Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
I insert my PNY 4gb drive into the usb port, it appears as Removable Disk E: and when i click on it under my computer and i receive the "please insert disk into drive E:" error.
  • gtarbert Nov 20, 2009
    Sadly these suggestions did not work. My USB ports work (1.0, but they work for my iPod and other devices.) I tried uninstalling the driver (not sure if it was successful) and re-inserting the flash drive - but the computer never indicated it was re-installing the device driver.
    One more tidbit I forgot; the device was working fine. I loaned it to a friend to upload a ppt file and when I received the flash drive back, the flash drive then gave me this error. This is somewhat time sensitive since I'm travelling, so please don't be offended if you are unavailable and I have to use a different expert. Regardless, thank you for your time and assistance.
    Regards,
    GTarbert
    I have a USB 2.0 PNY 4GB mini-drive. It was working fine, then I loaned it to a friend to upload a ppt file. When I received the flash drive back, I plugged it into a functioning USB port. The computer recognized the flash drive as a a Removable Disk, Drive E:. When I clicked on Drive E:, I received a window instructing me to insert a disk in Drive E:
    I've tried uninstalling/re-installing the driver, but I am not sure it was done properly. I've gone to the control panel and the add new hardware function was unable to detect this flash drive as new hardware. I've plugged the drive into a different USB with no success. I've restarted the computer with the drive plugged in during the restart. All of these things have apparently failed....any ideas?
  • 4,281 Answers
Try your usb in different usb ports.
Connect it to computer then when you power up the computer press F8 key then enter in safe mode.
Then check .
Also right click on my computer then click on manage then click on disk management or removable storage thne you can see your drive there.
Right click on it then explorer.
If still same issue check it in another computer if it gives same error then your drive has internal chip issue if it is in warrenty use warrenty.
Let me know if you need further assistance.
Posted on Nov 20, 2009
  • Connect your flash drive to your computer.
    Then when you power up the computer press F8 key then enter in safe mode.
    Then right click on my computer icon then click on property then click on hardware ->device manager.
    Then you can see all driver list sleect usb drivers and right click on it then uninstall all usb drivers 1 by 1 .
    Then restart your computer then it automatic installed all usb drivers.
    Then check.
  • 643 Answers
Hello, and welcome to Fixya.
Thank you for asking your question here.
There are a few things to try first.
One, try going to the control panel, add hardware, and seeing if your computer can detect the drive.. (if it does, let it install the drivers it needs to read it)
Two, try restarting your computer, with the drive plugged in the whole time.
Three.. try using a different usb port, sometimes they go bad, and if you have multiple usb ports, try all of them individually.
If none of this helps , please get back to me and i can suggest a few other things..
Posted on Nov 19, 2009
When i insert my 4gb pendrive ,it write insert disk drive what i do/
Dee:---- Log in as Administrator account in windows or any other account with administrative privileges
Dee:---- . Insert your removable disk into the USB port.
Dee :----. Click Start, now right click on my computer and select manage
Dee:----. Now, click Disk Management
Dee:---- . Right click on your removable drive partition and select Change Drive Letter and Paths under Disk Management ( you can find your drive easily through size )
Dee:---- . Change the drive letter some other drive letter like X: or Z: which is not reserved by some other drive on windows.
Dee:-----. That's it! Done.
Thanks
Deepak Kulkarni
System,Surat
+91-9898726758.
Dec 14, 2010 | Transcend (589307) Media
PNY is not working
the computer is not seeing it properly un plug,then refit ,are the contacts clean,
Jul 06, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I bought one pny pen drive of 2 GB after 4-5 mouths it gout courapted an when I try to explore/open and fromet a mesage is displyed by windows thati please insert disk drive in H:
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 14, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
We just bought a 4gb micro sd card with sd adapter and it is not recognized on our computer. Is this a software problem?
Oct 26, 2009 | PNY 4GB microSD High Capacity Mobile Media...
When I put my DaneElec 4GB USB Drive into my USB port, nothing happens. We have Vista.
Do other USB devices work when you plug them in the USB port?
If they don't then you have a faulty USB port otherwise the DaneElec is faulty or needs formatting.
Oct 18, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
Cruzer micro 4gb will not format. Also, PC will not reveal contents.
Oct 12, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have a PNY 4GB high speed USB Drive. I want to
Well, the easy way would be to do this
But if you want to use the USB drive just insert it into an open USB port
  1. click Start
  2. click My Computer
  3. Select the USB drive from the list of connected drives
  4. Click and drag the files from their location to the USB drive
To get them to the other computer follow steps 1-3, then click and drag them from the USB drive to their new location.
Sep 16, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
PNY Attache USB (4GB pen drive) not recognized by WinXP SP3
Your USB memory should be damaged. i have a Centon DataStickPro 4GB that was OK but now i have the same problem. If you know HOW you can try re-format on DOS, but be careful with your harddrive.
By the way, 3885 MB are 3.7GB or so.....
You can try buying another one, SAME MODEL, then the same/next day return the BAD ONE to the store and get your money back.
May 16, 2009 | PNY Technologies GeForce 6200 128MB AGP...
Please Insert a Disk in Drive H:
you can replace your usb port, or YOU CAN USE YOUR PENDRIVE IN ANOTHER COMPUTER, by which you will come to know that whether your USB port is OK or not.
Mar 26, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Install a disk in drive F?
Download this file from PNY to reformat your Flash Drive. It should work after that. Get the file here:
http://www2.pny.com/support/media//Files/06c3418a-bd4a-4a67-a7b7-f4415a58338a/Pre-test_v1.zip
Aug 22, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
82 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
