Question about KitchenAid Food Mixers
A metal dowel just came out of my kitchenaid mixer, and I can't get it back in. It's supposed to hold the neck of the machine stable.
  • 235 Answers
OLSONRENEE7- Sorry to hear about your mixer. You don't mention the model number, but I'm assuming you have a tilt head mixer, and the metal dowel you found came out of the bottom of the pedestal. Is that correct? If your anwer is yes, then that metal dowel is the pin hinge that your mixer head pivots around going from the up to the down position when mixing.
The inspection and troubleshooting of this problem is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around. If you're lacking one, you can download it from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, and then select Parts List file. You can check the page titled "Base and Pedestal Unit", and look for the part similar to the part you found. Normally this part should not come out during normal mixer use, so I suspect you may require new one.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part vary widely between vendors, so do your comparison shopping. Good luck, I hope this helps. Howard, Burke, VA
Posted on Nov 19, 2009
Metal rod sticking out of the side of the mixer
The rod is the part that holds your mixer head to the base, turn the mixer over and you will see a small screw, loosen the screw and push or hammer the rod back until it is even with both sides of the mixer. Use a non metal hammer, then re-tighten the screw you loosened. it is a set screw that holds the pin in place. i would beleive that it is already loos or else you would not have the rod sticking out in the first place
Sep 05, 2012 | KitchenAid KSM150PS Artisan Series Stand...
OIL IS LEAKING OUT OF THE HEAD INTO FOOD BOWL. KITCHENAID SAID OK, FOOD GRADE OIL! I DON'T LIKE BLACK OILY CAKE OR COOKIES? CAN YOU HELP US TO FIX OURSELVES.
Kitchenaid says to run the machine on 'high' long enough to heat the gearbox well and then turn the machine upside down and let it cool.
What happens is when you don't use your mixer a lot the grease in the gearbox will separate into oil and thicker grease. Warming it and turning it upside down is supposed to mix all the grease together again and allow it to flow to the top of the gearbox.
Give it a try, check back if you get no satisfaction and we'll get you started on changing your grease.
lp
Jan 01, 2011 | KitchenAid KSM103 Professional 5 Series...
Mixer has come off of stand
It will go back in if you back off the screw that was supposed to lock it in place. Look at the mixer part of the unit and make sure that the pin slides thru the hole. If not then turn the screw ccw a turn of so. Now make sure the pin slides easily thru the two holes in the stand part of the mixer.
Now carefully line up the top and bottom halves - look thru the hole in the stand until you can see the mixer's hole line up, then slide/tap the pin into the hole
Now turn the mixer on its side and look for the screw in the mixer casting. Turn it clockwise until tight and the pin will not come out again . . . . for a longer time hopefully . ..
Mar 22, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Rod came out of neck
raise the top while sliding the pin back in. You will need to play with the correct angle in order to get it in all the way. mine won't go in if it's all the way down nor all the way up. it needs to be somewhere in the middle.
Feb 08, 2010 | KitchenAid KSM150PS Artisan Series Stand...
My Kitchen Aid KSM150PS Artisan red mixer trembles alot and makes a grinding sound when I use it. I've exchanged it once already and have the same problem again.
Kitchenaid mixer are supposed to make a slight grinding sound while operating under load. This is simply the gears meshing together while the motor is turning them, but if the sounds gets worse or is already a metal grind type sound this could indicate a broken worm gear inside the unit, and shouldn't be run any longer. However if your mixer isnt on SOLID ground this could cause the tremble as well.Hope this helps
Thanks
Oct 31, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid Artisan 10 speed 325Watt Mixer
Hi, The KitchenAid mixers are usually quite easy to work on if you are competent at DIY. It sounds like a gearbox fault. Gearbox parts are easy obtained for most of the models and are easy to repair.
This is a service manual for a lot of the KitchenAid mixers. Might give you an idea on how difficult it is to work on before taking the plunge.
Hope this helps
Oct 30, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid Classic -Mixer Head wobbles or shakes back and forth
Lay the mixer on its side and look up through the base. You willnotice a small set screw. This holds the pin tight. If the set screw gets loose the pin willl begin to move out and the head will wobble. Simply tighten the set screw. I just did this to my Kitchenaid mixer 10 minutes ago and it now works fine.
Oct 29, 2008 | Food Mixers
Metal stem broke!
you should be able to order the part from kitchenaid.com. while you replace the stem it might be a good idea to replace the hub, and the gear assembly in the planitary unit
Feb 12, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Food Mixers Logo
115 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
