Question about Philips GOGEAR SA6045 MP3 Player
Computer will not recognize sa6045 even with usb cable connected computer will not recognize the player
Cuando prendo el mp4 se prende pero no sale el menu
Posted on Nov 19, 2009
Usb cable is causing a short circuit
the first cable (throw it away), the secound use that one or a new one. then you will need to locate the drivers on the internet, download them and install.
Jul 20, 2012 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
HOW IS THE BATTERY CHARGED
MP3 players are usually charged by the supplied USB cable when it is connected to a computer's USB port.
You can purchase an USB mains adapter and you can then connect the MP3 player with the USB cable into this USB mains adapter.
May 20, 2011 | Philips GOGEAR SA6045 MP3 Player
My sony nwz-s638f is not charging if i put it in the plug how can i make it work?
Please make sure that the Computer is recognizing the Walkman when connected to the USB port.
Make sure that you're using the supplied USB cable for connecting to the Computer.
If you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, reset the player by pressing the reset button.
Disconnect the USB cable from the portable player and then reconnect.
Check the connection status again.
Disconnect the USB cable from the computer and then reconnect.
Check for available space on the player using Windows Media Player or My Computer.
Restart the computer.
Check that the USB cable is firmly connected to both the computer and the player.
If the player is connected to a USB hub, disconnect it and connect it directly to the computer with a dedicated USB cable.
If the player is still not recognized by the computer, disconnect all devices connected to the computer with a USB connection and restart the computer.
After the computer restarts, connect only the Walkman player and test the connection again.
If the player is still not charged by the computer, try a different USB port.
Thanks for using FixYa.
May 05, 2011 | Sony NWZS638F Digital Media Player
Computer not recognizing m
Connect it with the USB cable and if that dosen't work install the software that came with it. If your memory card for the device is removable use an adapter to connect the card to the PC.
Jan 02, 2011 | Philips GOGEAR SA6045 MP3 Player
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
Samsung YP-S3 not recognized by computer
I think you have answered the question yourself. Change the USB cable.
If that doesn't make any difference try searching for the hardware again. Check the settings and drivers are working. Roll back the driver etc.
Apr 04, 2017 | Samsung YP-S3JAB Digital Media Player
My mp3 player won't do anything!!
Hello there,
It is unlikely that the player is dead but the Usb cable or USB/charging port or the battery is dead. If the player is under warranty you can demand for a replacement. Otherwise check if a replacement usb cable would fix the issue. Otherwise its going to cost you around $30 for repairs.
Sai.
Feb 15, 2009 | Philips GOGEAR SA6045 MP3 Player
My mp3 says waiting for usb cable connection!
Triple Reset for GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player.
Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
May 31, 2008 | Philips GOGEAR SA6045 MP3 Player
Lost software for my Phillips GoGear
Click on this link: https://www.p4c.philips.com/cgi-bin/dcbint/cpproduct_selector.pl?slg=ENG&ctn_no=sa6045&chassis_no=&x=0&y=0
And select the correct model number for your player.
SA6045/xx
Where xx is the relevant country code as printed on the player.
Click on software & drivers, then click the software you require.
May 02, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
151 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
