken hard drive heads.
In that case the data is often lost, because the recovery will be very expensive, as the technician will need a clean room facility to take apart the hard drive.
Regarding general troubleshooting you can follow the following guidelines.
Try a replacement USB cable first, and test the MyBook on a different computer, to ensure the fault is on the external storage unit.
There are two possibilities:
The Freecom USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be Freecom.
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
If the hard disk is clicking a lot, then the enclosure is usually working, and what is faulty is the disk, because of broken heads, as I said before.
Posted on Nov 20, 2009
Cant get my sumsung S2 external hard drive to work..my computer does not recognise it
If you are trying to use it on a computer with Windows XP or later installed it and it isn't automatically installing the drivers and finding the drive for you then there are typically only 2 possibilities of what's wrong.
1. Your external drive is probably Dead.
2. The USB port you are using is dead. Try plugging it in to a different USB port.
Before you write the drive off as DEAD, make sure you try plugging it in to a different computer and see if it works on the that computer.
Aug 17, 2012 | Computers & Internet
Usb ports on processor does not work
Click Start
Click Control Panel
Click Classic View
Click System
Click Hardware
Click Device Manager
Expand the "USB Serial Bus Controllers" branch.
Any "yellow" or "red" icons indicate that the device-driver software for your USB ports is not installed, or it is incorrectly installed.
Since your Shuttle motherboard uses a VIA chipset, VIA says:
For Win2K and WinXP, due to licensing agreements, a VIA USB2 driver package cannot be distributed online. Driver support for VIA USB 2.0 controllers requires Windows XP SP1 (Service Pack 1), Windows 2000 SP4, or system upgrade through Windows Update.
So, just run Microsoft Windows Update, and look in the "Optional Hardware" section for available downloads for the USB 2.0 ports on your motherboard. Select and download and install the update.
Dec 10, 2009 | Shuttle MV43VN Motherboard
I have lost the cd which came with my freecom classic hd 80gb and I had to wipe my computer. Now my computer will not read the files on my freecom harddrive
You don't need any software to use this device. If your hdd is external, you just plug it in to any computer via the USB port. If it is an internal hdd same thing again. You can read your files after restoring your computer. But of course it must be your secondary hdd.
Oct 27, 2009 | Computers & Internet
Computer doesn't seem to recognise LG KU990i via usb
first check ur usb port that is it ok? sometimes some usb has problem when it become old. then check ur usb cable is that ok? if everything are ok then format ur pc and install usb 2 software for ur usb system. thanks
Aug 08, 2009 | LG KU990 Viewty
Xp computer wont recognise new 250gb elements ext hard drive
use it on a differnet usb port
these portable hard drives have some issues with 1.1 usb ports
Jul 12, 2009 | Computers & Internet
DRIVERS FOR IOMAGIC 250GB (WIN XP)
The I250HD35 is plug-and-play with Windows XP. That means that all of the drivers needed to run your hard drive are included in Windows.
If your computer is asking for drivers when you plug in your drive, one of two things is probably happening:
1) Windows XP doesn't know where to look for the right drivers
2) Your drive has malfunctioned
The easiest way to assess which of these is happening is to take your drive and plug it into another computer that is running Windows XP. If it is detected properly on the other machine, then your computer doesn't have the right drivers or is looking in the wrong place for them. If it doesn't, then I/O Magic will be happy to replace your drive if it is still within the warranty period
If it is detected properly on another Windows XP machine, then when it asks for drivers, make sure to point it to the WindowsINF directory. This is where the default drivers are located.
If your drive is not detected properly on the other computer, your drive is probably experiencing a hardware malfunction. Please visit the I/O Magic website at www.iomagic.com and click on Support for specific return information.
Have a nice day,
I/O Magic Technical Support
Aug 03, 2008 | IO Magic Corporation GigaBank (I250HD35)...
My drive is not recognized
I've had this problem before.
I tried a different cord and it started working again. Additionally i've had this work for me (see below)
Try This:
  1. Unplug all USB devices
  2. Turn off Ext Hard drive
  3. Shut down computer
  4. Power on ext hard drive (then wait like 1 min)
  5. Turn on computer
  6. Wait for windows to finish loading
  7. Plug in the USB cord from the ext hard drive to your computer (may take up to a minute for computer to recognize it)
  8. If it doesn't recognize it then keep trying it in different USB ports
If it still won't recognize get all the latest windows update and reboot. If that doesn't solve your issue try your external hard drive on some other computers, check to see if drive needs special drivers installed (which most don't).
From SimpleTech's website: "1) I have the drive plugged in but I cannot find the drive in "My Computer", why?
The most likely cause would be not enough power provided by a single USB port on your computer. Unplug the portable drive from the cable and unplug the cable from the computer. Now, plug the cable into 2 USB ports directly on your computer. (If you have a desktop, you should plug the USB cable directly into the USB ports on the back of the computer. If this is a laptop, you should plug directly into a USB ports on the computer. Do not plug into a USB hub or docking station). Then plug the drive into the cable. In a few seconds you should see the drive listed in the "My Computer" window as a SimpleDrivePS."
If all that fails you need to RMA (Return to Manufacturer) your external hard drive. Most hard drives have a pretty decent warranty on them. Your simpletech 250GB has a 3 year warranty on it. Info on the warranty can be found at http://www.simpletech.com/support/warranty/. If you want to RMA it, click the "Technical Support / RMA Request" on the left hand side of that page.
Jun 27, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computer recognises printer but print requests not actioned
that happened to me with my cannon ip4300 so I installed the driver again so I had 2 drivers installed on the computer. The computer named the seconed instalation cannon (2) .
number 2 worked the first didnt.
so used number 2.
later deleted number 1 .still all ok
wierd but worked.
david267
Jan 27, 2008 | HP LaserJet 4L Printer
Problems using usb ports
I assume these are the built in ports you are
having trouble with.Do you have a terminal to
install another usb port via a dongle It may be
that the inner terminals of the usb receptacle
are not making good contact (defective) If you
have a junk board with same setup you
might be able to desolder the port,and
replace yours. I haven't had the occassion to
try this yet, but it might work
Nov 16, 2007 | AOpen AX4SPE Max (91.8AT10.501)...
Computers & Internet Logo
253 people viewed this question
David Payne
David Payne
