Question about Refrigerators
When the compressor (thermostat?) shuts off, it makes a very loud noise. Freezer and refrigerated area are keeping things cold just fine. Refrigerator is 12 years old.
  • Refrigerators Master
  • 1,606 Answers
The compressor has 3 or 4 internal motor support springs . Over time , one can rust , due to the contaminates in the refrigerant system . One of them can break free , which will not cause any damage , other than a clunk , when the compressor cuts off . You can still have many years of correct cooling , only the noise will be present .
Posted on Nov 20, 2009
Testimonial: "Thanks. At least I know it is still good for a while."
  • Mike Smith
    Mike Smith Nov 20, 2009
    If/when you do decide to get another refrig , this would be a good " garage " refrig , for drinks and the freezer space .
    President:
  • 2,702 Answers
Its getting close to the grave yard by now then?
this noise is likley to be the compressor stopping and being a bit of a grand daddy it kind or knocks a little,
lets face it,, its 12 years old? you must have had your moneys worth out of it by now??? so if it knocks a bit,, its earned it dont you think?
Posted on Nov 19, 2009
We have a bottom freezer Kenmore refrigerator, and it makes a very loud tapping noise, almost like someone hammering. Then it will make on loud pop and quiet down for awhile.
Which is your model.
Also how about cooling temperatures are they ok.
Is the sound like the motor compressor hemmering or the fan blades hammer.
Oct 28, 2010 | Refrigerators
Compressor is making very loud clunk when shutting off.
I think the wire was kinda expensive. If I were you I would try to save the fridge. I think you should unplug it for a couple hours, take everything out for a while and remove any ice. Once the fridge reached room temp, the refrigerant should have made its way back to the compressor. Plug it back in and see if it makes the noise again.
It might just be the fan in the freezer. I would try the unplug/deice for a few hour method first because it is free before you try to replace a fan that might be bumping ice. Good luck!
Mar 10, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerator does not get cold. The freezer works fine, but the fridge only gets slightly cool.
normaly the fridge has its own thermostat to keep the tem right, if this thermostat has stoped working it will do one of two things,,, freez every thing up as it wont turn off the compressor or will just stop working as it wont turn on the compressor,,, try turning up the thermostat first,
Nov 19, 2009 | Hotpoint Refrigerators
Bad capacitor/relay or compressor?
that is most likely a relay. Does the unit get cold while running?
Oct 23, 2009 | Amana ABB1921DE Bottom Freezer...
Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Mar 20, 2009 | Refrigerators
Abnormal cooling in freezer/refrigerator
ok, this is insufficient air flow causing the uneven cooling. the fan that has stopped may be dead. you can test the motor with a multi meter and voltage needle. i would also preform a break point test on the thermostat as well. make sure the compressor and condenser are ok. if the noise is coming for the compressor, you may have a bad compressor unit.
Mar 16, 2009 | Refrigerators
Cake Display Freezer Compressor keeps freezer cold
Maybe the guy meant the compressor is going bad.
Jul 24, 2017 | Traulsen Reach in Freezer - G12010
Noisy refrigerator compressor (?)
This is a compressor problem, and chances are there for this to worsen if not attended promptly.
Feb 06, 2008 | Refrigerators
Refridge makes a loud noise
are you sure it is the compressor making the noise and what sort of noise is it. if it is the compressor, there is no cure except replacement which is not diy.
Mar 27, 2007 | Hotpoint HTR16ABSR Top Freezer...
Refrigerators Logo
229 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
