Question about Canon CLC 1180 Copier
Paper trays on canon clc 1180 show A4 and Stmt sizes rather than Ltr and 11x17. How do I reset these paper tray readings
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Auto Paper Select option does not include a printer’s Manual Tray (Stack Bypass, etc.) in determining which feed tray to pull paper from. So you’ll need to open the paper drawer and detach the blue paper stopper by pushing it downwards and left. Now insert the stopper again at the A4R holes and unlock the top and front vertical lock and slide it to the A4R position and set the blue dial to A4R size.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 19, 2009
MF4350d 1page only
You must check the paper settings, Canon MF 4350d have two trays, the Cassete/Drawer & MP tray or (Multi-purpose tray).
Go to Paper Settings found the panel of the Printer, Set Cassete tray as A4 or LTR size & MP Tray as Long size or Foolscap(FLSP).
You must go to Start>Devices and printers>Right click the Printer>Printer Properties>Preperences>Page size change to Letter>Apply and press Ok..
Make sure that everytime you print,it will match the paper size you want to able to use,..
Jun 07, 2014 | Canon ImageCLASS MF4350d Laser All-in-One ...
Paper type for 8.5 x 11 paper was reset to A4. I want it to be LTR. How do I change back?
I would start with the easiest solution, look to see if there is any paper jammed behind the paper tray. There are switches behind the paper tray for paper size. Also, make sure the paper tray guides are in the correct position against the paper in the tray, they tell the copier the paper size. Good Luck
Oct 31, 2013 | Minolta bizhub 200 Copier
How can I found out the stats on a Canon NP 6551 (ie total pages, etc...)?
NP6560 Main Specifications
Main Unit
Type: Console
Platen: Stationary
Photoconductive material: Amorphous Silicon
Copying system: Electrostatic transfer system
Developing system: Toner projection system
Fixing system: Heat roller system
Acceptable copy stock: Paper drawer:17 to 24-lb bond (64 to 90 g/m2); plain paper
Stack bypass:17-lb bond to 110-lb index (64 to 200 g/m2); plain paper
(However, Keep in mind that the paper weight that can be used varies
depending on the type of the Sorter being used.
SADF tray : transparencies and labels
Acceptable originals: Sheets, books, and three-dimensional objects (up to 4.4-lb or 2 kg)
Maximum original size: 11" x 17"
Copy sizes: Paper drawer: STMT, STMTR, LTR, LTRR, LGL, and 11" x 17"
Stack bypass: 4 1/8" x 5 7/8" (horizontal placement) to 11" x 17"
Non-image areas: Leading edge: 1/4" (4.5 mm)
Left and right side: 1/16" (3 mm)
Trailing edge: 1/16" (2 mm)
Warm-up time: Approx. 6 minutes (at temp. of 68°F)
First copy time: Max. 2.8 seconds
[LTR size, direct copying, Manual Exposure Control, Drawer 1 (top
drawer) selected 1→1-sided mode]
Copy speed: Direct (100%) LTR 60 cpm
65 cpm (Accelerated mode)
LTRR 49 cpm
11"X 17" 30 cpm
LGL 40 cpm
STMT 60 cpm
STMTR 60 cpm
Reduction 11"x 17" → STMT 56 cpm (50%)
11"x 17" → LTR 48 cpm (64%)
11"x 17" → LGL 40 cpm (73%)
11"x 15" → LTR 48 cpm (73%)
LGL → LTR 49 cpm (78%)
Enlargement LGL → 11"x 17" 30 cpm (121%)
LTR → 11"x 17" 30 cpm (129%)
STMT → 11"x 17" 29 cpm (200%)
Magnification: Direct 1:1.000
Reduction 1:0.500 (11" x 17"→STMT)
1:0.647 (11" x 17"→LTR)
1:0.733 (11" x 17"→LGL/11" x 15"→LTR)
1:0.786 (LGL→LTR)
Enlargement 1:1.214 (LGL→11" x 17")
1:1.294 (LTR→11" x 17")
1:2.000 (STMT→11" x 17")
Zoom 1:0.490-1:2.040
7-8
Paper feeding system: Drawer 1, 2 (1,500 sheets x 2)
Drawer 3, 4 (550 sheets x 2)
Stack bypass (50 sheets; stack approx. 1/4" high)
Multiple copies: 1-999
Power source: 120 V, 60 Hz
Max. power consumption: Less than 2.0 kW
Dimensions (H x W x D): 46" x 25 3/8" x 28 1/2"
(1169 x 643 x 725 mm)
Installation Space (W x D): 40 5/8" x 28 1/2"
(1030 x 725 mm)
50 3/8" x 28 1/2" (1280 x 725 mm)
[With copy tray (option) attached and stack bypass auxiliary tray extended]
Weight: Approx. 462 lb (210 kg)
RDF (Standard equipment)
Originals: STMT to 11" x 17" size (STMT-size cannot be placed horizontally.)
Original tray: LTR 15-lb to 110-lb bond (52 to 200 g/m2)
11" x 17", LGL, LTRR, or STMT
15-lb to 32-lb bond (52 to 128 g/m2)
SADF tray: 11" x 17" to STMT
11-lb to 110-lb bond (38 to 200 g/m2)
Max. power consumption: 120 W
Original tray capacity: Original tray: 11" x 17" or LGL
50 sheets (20-lb bond or 80g/m2)
LTR, LTRR, or STMT
100 sheets (20-lb bond or 80g/m2)
1 sheet
Original replacement speed: 60 sheets/minute (LTR, horizontally placed)
Power supply: 24 V (supplied from main unit)
Dimensions (H x W x D): 6 7/8" x 25 3/8" x 21 1/4"
(174 x 643 x 539 mm)
Weight: Approx. 56.3 lb (25.5 kg)
These specifications are subject to change without notice.
8-1
ar
Energy Saver
Stop
Guide
Additional Functions
Start
Display Contrast
ii
Enter a ID number with the Number ( 1 - 0 )
keys.
MEMO: ? If you make a mistake entering an ID number, press
the C
Clear
key. Then, enter the ID number again.
? You cannot enter two identical ID numbers.
? If you enter and store "000000" in place of a current
ID number, that ID number is canceled.
? You can store up to 1,000 ID numbers.
Press the [OK] key.
If you want to store another ID number, repeat
steps 3 to 5.
5
After entering all the ID numbers to be stored,
press the ID key. The display returns to the ID
entry screen.
6
Canceling the ID Mode: Clearing All ID Numbers
If you clear all the ID numbers then you can make copies without having to enter an ID
number.
Press the Additional Functions , ID , Stop , and Additional Functions keys in that
1 order.
Clear
Guide
Interrupt
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
iii
Press the [OK] key.
MEMO: ? If you want to stop all the ID#s from being cleared,
press the [C] key.
Press the [CLEAR ALL ID#s] key.
Press the [STORE USER ID#] key, then press
the [OK] key.
All the ID#s are cleared.
If you press the [OK] key, you will return to the
Standard mode.
MEMO: ? Storing all the ID#s under "000000" will also clear all
the ID#s.
iv
In the ID mode, the copier keeps track of the copy quantity made under each ID number (up to
999,999). You can view the copy total for each ID number in the touch panel display.
1 order.
After pressing the [COPY TOTALS] key, press
2 the [OK] key.
Press the [?] or [?] key to check the copy totals
for a department. The copy totals can also be
displayed by entering the department number.
Press the Number keys ( 1 - 0 ) for a four digit
department number and it appears at the top of
the display. When you finish checking the copy
totals, press the [OK] key.
Copy Totals (Check Totals)
The following procedure describes how to clear the copy totals for all ID numbers to zero.
Copy Totals (Clear All Totals)
1 order.
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
v
2 the [OK] key.
Press the [CLEAR ALL TOTALS] key. 3
Press the [OK] key.
MEMO: ? To cancel clearing all totals, press the [C] key. 4
The copy totals for all ID numbers are cleared to
zero. If you press the [OK] key the display
requesting the entry of an ID number appears.
MEMO: ? You cannot clear the copy totals for ID numbers
individually.
Dec 21, 2010 | Canon NP 6551 Black and White Copier
Our Canon imageRUNNER 2270 is copy/printing sidways instead of normal. what happened?
I would look to make sure the paper tray's are set correctly in the paper trays... There is a knob that moves at will.... just kidding... Make sure that when you press on the diplay for paper size's, that if it shows LTR make sure the paper is in the tray going the short way.. LTR or you may have the paper tray set for LTR-R and you have the paper in the tray as LTR. I believe that the paper trays are set wrong. You may have figured it out already.. Good Luck
Nov 29, 2010 | Canon imageRUNNER 2270 Copier
I have an old Canon 1150 color copier. The bottom drawer #2 dropped and can't feed paper properly. So I put 11x17 paper in drawer #1 which had 8x10 paper originally. Now the panel still shows drawer #1...
Is there a paper selection wheel or bar in the tray?
Some of the older Canon models have a dial (usually in the lower right hand corner of the tray) or a slider bar (usually on the left hand side of the tray) when you open it. That has to be set properly or the machine has no idea what size paper is there.
Dec 03, 2009 | Canon CLC 1150 Color Copier
All trays have defaulted to A4 size
go to service mode (press *,2&8,*) then COPIER>OPTION>CST>P-SZ-C1 for right deck paper size, change the number 6 for A4,15 for B5,18 for LTR
COPIER>OPTION>CST>P-SZ-C2 for left deck paper size, change the number 6 for A4,15 for B5,18 for LTR
Feb 06, 2009 | Canon imageRUNNER 5000 Copier
Lexmark T632 says "Load MP Feeder Letter
Hi Pqpoppa,
Check the paper size setting in the printer. Set it to the paper size you normally use such as A4 and the default tray. Check the default paper size in the printer driver in your computer and the default tray. Finally, check the paper size of the document you are printing. If all these match, it should not try to be smart and ask you to feed paper.
Rgds
S88
Nov 03, 2008 | Lexmark T632 Laser Printer
Cannot reduce size from 11x17 to letter
The NP6551 is an analogue copier, using only mirrors and lenses. It has no way of rotating the image. If you want to reduce a 11x17 to a 8.5x11 both peices of paper need to be fed in the same direction, ie short edge first. Change one of your trays to LTR-R ('R' for Reduction) or feed the LTR paper in thru the bypass in the long direction. If you use te bypass you must specify the paper size as LTR-R, you cannot use FREE.
Jul 26, 2008 | Canon NP 6551 Black and White Copier
PAPER SIZE DETECTION ERROR
Are you tring to use a paper tray or the manual by pass tray?If you are tring to use a paper tray for more then one or more copiers, you are going to have to ask your service techs to change the setting of one of your paper trays to A4 in service mode. Or if that has been done, look behind the paper trays for a wade of paper blocking the size detect switchs behind the paper trays. Good Luck
Mar 03, 2008 | Canon CLC 1120 Color Copier
Canon iR5000 Tray 3 problem
look behind the tray and see if there is paper stuck behind the tray. Good luck
Dec 18, 2007 | Canon imageRUNNER 5000 Copier
Canon CLC 1180 Copier Logo
100 people viewed this question
old marine
old marine
