Question about Motorola Mobility I315 Cellular Phone
I want to speak to all radio users at the same time via mike phone how do i do this?
Why does the channel change when I key the mike?
wrong mike is plugged to radio , many radios have the option to change the channels via two buttons on mike , unfortunately the mike connectors are pretty standard so they all hook right in easy , but that doesn't mean it's making the right connections inside , a good radio shop (there are still a few around if you look 4 them) will be able to rewire your mike to work on that radio if that's what u want to run
Dec 01, 2015 | Radio Communications
Cb troubleshooting
Sounds Like a wire is broken on the mic connector. Disassemble the microphone plug and check the connections. Also There is a relay inside the 139XLR that is quite old by now and could possibly be worn out or dirty.
Jul 04, 2014 | Radio Communications
HOw to VOX
If you are following the instructions and still it seems not to work, perhaps you are not talking loudly enough above the threshold trigger level and you need to speak up or speak closer to the mike.. If that doesn't work. Have the sets looked at.
Mar 30, 2014 | Midland LXT80 Two Way Radio
How do i get the radio back to factory settings
In order to Get the RADIO back to factory default settings,all you have to do is,If you have a NEW RADIO,read it,by using the software/programming cable,and write it in your old radio,
Thank you,
Jack
Jan 27, 2013 | Radio Communications
FT-890AT yaesu transceiver has distorted transmit audio
Hi Ronald,
Could the problem be related by having the mike to close to your mouth? This is the most common cause of over-modulation/ distortion from the transmission end.
If you have the mike 3-6 inches from the mouth and speak in an even non loud tone, that would help sort that out. If this is not the source of the over modulation/distortion, then you may have a transmitter issue, which would require the unit to be serviced by a qualified radio technician or ham radio operator, if you know one willing to look at it for you.
I hope that this has helped you.
Cheers,
Peter
Dec 01, 2012 | Radio Communications
Everytime i try to speak to someone they here a screeching noise at there end and cant make out what im saying, but i can here them ok at my end, ive changed mics so i no its not that, would it be my ariel...
Make sure that you are both on FM or USB If the modulation is not the same then you have a bad communication. If you hit the mike and they get a santia 9+ then the arial cannot be the issue
I assume that you have tested it with a mike that was supplied with the cb?
good luck
rene
Jun 08, 2011 | Cobra 29 LTD CB Radio
I can only speak to someone when my phone is on speaker. as soon as i take it off speaker the person cannot hear me and i cannot hear them
Hi Friend,
The problem is with the Mike in the Phone,you have to Change the mike.Once you have changed the mike the problem will be getting fine
Regards,
Ayyasam
Mar 28, 2010 | RIM BlackBerry Pearl 8100
No one can hear me on my phone Speaker Problem??? Any ideas???
Hi Friend,
You can hear what they are speaking but you they can't hear you,
The problem is with your mike which you are speaking to them,if you change the mike you can get the solution.This can be changed in near by mobile authorized service centers.
Check and revert back
Regards,
Ayyasam
Jun 25, 2009 | Nokia 1100
Modulation
have you happened to check the cable to your antennas? maybe you got a cut in the insulation. thats the only idea i can come up with being that you have had all the work done to it and still havin problems.
Oct 18, 2008 | Radio Communications
Galaxy DX99V
The RK56 was a good mike until Telex bought out Turner many years ago. Now the audio output is lower than it used to be & it's not a compatibility issue as Galaxy radios have microphone amplifier circuits similar to most other CB & 10-Meter radios. You'd have been better off buying an Astatic 636L or even a generic noise-cancelling mike instead. The only thing I can recommend is to hold the mike on your cheek, close to but not directly in front of your mouth, with the grille facing it & speak in a louder than usual voice.
Sep 24, 2008 | Radio Communications
Motorola Mobility I315 Cellular Phone Logo
19 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
