Question about LG Shine CU720 Cellular Phone
Display screen does not work - LG Shine CU720 Cellular Phone
Acer laptop display goes off after some second
Try booting into safe mode. Chances are that you have set the screen resolution and refresh rate to some value that the LCD cannot handle. That is why it works until Windows takes over. Once you are in Safe Mode you can get things under control.
Jul 20, 2014 | Acer Computers & Internet
Screen will not load just white lines
Does external display work fine? If you have not checked, connect an external display like desktop monitor or a LED TV which has VGA connector to your laptop's vga port. You may have to use some fn keys combination to switch from laptop display to external. If external display works fine then check the display cable connecting laptop motherboard to laptop display. And also check laptop LCD/LED screen. You may have to try another with another screen in such scenario.
Sep 17, 2012 | Pavilion g7-1219wm Notebook PC
My Samsung cell phone screen is not working; it stays black when I open it. It's a Samsung U600. It still works with exception of the screen...
Hi,there are there kinds of black screen in phone,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage LCD the phone will detected,and thirdly, The flex of the phone.
The flex is connected to the screen and it makes the screen display,if the flex gets damaged it will make the screen display be affected.
i hope ,i will help you ,thanks for trusting fixya...
Sep 03, 2010 | Samsung Instinct Cell Phone
The display stopped working, Just a white blank screen. The phone still works but the screen does not. Can't see who is calling and can't retrieve pictures.
Hi,blank screen is usually caused by bad screen or flex depending on the type of phone you are using at the moment.
If the phone is a flex phone that means you will need to check both the screen and the flex.(flex makes the screen to display).
When you replace the screen,the phone display will be working again.
Have a nice day.
Sep 01, 2010 | Cell Phones
The computer boots but there's no display
check the display properties for dual monitor settings in
display properties>settings> check all options
I think it is set for external display u change to dual display. then both displays can work. or there is some display symbol of some function key. check that and press
Jun 17, 2010 | Acer Aspire One Netbook 8.9" Notebook
Dell 6000 laptop screen blanks out - bought new screen
ManualsBack to Contents Page
Display Assembly and Display LatchDell Inspiron™ 6000 Service Manual
Display Assembly
Display Bezel
Display Panel
Display Latch
Display AssemblyRemoving the Display AssemblyCAUTION: Before you perform the following procedures, see the safety instructions in the Product Information Guide.NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as the back panel) on the computer.NOTICE: To avoid damaging the system board, you must remove the main battery before you begin working inside the computer.
  1. Follow the instructions in "Preparing to Work Inside the Computer."
  2. Remove the hinge cover.
  3. Remove the keyboard.
  4. Open the display all the way (180 degrees) so that it lies flat against your work surface.
  5. Remove the four M2.5 x 5-mm screws (two on each side) that connect the display assembly to the computer.
  6. Loosen the screw that connects the grounding wire to the system board.
  7. Use the pull-tab to disconnect the display cable from the system board.
  8. If a wireless Mini PCI card is installed, disconnect the antenna cables from the card.
  9. Lift the display assembly from the computer.
Apr 06, 2009 | Dell Inspiron 6000 Notebook
Finepix f50fd camera working bar cracked screen.
Thank you for your reply. Since using the F50fd doesn't make any sense without the display screen, I need to hope that the problem your camera has really concerns the display screen and not any other electronic components (e.g. display drivers). Also, I need to hope that my working screen will be compatible to your camera - something Fuji easily could have tried to impede.
Why is your screen actually cracked? What happened?
Mar 30, 2008 | Fuji Finepix F50FD Digital Camera
Internal screen is white
NO YOUR DISPLAY IS DAMAGED YOU HAVE TO CHANGE UR PHONS DISPLAY AND IT WILL WORK EVEN CHANGING THE DISPLAY IF IT DONT WORK CHECK THE DISPLAY CONNECTOR.
Nov 23, 2007 | Motorola Mobility E815
LG Shine CU720 Cellular Phone Logo
22 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
