Question about Panasonic TH-42PX6U Plasma TV
We cannot control the volume or channels on the tv or the remote. Only the on/off switch works. When we turn it off, the red light flashes 20 times.
  • Panasonic Master
  • 19,396 Answers
Hi.
the TV goes in standby and does not wake up, because the control board is sending TV on protect mode after detecting a fault.
When this happens higher voltages from psu get shut down to prevent further damage.
20 Blinks is not an error code, but I will do some more research on this.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Nov 19, 2009
Code required to programe sky remote control for murphy 42884t2lcd
Hello
Three digit remote code with Sky with Murphy TV are:
132 244 191 502 100
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note:
In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press TV followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Sep 21, 2011 | Televison & Video
I have a Humax LU23 TD2 television and have now got Sky tv. I would like to know how to use the Sky remote to control all the functions such as power on, volume etc. for the tv. Can you help...
Hello
These are the setup processes for Sky TV.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 28, 2011 | Televison & Video
Hi need code for sky remote for sony kdl402530
Hello
Sky remote codes to check with Sony are:
533 038 039 064 102 130 505
679
505
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4* Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5* Point the Sky+ remote control at the TV and try the volume button.
OK.
Aug 25, 2011 | Televison & Video
Can't find sky remote code for grundig gu37fhd1080
Hello
Sky remote codes for Grundig are:
563 582 515 098 584 219 104 233 223 065 471
Aug 20, 2011 | Televison & Video
I need a code for my sky remote for my Onn T.V model number TL2638-TP
Hello
Sky remote codes for Onwa Tv are:
246 399 461 609
OK.
Jul 25, 2011 | Televison & Video
Sky remote control code needed for lg tv - model 37lk450
Hello
Setup codes for LG TV with Sky remote are:
065 244 405 318 037 398 191 459 245 389 060 275
065
742
743
726
508
584
1*Select any channel on the TV.
2*Point your Sky+ remote control away from the TV and press the tv button.
3*Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
5. Point the Sky+ remote control at the TV and try the volume button. If this works try the other TV functions.
Please note:- in der to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
Jul 16, 2011 | Televison & Video
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control.
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
6EDEH
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
100 000 0
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Sep 14, 2009 | Aiwa TV-S2011 20"
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Remote problems
This is the preferred method of code searching our technicians use.
1. TV on.
2. On your Dish Network remote PRESS AND HOLD the small clear tv button until all buttons across the top of the remote light up and release.The only button lit should be the clear tv button that will be flashing.
3. Press the small red tv button next to the power button and release it. This should leave the clear tv button that was flashing lit solid.
4. Now slowly depress the channel up key until the tv turns off.Each time the up channel button is depressed the clear tv button will cease being lit and once it is released the clear tv button should remain solid. If the clear tv button flashes multiple times it usually means there is no known code for your tv, there may be another code that will work so continue on.
5. Once you are successful in getting the TV turned off press the channel down button once and then the channel up button. This should turn the TV back on.
6.Press the # key button on the remote. The clear tv button should flash three times then press the record button and try the volume up/down and the small red tv button. You should be able to turn volume up and down and turn tv on /off. If only one of these function it means that you have only found a half code and need to try the process again. Not all TV's have full codes or any codes at all especially combo units.
I hope this helps you and thanks for using Fix Ya.
Dec 01, 2008 | DISH Network IR Remote Control
Can u help?
1. TV on.
This is the easier of the two methods as it sometimes will find codes that will work but are not listed. If you prefer to try the method of entering in the code numbers for your TV I gladly get them for you however I will need to know the brand of tv and if it is a combo DVD or VHS model, your receiver type, and the remote type which can be found on the back of thew remote. I hope this assists you and thank you for using Fix Ya. Let me know if I can be of further assistance.
Oct 09, 2008 | DISH Network IR Remote Control
Panasonic TH-42PX6U Plasma TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
