Question about Garden
Fuel line diagram for 358.352160 don't know how to route the fuel lines correctly. Have 2 sizes
    President:
  • 2,220 Answers
It is most likely a Poulan almost all are. The IPL is the only manufacturer supplied fuel system detail, it lists components, part numbers and very little routing detail. and is usually spread over multiple illustrations.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
I think you'll find the short video, a few notes and a typical system most helpful. Any local saw shop can provide replacement hose.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
HTH
Lou
Posted on Nov 19, 2009
I need the fuel line routing for an 07 chevy avalanche with 5.3L engine. Which line on the fuel pump is the pressure line? where does it go from pump?
Bruce, look for the fuel line running along frame rail with the gas filter attached, this will be the high pressure fuel line that feeds the engines fuel rail/injectors. searched the net and could not find a lot on the fuel lines for Avalanche. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CK159 259 359 for Chevrolet Avalanche
Pt 1 2007 Chevy Pickup Fuel Pump Replacement At Ray Shop
Pt 2 2007 Chevy Pickup Fuel Pump Replacement At Ray Shop
Aug 19, 2016 | Fuel Pump With Sending Unit Chevy...
How to install lines in proper place on fuel pump
you don`t say if this is a Honda or a truck as your question has 2 different vehicles in your question. that being said the fuel lines are 2 different sizes. match up line size to each other.
Aug 17, 2014 | 1992 Honda Accord
1986 Yamaha Fazer fuel line routing diagram
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1986 Yamaha Fazer fuel line routing diagram Google Search Fuel line diagram
Yamaha FZS1000 2001 Service Manual
OEM parts for Yamaha
Yamaha FAZER FZS1000 Owner Manual
Jul 06, 2012 | 1987 Yamaha FZX 750
Fuel line diagram for sears mini cultivator
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Feb 17, 2012 | Ryobi Garden
I need the fuel line routing diagram for a Craftsman Model No. 358.791510 Weedwacker 32cc/1.9 cu.in. 2-cycle
Jan 18, 2012 | Garden
The fuel line in the tank connects to the nipple. It then goes into the small hole in the tank and then the fuel line from the carb connects to the nipple. This line is the line that is attached to the body of the carb, not near the plate.
Jan 18, 2012 | Homelite Consumer Products 4.0 Amp, 13 In....
I need a diagram for the fuel lines on 1997 kawasaki vulcan 750. i took the fuel lines loose and i don't know where they go
Hi.
There is no "diagram" showing the whole routing of fuel lines in the bike. You need to use different diagrams in Fuel System section of the service manual. Fuel system section starts at page 15 in service manual, but what you really need starts at page 40. I have posted fuel service manual at the end of comment.
There is one forum where users discussed the routing. One user has colored the diagram from service manual to indicate lines routing. Here the diagram:
Here the forum, I quote:
"The red and yellow are the fuel lines that go to the petcock. The green one you left unmarked also goes to the petcock. The line with a question mark is a vacuum line that connects to a part in front of the battery along with the larger lines to the cylinders."
Here the service manual in PDF format.
Regards.
Ginko
Sep 05, 2011 | 1988 kawasaki VN 750 Vulcan
Need diagram / pictures of routing of all fuel lines. 1981. CX500 Custom
It's hard to find diagram for older bike.
I got the pic from the tank to pet ****.
LINK HERE
Aug 10, 2011 | Honda CX 500 B Motorcycles
Need to know how gas lines go on a RGB3100 they rotted off need to see a diagram
I don't have a diagram, but I can explain to you the fuel line routing.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Jun 12, 2011 | Ryobi Garden
Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Garden Logo
730 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
