Question about Electrolux 30" Self-Cleaning Freestanding Double Oven Electric Convection Range - White
How to remove oven racks for cleaning my electrolux oven
  • Electrolux Master
  • 3,361 Answers
Push the racks all the way to the rear of the oven. Lift the rear of the rack to dislodge it from the side rail and pull it out.
Posted on Nov 19, 2009
Message to remove racks when trying to self clean,yet all racks have already been removed.
This message is a reminder to make sure the rack are removed only. If they are removed then continue with the self clean cycle. Good Luck
Mar 22, 2016 | Electrolux 30" Built-In Single Electric...
The 'remove oven racks' light won't allow me to start the cleaning feature on my electolux oven
Thank you for your post, friend!
I see you are having challenges with your Electrolux range displaying "Remove the racks" when they have already been removed. It sounds like you could have a possible issue with the sensor or control panel within your Electrolux range. I would recommend performing a reset on your range. You can do this by disconnecting power from it for ten minutes. If this does not help correct the issue I would recommend reaching out to a professional and scheduling a service appointment for a proper diagnosis. This would help avoid any unnecessary part purchases. -Matt
Oct 21, 2014 | Electrolux Kitchen Ranges
How do I clean the electrolux oven? It won't start after i take the racks out
As you did not specify the exact model I assume that this is a self-cleaning oven, in other words with pyrolytic cleaning. It has a microswitch which is activated by removing the racks and just because that you can not run the pyrolytic cleaning otherwise racks would be destroyed. Do not forget that the temperature during pyrolytic cleaning is app. 500 degrees Celsius. For that reasons the oven door is locked when temperature increasing to app. 300 degrees and unlocked when the temperature decreasing to the app. 200 degrees. It is clear that when you remove the racks only program that you can run is pyrolytic cleaning.
Dado
Oct 10, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux dual fuel range 316471210 self clean remove racks message displayed and cannot proceed
Hi friend, thank you for your inquiry!
I understand that you are receiving a "remove racks" message on your Electrolux range. The oven racks and supports must be removed before the self-clean will initiate or the control will not allow the self-clean to turn on. I hope this is helpful. -Matt
Sep 04, 2014 | Electrolux Kitchen Ranges
Electrolux Icon range won't self clean - "Remove Racks" displayed
Good Morning Friend,
I understand you are unable to self-clean your Electrolux Icon range, model# E30SO75ESS, due to it stating "Remove Racks", when you already have. Please follow these instructions for cleaning your oven:
1. Remove the turntable from the oven before the Refresh Cycle. No food should be in the oven.
2. The Refresh Cycle is 30 minutes.
3. During the Refresh Cycle some smoke and odor may occur. Open a window or use the ventilation fan in the room.
If this does not help, I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try the "Refresh cycle". I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux Icon Oven self cleaning won't start- the lock button keeps flashing. Yes, the racks and rack holders are removed.
Good Afternoon Friend,
I understand that you are having trouble with your Electrolux Icon oven, model# E30SO75ESS, and running the self-clean cycle. I see that the lock button keeps flashing and that you have the racks and rack holders out. I suggest following the steps below to run your self-clean cycle:
    1) Place the rack holders and the racks in your oven.
    2) Reset your appliance, by shutting the power off at your homes circuit breaker, for 3-5 minutes.
    3) Restore power.
    4) Reset the clock, by pressing the "Clock" button then press the number "2". Enter in the time of day, and then press the "Clock" button again.
    5) Start the self-clean cycle with the racks in your range. This is to make your oven recognize that the racks are in the oven.
    6) Take the racks and rack holders out and start the self-clean cycle again.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully.
    -Best Regards-
    WP
May 18, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux icon duel fuel range racks red light wont stop flashing even though I removed all racks, so oven will not start self clean cycle
Good Morning Andrea,
I see that you are having trouble with your Electrolux range, model# E30DF74GPS, and getting it to go into the self-clean cycle. I would suggest giving it a hard reset. First make sure the racks are in. Next, cut the power at the circuit breaker and leave it off for 2-3 minutes. After the time has elapsed cut the power back on. Start the self-clean cycle with the racks inside the oven. We're trying to get the oven to recognize the racks are inside. Once it states the racks are in, cancel out and take the racks out. Now, with the racks out start the self-clean cycle again. If you are still receiving the red light blinking, I suggest contacting the manufacturer or your local authorized technician. Hope this has been helpful.
-Best Regards-
WP
Mar 23, 2014 | Electrolux Icon E30df74gps 30" Pro-style...
Electrolux Icon Oven won't self clean - "Remove Racks" displayed
I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
Nov 01, 2008 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux 30" Self-Cleaning Freestanding Double Oven Electric Convection Range - White Logo
836 people viewed this question
Top Electrolux Kitchen Ranges Experts
Mike Henne
Level 1 Expert
Dominic
Dominic
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
