Question about Car Audio & Video
Have a 2002 volkswagen beetle, want to remove stereo unit
I am trying to remove it without disassembling the whole dashboard section. Getting no power to the stereo unit, fuse box does not show a specific fuse for the stereo unit? Where does the power fuse reside for the stereo unit?
  • Car Audio & ... Master
  • 4,917 Answers
The information is here
http://www.somewhereville.com/blogimages/New_Beetle_Fuse_Card_large_10April2009.jpg
Posted on Nov 19, 2009
Testimonial: "Excellent, the factory fuse identifier card was not updated with identifying whish was the radio fuse location"
  • 36 Answers
I think there is a 10a fuse on the back of the radio. get yourself some radio removal tools and pull out the radio. replace said fuse and see if that fixes it!
Posted on Nov 30, 2009
1999 volkswagen beetle has stopped turning on
Have the battry load tested I would say you need a new one
Jul 05, 2012 | 1999 Volkswagen Beetle
My radio does not work in my 2002 VW beetle. I have changed all the fuses and it still will not come on.
You need to pull the deck/unit and check the power wire for power first. Once you establish power you need to check other connections also make sure they are good. You may have a bad radio unit.
FixYa Support
Derek Carden
Sep 17, 2011 | 2002 Volkswagen Beetle Turbo S
Horizontal break light does not work in my pre-loved 1999 NewBeetle. I dont think there is a fuse in the fuse slot if it does in fact use a fuse. If it is a fuse problem what ampere should be used and...
the light works on the same fuse as on the other brake lights if they work it can be the light is faulty or the wiring is damaged.hope this helps
May 27, 2011 | 1999 Volkswagen Beetle
Need a Fuse card Diagram for a 2002 VW Beetle
The fuse panel on 2002 VW Beetle is located behind a plastic cover on the driver's side end panel of the dashboard, door open. See pictures below:
The fuse panel diagram:
Please do rate my response. Thanks!
Feb 13, 2011 | Volkswagen Beetle Cars & Trucks
I need a copy of a fuse card diagram for a 2002 VW beetle can you please help thank you
Feb 13, 2011 | 2002 Volkswagen Beetle Turbo S
What can I do to make the EPC light go off on my dashboard. I have no power and my turbo is not working on my 2002 VW Turbo S Beetle
First you have to scan for trouble codes (DTC), then you navigate using the codes where your problem or malfunction is located. Once it is isolated and repaired will erase the stored codes. You will recode it (new device handshake with ECM), do a setting to default.
If you just want the light off without doing the steps above.
  • Remove instrument cluster
  • Open to reveal where LED is located
  • Use black silicone caulking over the target LED
  • Let dry and replace cover housing
  • Install is reverse of removal
This will not fix your problem only hiding annoying light detection, although it would be dishonest when you sell your car with this fix, if not seriously illegal.
Feb 13, 2010 | 2000 Volkswagen Beetle
How to Check fan control module 2001 vw beetle? Power is getting to both 30A inputs but no output. In addition to both fans not working a/c clutch will not engage.
Sounds like your fan speed switch. I had the same problem. The fan speed switch is the main power switch to your AC. VW only sells the whole cluster wholesale around 150.00. Let me know if you need instruction on removing cluster.
Oct 25, 2009 | 2001 Volkswagen Beetle
Removal of dashboard assembly for 2002 volkswagen beetle
I would strongly recomend you dont tackle this job.They are NASTY.Even qualified VW techs would shy away from it.Once the dash is out the support bar and the heaterbox needs to be removed and they are a pain.Sorry i know its no help but its sound advice .Cheers
May 08, 2009 | 2000 Volkswagen Beetle
Looking for help in replacing low light bulb in headlight for 2002 volkswagen beetle turbo.
It is a pain in the ****. There is a handle under the hood, behind the headlight that slides to release the whole headlight lens. It sounds easy but the slide is usually got all kinds of dirt and rocks in it and won't slide.
May 06, 2009 | 2002 Volkswagen Beetle Turbo S
87 4runner heater difficuly
It is possible because I did it. I remember it being quite tricky and frustrating. Cant remember exactly how but I removed almost the whole dash and ducting but did not have to remove any A/C components.
Jan 08, 2009 | 1987 Toyota 4Runner
Car Audio & Video Logo
141 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
