Question about Pantech Matrix Cell Phone
How can u pair lexus rx350 2010 with pantech phone. passcode for bluetooth
  •  Unlock Any Pantech phone at cheaper price
    Unlock Any Pantech phone at cheaper price $0.50 onwardshttp://unlockpantechmobile.com Unlock Pantech C740 Matrix, Unlock Pantech C790 Alladin-Duo, Unlock Pantech C810 Duo, Unlock Pantech C820 Matrix Pro, Unlock Pantech P1010, Unlock Pantech P2000 Breeze, Unlock Pantech P2020 Ease, Unlock Pantech P2030 Breeze III, Unlock Pantech P6010, Unlock Pantech P7000 Impact, Unlock Pantech P7040 Link, Unlock Pantech P7040P, Unlock Pantech P8000 Crossover Android, Unlock Pantech P9020 Presuit, Unlock Pantech P9050 Laser, Unlock Pantech P9070 Burst, Unlock Pantech P8010 Flex, Unlock Any Pantech, Unlock Pantech, Unlock Pantech Mobile, Unlock Pantech Phone,
How do I connect my Motorola H720 Bluetooth headset to my PAnTECH P7040 cell phone?
Sharon-
Turn on Bluetooth on your pantech phone. Then H720 Bond Pair .
Mark
Motorola Support
Motorola Owners Forum
need help pairing my H70 Motorola Bluetooth with my Pantech P7040 cell...
Mar 08, 2015 | Motorola Mobility H720 H 720 Bluetooth...
Dont know how to find passcode for phone to pair device when using bluetooth
Usually the code is something simple like 0000, 5555, or 1234. Another way is to check your phone's manual, or google your phone name + bluetooth code.
Mar 15, 2011 | Cell Phones
I cannot pair my Pantech Crux phone with my Infiniti G37 using bluetooth. The phone does not ask for code to be input. Car is looking for 1234 code. I suspect the phone is sending 0000
to pair your pantech crux to you car you must hit settings ,bluetooth settings and settings at the bottom of the screen and make sure the didcovery mode and auto pair handsfree are both off then try pairing .It sould work i had the same problem
Dec 18, 2010 | Cell Phones
Bluetooth passcode
To find a bluetooth passcode click tis link bp
to change passcode click tis cp
to reset rp
  • Step 1 Look on the back of your headset or speakerphone for the Bluetooth passcode for the device. Typically the pairing code for headsets is printed on a sticker that is then placed on the underside of the accessory.
  • Step 2 Go into the Bluetooth menu on your cell phone to find the passcode for your cellphone. The Bluetooth menu for your phone is typically located under the "Settings" menu. In the Settings menu there should be an option to "Get code" or something comparable, which would allow you to find the code for your phone.
  • Step 3 Go into the Settings menu for your computer to find its Bluetooth passcode. Some laptops will randomly generate a new Bluetooth passcode for you each time you want to pair them with a new device. In that case the menu setting you're looking for is something like "Generate new pairing code."
  • Step 4 Look in the instruction book for your Bluetooth accessory if you cannot find the passcode attached to the device or in its menu. Many manufacturers will print the passcode for devices in their instruction book. If you still can't find the passcode, try using all zeros.
  • Read more: How to Find a Bluetooth Passcode | eHow.com http://www.ehow.com/how_5169210_bluetooth-passcode.html#ixzz0vcmCZd00
    Aug 04, 2010 | Apple iPhone Smartphone
    Hi i just bought a lg gw300 and i can't set up my bluetooth i don't know how to set up the "passcode".
    Your "Passcode" is setup when you "Pair" with another Bluetooth appliance.
    e.g If you want to connect to your friends phone via bluetooth to send a picture you would send via bluetooth and search for bluetooth device. When you select the one you wish to connect to it will attempt to "Pair" with it. At this point a "Passcode" maybe asked for if the bluetooth device you are pairing with has one set. If it does then you need to ask the person who owns the device for the "Passcode" before your picture can be sent/recieved.
    Normally if you wish to set a passcode for your device it will either be in your bluetooth settings. Possibly even in "Security" in the bluetooth settings or it may just be in your "Security" settings.
    Jul 10, 2010 | LG GW300 Cell Phone
    I can't figure out how to pair my pantech matrix phone to my samsung bluetooth device. All the userguide tell you is how to activate bluetooth. I have done all that. It doesn't explair how to pair the two...
    when you search for devices in the bluetooth menu it will find the other device that has bluetooth enabled and under options it should say pair and it will ask for a code and you can just use 1234 and it will work. ALSO make sure both devices have viability enabled in the bluetooth menu
    Mar 08, 2009 | Pantech C470 Matrix Smartphone
    What is the bluetooth password to connect to another device
    simply you can enter any word and then type the same word to your device
    Mar 05, 2009 | Pantech Matrix Cell Phone
    Bluetooth passcode
    When pairing two phones, you need to set up the connection on both phones. One will ask you to enter the password when you are creating the new connection, which you will then need to enter on the second phone to complete the connection. This ensures that only people you allow to connect (people you gave the code to) can connect to your device.
    As for pairing your headset, try this link:
    http://www.phonedog.com/cell-phone-research/blog/how-do-i-pair-my-bluetooth-headset-to-my-phone.aspx
    Jun 11, 2008 | LG VX9400 Cellular Phone
    Pantech Matrix  Cell Phone Logo
    257 people viewed this question
    Top Pantech Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Jax Planet
    Jax Planet
    Abdul Mannan
    Abdul Mannan
    Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
