Question about Cycling
Hi. I've had this problem before and it's infuriating. I've renewed my Chain wheel, Chain,and 8 speed cassette. It works fine on the stand. However when road testing I find that in either of the front 3 gears, 8th gear has a slight 'slip'when it first engages, it doesn't seem to slip again but I fear it might having done so the once. My rear and front mech I've not replaced. Could old jockey wheels be responsible for this? The chainwheel is Shimano, the cassette is hyperglide shimano, and the chain is a Taya 7 and 8 speed chain. What else could be going on, apart from that everything seems smooth, what's going on PLEASE? Thank you.
    President:
  • 1,137 Answers
Try using a Shimano hyperglide chain. I know they are more expensive but they fit better. The reason is the angle that the teeth of the cogs and gears are machined at. The idler wheels should be replaced too if you think they are worn. Also make sure that the tension spring in the derailleur is getting weak. They can be replaced with a little work. Here's some sites with info that will help:http://www.parktool.com/repair/byregion.asp?catid=5 Also:http://sheldonbrown.com/harris/tools.html Please let me know if this helped.
Posted on Nov 20, 2009
How do i remove rear gear cluster from giant rapid three cycle
Proper tools are a necessity. A cassette lockring tool and chain-whip (examples: http://www.roadragecycling.com/2012/10/bike-tools-top-11-you-need-most.html about half way down the page)
The proper lock ring for a Shimano 9 cassette is a Park Tool FR-5. There are other generic tools as well; but the FR-5 is the most common.
Many companies make chain whips too. My favorite (and the one in the picture) is the Wheels Manufacturing tool. It is also one of the most affordable.
For what it's worth: if there is a bike shop near you - many will remove a cassette for a nominal fee. Often $5-10.
Oct 08, 2012 | Shimano 9-Speed Bike Gear Cassette
I need to change the rear gear sprocket, but don't know what speed the mountain bike is. How can I tell what speed the bike is.
Count the cogs, duh. You're going to need some help even after you know if it's 6-, 7-, 8, 9- or 10-speed in the rear. Special tools and 'how-to' knowledge. Take it to a Bicycle Shop an experienced DIY cycling friend.
http://www.parktool.com/blog/repair-help/categories/cassette-and-freewheel-service
Sep 01, 2011 | Cycling
Somebody stole the back wheel off my bike. i want to replace it but am on a tight budget. will any 8spd wheel do?
No, if it's disc you need to make sure the hole pattern is the same if you want to be able to swap discs around (minimal setback). Then you need to get a disc that's the same size as the one you had because wheels don't normally come with the discs on them.
The rim width is not a BIG deal within reason. Try to match the remaining rim.
If it's a rim-brake style it doesn't matter so much.
In either case make sure it comes with a cassette body that is 8-speed compatible. Then you need a gear cluster.
http://sheldonbrown.com/k7.html
If the chain has significant miles on it you might as well get one of those too or it may be too worn to mesh properly with the new gears and it will prematurely destroy them if it works at all. Specify 8-speed as they come in different widths.
http://www.sheldonbrown.com/speeds.html
http://sheldonbrown.com/chains.html
Believe it or not, taking the bike to a shop and letting them replace the wheel will be the fastest and least expensive solution unless you already have the knowledge and special tools required for cassette and chain service.
Jun 06, 2011 | Mongoose 2006 Pro Tyax Comp Men's...
I have been given a set of Mavic NKSIUM Race wheels currently fitted with a Campag Cassette. Are these hubs Shimano compatable, as I want to fit a 8 speed Shimano Cassette Ian...
Nope. Campi and Shimano casette bodies are TOTALLY INcompatible, BUT I have had good luck with finding Campi casettes online (eBay) and having no interchange problems between my wheels and Shimano or Campi 9-speed shifters and derailleurs on several bikes. I switch wheels without concern for the other hardware.
http://desc.shop.ebay.com/i.html?_nkw=campagnolo+8-speed+cassette&_sacat=0&_odkw=campi+8-speed+cassette&_osacat=0&_trksid=p3286.c0.m270.l1313&LH_TitleDesc=1&_rdc=1
Within Campi there may be incompatibilities, though. If your wheels have an 8-speed Campi cassette now I think you'll be ok.
Feb 09, 2011 | Mavic Cycling
Question, . . need to replace chain Will a Sram PC-971 Chain work on my 8 speed road bike? Thanks T.K Yandell
Nope - This is a 9spd chain. The gears on a 9spd are narrower than on an 8spd. If you are going to use a SRAM chain you need one that starts with an 8 such as PC-850.
Any 8spd chain will work fine, Shimano, SRAM, whatever.
Nov 21, 2010 | Cycling
I have a Campy cassette set on my Cannondale. Lately, there has been an intermittent clicking noise coming from the rear wheel when pedaling. Nothing appears to be hitting the wheel. Also, at speeds above...
Clicking noises are commonly bearing problems but may occasionally be loose pedal cranks. If rear cassette isn't free wheeling properly sounds like a free wheel bearing is defective. I don't know your Campy - mine are all Shimano - but you should be able to replace the free wheel assembly OK as a separate service item. Mind you if it's of an age to demolish a bearing you should also be checking the gear teeth and chain for wear.
Nov 21, 2009 | Cycling
Front derailluer casset capacity
I know the Shimano Mega9 front and rear derailleurs work with 8 speed drivetrains, provided you are using the correct shifters.
Sep 02, 2009 | Full Speed Ahead Cycling
Drive chain goes loose and tight on back wheel turn
No.That was the problem.The chain and the sprockets needed to be renewed.
When you will take, the rear sprocket's base, off the axle check it's bearing.Just put your finger in and turn it slowly to see if it "locks" instantly.It will be nice if you renew it now that you disassembling the chain drive system.
Jun 07, 2009 | 2002 Honda CBR 600 F(4)i
Chaine question
the chain will flop around when running it on the center stand.the chain should have from 5/8 to 1 inch of slack in the middle of the chain when on center stand on the bottom run of the chain. if you adjust it turn the chain to find the tightest place in it and then adjust it at that point.if you adjust it at the loosest point it will be too tight--they dont wear even.dont know about cam chain noise--i wouldnt worry about it they dont give much trouble.
Nov 10, 2008 | 1991 Yamaha FZ 750 KS (Europe)
Cycling Logo
122 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
