Question about Fantom Vacums FM741 Twister Bagless Upright Vacuum
Need new roller brush ***. and belts FM741B - Fantom Vacums FM741 Twister Bagless Upright Vacuum
How do I fix my vacuum the brush will not spin
Lubricate each end of the roller brush with motor oil. Bearings inside the roller brush need lubrication for the brush to turn easily. Remove any pieces of thread that have wrapped around the roller brush. If it does not spin after doing the above steps, then either the belt is slipping or the bearings are severely damaged in the roller brush. Then you need either a smaller belt or a new roller brush.
Apr 26, 2015 | Dirt Devil UD40270RM Quick Power Compact...
Belt
Look underneath where the brush roller is located. The brush roller is removed to replace the belt. The new belt is installed on the motor shaft and the brush roller then the brush roller is reinstalled
Jul 27, 2013 | Eureka Whirlwind 4481 Upright Vacuum
Vax 2300
If the roller brush cannot be rotated easily by hand, it is likely that debris is jammed inside the end caps.Make note of the direction arrows on the end caps as you remove the roller brush. You will need to know this for reinstallation. The end caps are fastened with stop nuts. Removal of one will allow the inner shaft to be extracted for examination and cleaning. An old toothbrush is a good cleaning tool. Reinstall the inner shaft and stop nut. Check for free rotation of the brush roller. Place a new belt over the brush roller and reinstall the brush roller, being careful to observe the position of the arrows on the end caps. Inspect the motor shaft and remove any old belt residue before installing the new belt on the shaft.
Jun 30, 2013 | Vacuums
Replace belt on hoover vacuum U4655
Turn the machine over and remove the 4 screws which hold the cover on the brush. Remove the cover and brush roller. Remove old belt. Slide new belt over the motor pulley, first. Then slide roller through new belt (if self propelled model, slide roller through the small belt, also) and slide brush roller into slots on housing (note: slots are different, match roller sides to correct slot.)
Oct 22, 2011 | Hoover Vacuums
How to change belt on eureka whirlwind; what tool do I need
You will first need to remove the hood to gain access to the belt and brush roller. Turn the machine upside down, place the handle on the floor and the base on a counter. You will find several screws that hold on the hood, remove them. Turn the machine back to the upright position and remove the hood. On the right hand side,if your looking the front you will find where the belt goes. At the back you will find a silver shaft sticking out, put the new belt on there first. Then put the brush roller through the belt so it is in the carved out section of the brush roller. Then grab the brush roller by each end and stretch the belt till the brush roller fits back into the base. Turn the brush roller 3 compleat turns backwards and 3 forward to seat the belt in the proper position.
Then put back on the hood.
May 08, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
When machine is running the brush does not turn
You need a new belt. In order to change it, turn the machine compleatly upside down and place the head on a counter, handle on the floor.
There is a L shaped base plate to remove that has 5 screws in. Once the base plate is off, you see the brush roller and a silver shaft directly back from where the belt would ride. Remove the brush roller, place the new belt, Dirt Devil Style 5 ( see link below ) on to the shaft. Then insert the brush roller, so the belt is on the raised carved out section of the brush roller. Grab the brush roller at each end and stretch it till you are able to put the brush roller back into the base. Turn the brush roller backwards 3 compleat turns and the same forward to seat the belt.
Replace the base plate and you're done.
Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001 - Free Shipping Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001
Cost $ 8.00
Apr 28, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Vaccum not turning or sucking
It definitely sounds like your belt is broken. If something gets vacuumed up into the brushes, and prevents the brushes from spinning, the motor will continue to try and spin the belt and the brush, but since the brushes can't spin, this will burn right through most belts.
Especially since you mentioned a sock being sucked up, and the roller brush not spinning, this is a tell tale sign of your belt needing replacing.
Here's what you'll need to complete this repair:
- Phillips Head Screw Driver
- Hoover Windtunnel Replacement Belt, Non-Self Propelled, Hoover Part # 38528033
- Depending on how long the sock was stuck in the brush, you may need a new roller brush as well. The roller brush for your model is Hoover Part # 48414110. Here's a direct link for the roller brush for your vacuum on our website:
http://www.govacuum.com/generic-hoover-windtunnel-tempo-fusion-upright-12-inch-replacement-roller-brush-hoover-part-number-4.html
If you have the Hoover Tempo Widepath vacuum that you listed the repair under, then here's a direct link back to our website, govacuum dot com, to the exact belt for your Hoover Tempo:
http://www.govacuum.com/agbelhoovpar9.html
Now, once you have a new belt, this repair is pretty straight forward. I'll explain step by step what you'll need to do to change the belt.
Step 1. Make sure your vacuum cleaner is unplugged. The easiest way to change the belt in your vacuum is to turn the machine upside down, so the handle is on the ground holding it up, then lean the vacuum over a counter top or work bench.
Step 2. Remove the bottom plate of your vacuum cleaner. You'll see on the bottom of the vacuum 4 screws that are located on each corner of the brush, remove all 4 screws, and lift up on the bottom plate that covers the roller brush.
Step 3. After removing the bottom plate, you should now be able to access the roller brush completely, and you'll probably also notice that the belt on the right side of the roller brush is broken. You may just remove the broken belt completely and throw it away. Lift straight up on the roller brush itself to remove it from the vacuum.
Step 4. Test the roller brush. After something gets stuck in the brushes, and it causes the belt to burn, there's also a good possibility that your roller brush may need replacing as well. Also the roller brush will wear down over time, and the brushes will wear down as well, greatly reducing the cleaning ability of your vacuum. You'll want to test your roller brush, to ensure that it spins freely. If it doesn't, then as you install the new belt, it's possible it could also break immediately. To test the roller brush, remove it completely from the vacuum. Holding just the end caps of the bar with your fingertips, try to spin the brush in your hands using your thumbs. This is how it should look when you test your brush (the roller brush is to a different machine, but testing it will work the same):
The roller brush should spin at least 3 or 4 times in your hands on each spin. If the brush will not spin at all, or you feel some resistance when spinning it, then you'll probably want to go ahead and replace the roller brush as well at this point.
Step 5. Once you have your new belt, and new roller brush (if needed), it's time to install them. First wrap one side of the belt over the metal motor pulley in the back of the vacuum, opposite the roller brush. Now after you have one side of the belt wrapped around this metal pin, put the roller brush through the other end of the belt. Using the roller brush as leverage, stretch the belt with the roller brush inside of it back into the roller brush tray. You'll notice that on the left bearing cap on the end of the roller brush, there's a little rectangular shaped notch. Make sure that the rectangular notch is vertical, and slide this end into the agitator housing first, then fit the other side (circular notch) into the housing. With a little bit of elbow grease, you'll be able to stretch the brush with the belt back into place.
Step 6. Test the belt and the brush before putting the bottom plate back on. To make sure that belt and brush are properly installed, pull the belt forward towards the brush, and make sure that the brush spins while you're pulling the belt. If the brush does not spin, then either the belt is pinched underneath of the roller brush, or the brush is bad / installed incorrectly. Make sure that the brush spins freely before reinstalling the bottom the plate, otherwise the belt will burn and break again as soon as you turn on the vacuum.
Step 7. Reinstall the bottom plate, and screw down the four screws. Now you can turn the vacuum on, and make sure that the brush is spinning. If the brush is not spinning, repeat the steps above to make sure that the belt and brush were put in correctly.
That should fix your problem. Ideally you should change your belt at least once a year. Even if the belt doesn't break, it will stretch out. When the belt is stretched out, it will not pick up as well as a new belt will.
If you have any problems, or questions about how to do it, please feel free to use the Clarification Request here on the Fixya repair page, and I'll be more then happy to answer any follow questions for you.
Here's a link to the owners manual for your model that will also give you diagrammed pictures of how to replace your belt.
http://www.hoover.com/pdfs/manuals/U5140900.pdf
If you found this repair helpful, please be sure to rate this repair helpful by clicking the thumbs up icons. This small token of appreciation keeps Fixya repair experts continue posting free repairs to help the community. Thank you very much, that's greatly appreciated.
Chris J.
GoVacuum
Apr 07, 2010 | Hoover Tempo Widepath Upright Vacuum -...
The vacuum cleaning brush is not spending
Yes belt probably broken. Also the brush roller heats up on the ends, causing the plastic end cap nearest the belt to melt/weld to the end. It's supposed to spin freely. Also 2 bearings inside tend to become sticky, probably from heat. Next thing you know, the brush roller is seized and will not turn. Probably the whole reason the belt breaks. New belt & new brush roller, 30-35 bucks. It will happen again. Now you've spent almost half what it costs new. Lose the junk. 2 years for a cheap vacuum is the normal life span anyhow.
Dec 10, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
My purple and red Dyson has become hard to push. Could a belt have broken?
It's simple to tell if a belt has broken. Just switch the machine on and have a look (look, don't feel) to see if the brush roller is rotating. If it is, then the belt is not broken.
Depending on how much use your machine has had, it's quite likely that the brushes on the brush roller are worn to the point where you need a new brush roller.  Most vacuum cleaners rely on rotation of the brush roller to pull them along, so if the bristles are too short this doesn't happen.
I hope this helps. Please remember to rate this response.
Mar 11, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Putting on a belt on a vacuum
Greetings from GoVacuum.com,
Replacing a Belt on an Upright vacuum can vary from model to model, but it is basically going to be the same for most upright models.
First you will need to access the belt. Most upright vacuums this is done by turning the machine upside down, and most you'll need to remove the bottom plate by unscrewing (usually 4) screws that hold the plate on. You should see screws that are closest to the actual roller brush, simply remove these screws, and take the bottom plate off. If the machine is a Eureka, or Kenmore, the top agitator housing will be removed from the top of the vacuum, not the bottom.
Once you have removed the bottom plate, or top agitator housing, you should be able to see the belt (or broken belt) along with the roller brush. Remove the broken belt. Make sure that you purchase the correct belt by taking the make, and the model number (located on the back or bottom of the machine). Please note that a broken belt may be 4-5 inches longer then a new belt, as they stretch a lot before they finally break.
Once you have the new belt, you will need to remove the roller brush. Pay attention to how the roller brush fits into the agitator housing, usually there will be fittings on the end of the roller that have to be put in a specific place, or in a certain way to work right. After the roller brush is taken out of the machine, you will need to wrap one end of the belt around a metal pulley on the opposite side of the roller brush. Most pulleys are located where the main housing (handle part) of the vacuum meet the the agitator (floor part) part of the machine. Anyways, wrap one end of the belt around the pulley, and then put the roller brush through the other end of the belt. This is where you'll need to put some elbow grease into it. You'll need to stretch the roller brush and belt so that the brush and belt are stretched back to the place where you took the roller brush out of the vacuum.
Once you have replaced the roller brush with a new belt around it, pull the belt a few times to make sure that the brush spins while you are pulling it, to ensure that the belt is not pinched, and is spinning freely.
I hope this helps. Here's a video showing how to replace the belt on a Hoover Windtunnel Self Propelled model; Feel free to email me if you'd like to send me the model number of your vacuum, this way I can be a little more specific, and give you part numbers. I have all belts for all vacuums in stock. Email; chris.jones@govacuum.com. 1-866-468-2288. You may also chat with me by going to our website, www.govacuum.com, and clicking in the top right part of the page. Thanks!
Oct 11, 2008 | Vacuums
Fantom Vacums FM741 Twister Bagless Upright Vacuum Logo
43 people viewed this question
Top Fantom Vacums Vacuums Experts
woodzowl307
ray gallant
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
