Question about Belkin N1 Wireless USB 2.0 Network Adapter (S6359026)
I am rplacing a linksys adatpter with a belkin, program will not work keep saying another system running help
    Problem Solver:
  • 12 Answers
Go into control panel, uninstall software options and remove the software for both. Reboot the pc then install the software with plugging in the device. When it's complete insert the device.
Posted on Nov 19, 2009
ICan't hook up magnavox bluray to Belkin n600 wireless router. I had linksys and it worked fine
I hate to say this but Belkin is not a very "friendly" router. I suggest you take it back for a refund, as I did, and get a D-link or Linksys.
They took mine back with no problem because there have been a lot of returns on them.
Mar 28, 2011 | Belkin Computers & Internet
I can not get it to work at all. Is there a CD I need to get this set up? I have a Linksys wireless G router and the Belkin F5D7130 plugged in to it. But I have no range.
You don't need a CD - there is a web interface. First, download the user manual here.
I suspect your problem is the Linksys/Belkin combination. Linksys by default uses a subnet of 192.168.1.xxx while Belkin uses 192.168.2.xxx. With a subnet mask of 255.255.255.0 (the default for both), no communication would be possible between these two subnets. The "255" in each of those first three octets means they must match exactly.
Either move the Linksys to 192.168.2.xxx or the Belkin to 192.168.1.xxx (and keep the same subnet mask) OR you can change the subnet mask to a broader one (255.255.254.0) that allows the two different subnets to talk to each other. This subnet mask would have to be applied to both devices.
According to the manual, the default address of the Belkin is 192.168.2.254, which leads to your next problem - your PC probably can't connect to the Belkin device. Assuming your PC is configured for the Linksys subnet, the easiest way to communicate with the Belkin is to use a network cable directly linking your PC to the Belkin (may need to be a crossover cable) and manually set your PC's IP address to one in the same subnet as the Belkin, like for example 192.168.2.200 with a subnet mask of 255.255.255.0. Then you can open your web browser and point it to the Belkin default address, as outlined in the manual, and make whatever changes are required.
Feb 21, 2011 | Belkin F5D7130 And F5D7010 (Bundle)...
Whats the security key for belkin 33ED
There are two ways of finding a WEP key. The first way is to look on the router itself and on any packaging that came with it when purchased; there may be information on here. The second way is slightly more complex and so for ease of use this has been displayed in numbered stages. This has been tailored for using a Linksys router, and so there may be slight differences in the words if using a different router such as a Belkin.
Steps to find a WEP key:
1. Open a browser (the program used to access the internet). The following process worked for myself when using the Internet Explorer, Firefox and Opera browsers, although I am unsure whether it will work for other browsers (eg Chrome, Safari etc).
2. Type the following into the address bar of the browser. If using a Linksys router type in "192.168.1.1" and if using a Belkin router type "192.168.2.1". The address bar is the area where webpages are typed. It is important when typing in that there is NO http://www. before the numbers.
3. If all has gone well this should open a page that either says Linksys or Belkin.
3. There may be the need to login. When using a Linksys if you don't know what the username and password are it may still be the factory settings, and so enter in "admin" for the username and "password" for the password. If using a Belkin router, the factory settings often come with no password, so just click submit without typing in a password.
4. Click on a) "Wireless" or b) "settings".
5. Click on a) "Wireless security" or b) "wireless settings".
6. There should be a page with a WEP key listed.
7. Write it down/copy
Thanks.
All the best.
Feb 14, 2011 | Belkin Computers & Internet
Installed Belkin Wireless USB adapter. Didn't
Connect with the Ethernet and maybe windows has an update driver for it.
Apr 08, 2010 | Computers & Internet
I keep losing the connection to my Linksys N router...why??
1.Primarily, if you use a N standard wireless router, you must go in for the same N standard adapter, to get full efficiency. You didn't mention the model no.
2.If you have any other wireless computer in your house, check with that if it also has the same issues. Try checking with new and old wireless devices.
3.If finally, you conclude that its only this Belkin adapter that is responsible for intermittent connection, then:
3a. Uninstall the Belkin adapter's utility and drivers from control panel(Add/Remove programs)
3b.Go to http://en-us-belkin.com/support and download the latest drivers for your model.
3c. Unplug the adapter and run the downloaded setup file. (Setup will walk you through from here)
But i could have helped you better if you had mentioned the model or part number along with the version of it.
Anyway, this would certainly work.
Jan 24, 2010 | Belkin N150 (F6D4050) 802.11g/b Wireless...
Connecting to the internet
  1. Start Menu
  2. Run
  3. cmd
  4. Ipconfig and check if your IP starts with 192.168... if so check the gatway if not you have to configure the router so it can give you an IP address
Jun 23, 2009 | Belkin (F5D7000) 802.11g/b Wireless...
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
BELKIN G WIRELESS PROBLEM
yea this doesnt work i tried it on my destop you have to uninstall belkin program then install it back then run the usb and dont do the setup wizard pain in the @$$ and it will say new hardware found click it and then use the belkin wireless program put in the ssid, how manny ghz its runnin and the wep if there is any
Jun 20, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin F5D7132: cannot open exe program
Windows Vista; belkin says it's compatible. install program downloads, but desktop shortcut does not appear. When I attempt to open the file, I get error message "IP802MR MFC application has stopped working." IP802MR is the name of that file.
Jun 17, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Belkin router not working with my xbox 360 console
You said you have a belkin router. Try using a linksys g router. Go and get a chapie for 45 bucks. I have a wireless b and it works like a charm. If it doesnt work, just simply return it, or call linksys customer support.
Mar 18, 2008 | Microsoft Xbox 360 Console
Belkin N1 Wireless USB 2.0 Network Adapter (S6359026) Logo
129 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
