Question about Nokia 5630 XpressMusic Smartphone
I have it a week and sometimes its turn off and afther that i can't start it.
Spaform hot tub manual
check the timer or may need to reset the cycle on it..(reprogram the controller)
Jan 09, 2014 | Pool & Spa
Hi.I just got Ducati monster 620 sie 2002 it was running great I used shell 95 and problem start no power when you riding, I empty the thank afther 100 km and used caltex 95 octane afther one thank change...
Changing fuel brands is unlikely fix anything.
Perhaps you got some contaminated fuel when the problem first happened, if this is so it will probably need a fuel filter
Aug 06, 2011 | Ducati Monster 620s i.e Motorcycles
Turns over will not start. put in stp injector cleaner and the day afther it died. i replaced the fuel filter and distirbutor and rotor, plugs and wires. ??????
You need to verify what is missing, why it won't start...
do you have spark?
Do you have compression on all cylinders?
Do you have fuel pressure?
Do you have fuel injector pulse?
Aug 02, 2011 | 1997 GMC Sierra
1994 acura integra
check all your relays and fuses
Apr 15, 2010 | 1994 Acura Integra
HONDA VTX 1800c 2002 no ignition afther accident
There could be a "tilt" switch on the bike. Usually they are in the speedometer. This kills the ignition to the bike should it be dropped while riding. I don't know if it can be reset. Local dealer may can help.
Sep 27, 2009 | 2002 Honda VTX
The car runs ok for one or two days ,then afther being parked for some hours it wont start, it cranks and have spark ,but wont run,then afther six or more hours it will run again,the ceck engine light...
Had one of these drive me crazy. That one was the fuel pump. Pumped OK, but let the pressure back into the tank and let air into the fuel rail. Once engine had cooled,the pump purged the air out of system. Have someone check the fuel pressure when it does not start. If check valve is bad,there will be lots of air in the fuel rail. Second most likely cause is crank sensor going bad.It becomes heat sensitive on the way out.
Jul 24, 2009 | 1994 Toyota Camry
Please help
could be a problem with the battery, power adapter, memory or motherboard. Remove the battery and try turning on the computer with just the power adapter. If no go, test another power adapter. try another battery. Reseat the memory modules, or try using other working memory modules. You may also check this HP support site: http://tinyurl.com/dn44m2
Feb 01, 2009 | HP Compaq nc6000 Notebook
05/55 s60 d5 185. whirring from under bonnet
Hi, this noise is usualy caused by dry belts afther engine been washed or driving in the rain , you can buy a belt dressing spray at many auto parts ,spray all belts lightly ,repeat if nessesary until noise is gone....C1
Jan 04, 2009 | 2005 Volvo S60
Nokia 5630 XpressMusic Smartphone Logo
82 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
