Question about Canon EOS 400D / Rebel XTi Digital Camera
The flash pops up but doesnt work. than gives me a busy signal than gives me the 99 warning. it was dropped a short distance from my hands. just want to know what i can do myself. if anything
    Brigadier General:
  • 4,090 Answers
This error is usually assocociated with a dirty lens mount.. rub both lens mount terminals and camera terminals with a pencil eraser making sure nothing gets inside the works. and reassemble.
Other reports indicate it can also be the battery terminals.. do the same thing.
regarding the flash.. if the lens mounts are dirty ( or misaligned requiring repair) the flash will not flash.
Please rate my help++++Thanks for using FIXYA
Posted on Nov 29, 2009
Turn signals not working
all else on car works perfectly (other shoe drops??????)
waring 1: no scan tool, you will fail (99%)
is battery fully charged to 12.6vdc rested or at 10v?
all 4 corners dead?
not working means dead?, flashes too fast/slow or dim? or they stick on? (5 modes to fail not counting L/R and haz)
do the hazards work? (prime evidence and not stated)
most cars before 2007 have fuse marked TURN.
but not this car... its not at all like older cars....
did you scan it first after the fuse tests? any PCM scan tool.?
2009 WK jeep
the FSM chapter 8L shows the huge list of errors the lamps can fail. DTC errors.
in fact 8 blinker codes, ! DTC errors,
there is no fuse, just for turns, (trailer lamps fuse 19)
read this excerpt from the FSM book.
The turn signal system operates on battery current received on a fused ignition switch output (run) circuit so that the
turn signals will only operate with the ignition switch in the On position. The hazard warning system operates on
non-switched battery current received on a fused B(+) circuit so that the hazard warning remains operational regardless
of the ignition switch position. When the turn signal system is activated, the circuitry of the left multi-function
switch and the FCM will cause the selected (right or left) turn signal indicator, front park/turn signal lamp, front side
marker lamp and rear tail/stop/turn signal lamp to flash on and off. When the hazard warning system is activated,
the circuitry of the hazard warning switch and the FCM will cause both the right side and the left side turn signal
indicators, front park/turn signal lamps, front side marker lamps and rear tail/stop/turn signal lamps to flash on and
off. The Front Control Module (FCM) can also activate the hazard warning system lamps.
end quote)
the module front control MFC, runs this
and it uses fuse 18 , if 18 blows the module goes off line and vast things fail and huge numbers OF DTCs store.
and fuse 27 MFC
MFC needs these fuses good.
keep in mind nobody has MFC internal schematics...so........
this module drives left and right side front and rear.
electronic drivers, not fuses.
the MFC is here.
the fuses are 12,13,18, 20,27 that power MFC.
25812039-lb3yimx2pwhstnjl4tgwffiq-2-0.jpg ground this end.
Aug 07, 2015 | 2009 Jeep Grand Cherokee
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Flash pops but doesnt fire
Still this is strange. Most of the time when I use the auto setting, I turn the main dial not on the green camera, but on the one between SCENE and the green logo. That prevent the flash to pop up. But still if you want to use the flash it should be possible.
Be aware that some settings the flash can't be used, f.i. when the shutter speed is to high. I would suggest to put al user settings back to standard and try to use the flash again. If it stalls again, try to read the display, if it gives anything of a warning or message.
Jan 18, 2014 | Nikon D5100 Digital Camera with 1855mm...
I have canon 450 d i face the problem error 99 if i open flash it showing error 99 give me answer
error 99 means flash is stuck . pop the flash and when it clicks, you have to smack the side of the camera to make it pop open
Nov 23, 2010 | Canon EOS 40D Digital Camera
Canon 450D - Error 99 only when flash pops up
Flash Tube is bad inside the Flah head, tccamerarepair.com
Mar 08, 2017 | Canon EOS 450D Digital Camera
Canon rebel xt eos
Error 99 means lens communication error.
Try to clean the contacts on both sides.
and re-install lens
Jun 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Volumne on Akai LCT3285TA
Often a signal might experience a super-quick "drop" in signal strength, and the display is automatically adjusting the now weaker audio signal to "mono" (temporary, as for best quality). But the dropout is usually so brief you will then see the "stronger" signal restored [full strength], and now the audio is "stereo".
It's like a "bump" or "disturbance" that occasionally affects the cable/satellite/OTA (antennae) signal being fed into the TV, and your display's attempts to compensate for the weaker signal [going to mono, then back to stereo once back to full strength].
Connecting it to your cable directly (bypassing the box) or an antenna would give you a true over-the-air signal, which would be proper MTS and would not give you any more pop ups.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
I know what you two are talking about. I ordered a Canon EOS 300d from a site called "Keh" and I had never used one before... so I get it in the mail on time. The camera works fine for a few minutes then I get an "error 99" and can't do jack with the camera. I researched online and even called keh ... I read and heard that it has to do with the lens... so I sen't the camera back and got my money.
Nov 26, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
97 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
