Question about LG WM-2277HW Front Load Washer
On the top in the back, there is a round white plastic piece (like an inset disk) below the water hoses. There is a small leak out of it. What is this part and how do I fix it?
  • hbr3 Nov 19, 2009
    Full model number is WM2487HRM
    611KWVQ03079
    About 2-3 years old
    The leaking part is the white plastic peice, about 2+" in diameter directly below the cold water inlet valve/hose.
    Thank you.
  • LG Master
  • 19,396 Answers
Hi.
The part where the hose is connected is the inlet valve, that part is often leaking when there is a fault. In that case it must be replaced.
Please give me complete model number, as printed on service plate.
I will post another message with part for the model in title.
Regards.
Posted on Nov 19, 2009
  • Ginko
    Ginko Nov 19, 2009
    Here the service manual:
    SERVICE MANUAL
    Check the schematics at page 40.
  • Ginko
    Ginko Nov 19, 2009
    Regarding the part,
    you can locate and purchase the part using the links below.
    You will find diagram and part list below in the Sears Parts page.
    You can purchase the part online from their website.
    Click the links to open diagrams.
Don't know how to get detergent into the ultimate x pressure washer (1500psi)
To the right of the Brass fitting where your garden hose attaches there is a small round plastic cover piece, pull on that and it will pull out a clear tube with it which goes into any container containing your detergent, it will pull the detergent as you use the pressure washer. Push the tube back in after you are done using it. You can also buy a replacement detergent bottle for other pressure washers if you wanted to.
Jun 05, 2011 | Garden
The water leaks from the back side of the washer just under the cold water hose (at the top of the washer). Their is a round plastic part with some open space in the part. When the washer goes to rinse...
that is the drum vent. there is a mushroom valve inside to prevent water from coming out.when it fails, water comes out of vent. the valve either needs to be replaced or cleaned and reinserted. the top cover will need to be removed to do this. remove 2 back bottom screws and slide top towards rear to remove.
May 10, 2011 | LG WM-2277HW Front Load Washer
I have a 1984 cadillac deville small plastic piece inline with heater core hoses leaking ..at back of air filter on top...what is this piece called?
probably your heater control valve. below is a replacement from autozone, but yours may look different. If it isn't the control valve, maybe it's a splice someone put in. The control valve is the only thing that comes stock in the heater hose.
Oct 15, 2010 | 1984 Cadillac DeVille
Cant find ac drain hose on 2002 mitsubishi montero
Center of the firewall just below two transversal hoses.almost inside tranny tunnel..difficult to access and clean.
Jul 27, 2010 | 2002 Mitsubishi Montero
Water is leaking out from under the front part of the machine (this is a top load machine). Doesn't matter whether use small or large fill. have checked hoses and drainage in back they are not leaking....
have u checked the pump that is located iin the front of the machine? Remove the entire cover of the machine look down in the very front when the cover is removed turn the machine on and you should be able to see exactly where ur leak is coming from your pump is located on the motor small white or grey plastic round like object sometimes it can leak fromthe center of the pump in any case test the machine with the cover off and you willbe able to find the leak hope this helps
Jun 24, 2010 | Washing Machines
Wii would not eject disk so we took it apart and fixed it but while we were doing this a plastic piece fell out of the metal casing over the disk drive now we cant find where it came from so we are now...
what does this "plastic piece" look like??
that said.. I think its the magnetic disc holder (round- white- plastic- fits on a cd...)
, it sits on top of the disc drive in the round hole - it holds the disc to the motor when the disc plays...
You have to put it back in its holder above the disc, it goes on top of the "crossmember" if you put a disc in the drive and set the laser to lift up and grab the disc you will know if you have it right because the "plastic piece" will grab the disc and hold it tight against the motor.
hopefully this solves your problem... comment back if you need more info or if the p[iece isnt what I described and is something totally different.
Jan 21, 2010 | Nintendo Wii Console
Shower spout
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
Jan 30, 2009 | Price Pfister 01-311 Shower Head, Tub...
Leaking from bottom front
lean washer to back ..pump mounts just underneath 2 clips hold pump too motor shaft remove clips remove hose clamps ckd pump most likely suspect for leaks
Sep 02, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Re: lg wm1812
There is a vent at the back of the machine near the top that is covered by a small round white plastic cross pattern. Inside of the machine there is a black flexible hose that attaches to the vent from the top of the outer tub. inside of the tub attachment point is supposed to be a light blue plastic valve that looks like an old style army helmet on a peg. The peg fits into a flange in the opening on the outer tub. If this valve is missing water will escape from the vent on the back of the machine. Another likely point of water leak is a loose inlet hose or missing washer on the inlet hose.
Mar 14, 2007 | LG WM1812C Front Load Washer
LG WM-2277HW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
