Question about Fuji FinePix S3100 Digital Camera
One day I was taking pictures just fine, then the next day the camera would not come on. I changed batteries...several sets...and chips. It just wont come on anymore. Help!
5 Suggested Answers
  • 188 Answers
SOURCE: Pictures are all white when using the flash
it seems that the shutter of your camera is having a problem with. normally whin it gets stucked fully open it creats such problem. you need a help of a repairer.
Posted on Nov 06, 2006
  • 3 Answers
SOURCE: won't take pictures
Clean contacts in battery compartment
Posted on Jul 03, 2007
  • 3 Answers
SOURCE: Button don't work
One of the buttons is constant presset in.
Under the button is a metal membrame, sometimes it happens by to mutch force the membrame is defect, it doesn't popup again.
Try to find out witch button doesn feal good anymore, can you work without it ?(for example left macro), open camera and remove membrame.
LKet it repait by fuiji ? a least € 100,-.more than new....
Posted on Nov 15, 2007
Tri3mast
  • 747 Answers
SOURCE: When I turn my camera on, the LCD doesn't light up
This might be your problem if the camera is functioning properly then you may have pushed the Disp/Back button in the lower left corner on the five way controller dial. Push the button and the display on the view screen will change.
Posted on Dec 23, 2010
Camera on and SD working - but not taking pictures
Check flash is not obscured by the case
Check AF is set to infinity or [set by range]
Ensure target is within AF zone...might be aiming too low in order for it to register movement.
Nov 22, 2013 | Moultrie MFH-DGS-200 Digital Camera
Wont take picture
Could you give some details? What make and model camera? Does it turn on at all? If it does turn on, what happens when you try to take a picture: nothing at all, an error message, or something else?
Apr 15, 2013 | Cameras
When I turn on my Canon PC 1130 to take a picture, the lcd screen and view finder just show a black screen. Camera is working fine in the play mode. Please help.
Set the camera in TV mode, (delayed shutter mode) set the shutter at 15 sec, click to take a picture and during that 15 secs (like, after 7 seconds) open the battery compartment which cuts contact with the battery circuit. Close the battery cover. At this point the camera works fine ... but only temporarily.... Here is the key to the permanent fix. While the camera is working via the temporary fix, take many, many pictures. Hundreds! I probably snapped 400-600 pics. The idea is to wear down the little patches of hardened oil on the shutter blades. For the next three days I took hundreds of pics each day. Basically, I just aimed the camera at the wall or whatever and snapped off several hundred pics.
Jan 05, 2011 | Canon Cameras
BROKEN FLASH
the chip set in your camera is damaged.you want to change it.
Aug 27, 2009 | Samsung NV10 Digital Camera
I Have a Nikon 5600 and it wont take pictures
Make sure you have either a fully charged batteries or a new batteries.
Could be some internal problems such as loose connections.
Camera sounds like it needs repair. Repair for this camera, due to age may be beyond what you would want to spend.
Jul 07, 2008 | Nikon Coolpix 5700 Digital Camera
Defintely getting power, but not switching on.
There are several possibilities. Let's start with the easiest two. First the battery, take it out and try starting up only with the power supply. Then the memory chips. If a memory chip fails it can cause a no start in IBM's. Take the memory out and try it. Then try it, putting them in one at a time. If these don't work, then I'm afraid your problem lies within. Namingly the power management chip on the motherboard. The pm chip controls the power input, and allows such functions as switching between battery and AC, and battery charging. The pm chip can go without warning, and just because it lights and shows charging doesn't mean this chip hasn't malfunctioned. I've had several IBM's come through my shop that have experienced the same problem you're describing. I've also had them with problems like; it will only power with the battery, won't charge the battery, will charge battery and only run with battery shuts down while charging, only power under AC, etc... all pm chip related issues. Unfortunately, the only solution is motherboard replacement.
Jun 19, 2008 | IBM ThinkPad T40 2373 Notebook
Polaroid Memory Chip problem
Hey ashley131,
One thing that might be happening is your SD card is set to the locked position on the side of your card. If this is not the case you could try opening the card by going to My Computer and right clicking on the memory card icon, then left click on open, and if it opens copy all the files shown and paste them into a folder of your choice, and then try opening the files using windows picture manager. If this doesn't work there are memory card recovery programs you should be able to use to recover your images just do an internet search for memory card recovery software. Once you have saved your images to your computer I would format your memory card in your camera, and the card should be able to be used again. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 27, 2008 | Cameras
HELP!!! PLEASE!!
I have had the same problem with my Polaroid camera also. I had it for just a few months and sent it it in while it was still under warranty. They then sent it back to me TWO months later telling me they could do nothing about it. They didn't fix it, send me a new one or anything. I see that several people have posted on the same problem and haven't got any resolutions. This is ridiculous!
Dec 10, 2007 | Polaroid i733LP Digital Camera
Trouble transferring pictures from camera to computer
First, Try and install the HP software again. Uninstall the software first and reboot the pc. Then reinstall software. The memory chip maybe have currupt pictures, so format the chip using the camera. You manual should tell you how to do this. Second, Turn the camera on and let the battery run all the way down. This may take some time, maybe a day. Then charge it back up for a day. I hope this helps you out. Let me know.
Jul 01, 2007 | HP Photosmart M415 Digital Camera
Fuji FinePix S3100 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
