Question about Epson Stylus Pro 3800 InkJet Printer
Just replaced Epson 3800 LK T5807 cartridge. It still says ink low...
    Genius:
  • 1,011 Answers
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Nov 19, 2009
Error 1404 sevice
This error indicates that the air pressure for an ink cartridge is not correct, which is usually caused by a defective ink cartridge. If you recently replaced an ink cartridge, try replacing it with a new one. If the error still appears, contact Epson for help.
Here is the homepage:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=79928&infoType=Downloads
Good luck
Nov 12, 2012 | Epson Stylus Pro 3800 InkJet Printer
How to replace catridges for Epson Stylus Office T40W??
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing.
>Open the printer cover and the output tray.
>Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the
power light begins to flash.
>Press the ink button again. If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This
occurs each time you press the ink button until all expended or low ink cartridges have been
indicated. Once all of the expended or low ink cartridges have been indicated, the ink cartridge
holder
moves to the ink cartridge replacement position when you press the ink button. >Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover
>Press the ink button and then the printer moves the ink cartridge holder and begins charging the
ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
May 22, 2011 | Epson Computers & Internet
How to I change ink on epson printer NX127 I cannot get the cartage out Can you show me the picture of the cartage ink holder with the lid up
First make sure the printer is on, then open the printer cover and the cartridge cover. Then press the Stop button. Assuming the printer has identified a cartridge with low ink, that cartridge will be moved to the replacement position; then the power light will flash. Squeeze the tabs on the ends of the cartridge together and lift it up. Unpack the new cartridge and remove the tape carefully. Then press the new cartridge into place until it clicks.
If more than one cartridge has low ink, the leftmost one will be in the replacement position when the cartridge carrier stops moving. Press Stop again to advance the carrier to put the next low cartridge into the replacement position. Then press Stop again to have the printer move the cartridges to the home position and charge the print head. When the lights go out or stop flashing, close the cartridge cover and the printer cover.
If the cartridges aren't low on ink, then use the Epson printer utility (under the Maintenance tab) to start the process.
For pictures of the Epson printer during ink replacement see: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_SessionID=@@@@1558177770.1297529968@@@@&BV_EngineID=ccdcademkhmjkgicfngcfkmdhjidfmh.0&cookies=no&infoType=FAQ&oid=150187&prodoid=63088089&foid=157388 . Alternataively, see http://files.support.epson.com/htmldocs/nx125_/nx125_00ug/wwhelp/wwhimpl/common/html/wwhelp.htm?context=Epson&file=Ink.7.1.html .
I hope this helps.
Feb 12, 2011 | Epson Office Equipment & Supplies
How to change ink cartridges on an Epson CX 3800
Be sure you have a new ink cartridge before you begin. Once you start replacing a cartridge you must complete all steps in one session.
1. Make sure the Epson CX printer is on.
2 Make sure the document cover is closed, then open the scanner
Caution: Do Not open the scanner when the document cover cover is open.
3. Press and release the " ink " button. The ink cartridge moves to the check position and the
" On " and " ink " lights flash. If one of the cartridges is low or empty, the printer moves the
cartridge to the _ink out mark.
Note: Don't hold down the " ink " button for 3 or more seconds or the printer starts cleaning the print head.
Caution: Do Not move the print head by hand; this may damage the printer, always press the ink
button to move it.
4. Press the " ink " button again
a. If more than one cartridge is low or empty, the next cartridge moves to the_ink out position.
b. If all of the empty or low cartridges have been identified, the print head moves to the ink
cartridge replacement position.
5. Open the cartridge cover.
6. Squeeze the tab at the back of the empty/low cartridge and lift it straight out.
7. Before you open the new ink cartridge package shake it four or five times, then remove it
from the package.
Caution: Do Not remove or tear the label on the cartridge; otherwise ink will leak.
Do Not touch the green chip on the front of the cartridge, this can damage the
ink cartridge.
8. Place the new ink cartridge into the cartridge holder and push it down until it snaps into
place.
a. Replace any other cartridges that need to be replaced.
9. Close the ink cartridge cover and press it until it clicks into place.
10.Close the scanner.
11. Press the " ink " button The print starts charging ink and the " On " light starts flashing. This
takes about one minute. When it's finished the " On " light stops flashing and remains on.
and the " ink " light goes out.
Caution: Never turn off the printer while the " On " light is flashing or you'll waste ink.
Note: If the " ink " light stays on ( not flashing ), the ink cartridge may not be installed correctly.
Press the " ink " button again and reinstall the ink cartridge until it clicks into place.
Feb 09, 2011 | Epson Office Equipment & Supplies
I don't know how to change the ink cartridge of epson tx 110
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
SEE IMAGE BELOW
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Mar 21, 2010 | Epson Office Equipment & Supplies
Epson 3800 printer stops printing and shows error 131B. magenta ink stains the paper at about distance between 11-17 inches
Hi, I tried looking up your error code 131B and could not find it anywhere, but from Epson troubleshooting page for this printer there should be an error message on the display panel. Check out this link for the messages: http://files.support.epson.com/htmldocs/pro38_/pro38_ug/trble_1.htm#S-00700-00100-00100-00200
I would replace that print cartridge, even if you just bought one just to make sure you dont have a bad cartridge, but do a cleaning of the nozzles first. Let me know how it went.
WBTech
Feb 02, 2010 | Epson Stylus Pro 3800 InkJet Printer
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
Warning:
Note:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
How do I replace ink cartridge?
you can use the maintenance utility on your driver to perform ink cartridge replacement. or you can perform this method should you be using it stand alone:
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
1. Turn on the Epson Stylus NX400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus NX400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement.
If you’re replacing a cartridge before you see a message on the Epson Stylus NX400 Series
LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
follow on through each one of the inks and it should be good there on
Sep 23, 2009 | Epson Stylus NX400 InkJet Printer
How do I change the ink cartridges
1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you’re replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner.
3. Open the cartridge cover.
4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.)
6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
7. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak.
8. Insert the new cartridge into the holder and push it down until it clicks into place.
9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place.
10. Close the scanner.
11. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Caution:
Never turn off the Epson Stylus CX8400 Series while ink is charging or you’ll waste ink.
If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus CX8400 Series with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
got this from the Epson Site
Jul 29, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Epson stylus cx4200 all-in-one?
1. Make sure the printer is turned on.
2. Make sure the document cover is closed, then closed, then open the scanner.
(Do not open the scanner when the document cover is open).
3. Press and release the ink button. The 'On' and 'Ink' lights flash.
If one of the cartridges is low or empty the printer moves that cartridge to the 'ink out' mark. Go to step 4.
If no cartridges are low or empty the ink cartridge holder moves to the ink replacement position. Go to step 5.
4. Pree the 'ink' button again.
If more than one cartridge is empty or low the next cartridge moves to the 'ink out' mark.
Once the printer identifies all the empty or low ink cartridges the print head moves to the ink cartridge replacement position.
5. Open the cartridge cover, squeeze the tab at the back of the empty cartridge and lift it out.
6. Before you open the new cartridge package shake it four or five times and remove it from the package .
(Don't remove or tear the label on the cartridge otherwise ink will leak out) .
(Don't touch the green chip on the front of the ink cartridge - you could damage the cartridge).
7. Place the new ink cartridge into the cartridge holder and push it down till it clicks into place.
8. Replace any other cartridges that need replacing.
11. Press the 'ink' button. The printer starts charging ink and the 'on' light starts flashing . This takes about a minute . When it's finished the 'on' light stops flashing and remains on and the 'ink' light goes out.
You'll see all the above, with helpful pictures, at
this Epson support page
Mar 19, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson Stylus Pro 3800 InkJet Printer Logo
219 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
