Question about Cameras
Fujifilm 7000 camera turns on, but view lens will not focus correctly. Jumbled picture.
  • Cameras Master
  • 19,396 Answers
Hi.
If the lens are not focusing correctly, and the camera goes properly out of focus, then that is a lens error. It can caused by a faulty motor, a mechanical problem or a defective control board.
If instead you get a completely jumbled picture, made of shadowed blurred images, then you have a faulty CCD sensor.
CCD sensor is the part that captures light to generate the digital picture.
In both situations the camera must be disassembled and fixed by a technician.
Call Fuji at the number listed on the owner manual and ask a quote on repair.
If the problem is the CCD sensor, point out that you did not do any improper use of the camera, in some case the customer service may acknowledge that this is a factory defect and cover part of the repair cost.
Regards.
Posted on Nov 19, 2009
Can anyone tell me how to remove lens from fujifilm hs 20
You can't remove the lens of your not so cheap bridge camera.
If you want to clean the lens, it really needs to stay on. After removing anything on or from this lens, you need at least a collimator, to align the lens elements. If not it won't be able to focus and could give lots or other errors in the pictures, like colour blur, aberration and out of focus parts.
Jan 14, 2015 | FUJIFILM HS20 EXR Digital Camera
Aoutofocus stopped working
Please remove the battery and and then insert it again and test to automatically reset the setting.
melnavz
Oct 13, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Will not take picture
If the view finder is dim it is likely the iris of the lens is stuck and cannot acquire correct lighting. It need to be repaired by disassembling the lens.
Feb 10, 2013 | Nikon D100 Digital Camera
Dark, cloudy viewing 35-135mm Sigma lens
The problem sounds like the camera did not reset properly after the last exposure. Minolta deigned the camera to keep the aperture fully open except during exposure.
During exposure it snaps the aperture down to the selected opening, then opens it again to allow enough light for proper focusing. If it did not fully open the blades after the shot, much less light would pass through the lens. The viewfinder would be darker and look murky.
Most likely cause? Dried up lubricants in the camera.
Next likely cause? Teeth broken on a plastic gear.
Get it to a camera repair place. Get estimates first.
Dec 30, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Video picture is not clear on webcam. Picture is not focused. How do I correct the blurred image seen by the webcam?
Most web cams have a short focal range, (Nearest to furthest focused content), and have a front lens that turns like a dial so you can choose where you want your camera to focus.
Try Twisiting the housing or ring around the front lens, if it turns then turn it while viewing the image on the computer to set the focus where you like.
Also make shure there are NO smudges on the lens, it's small so even the tinyest smudge or spec is huge on the screen.
Jun 18, 2009 | Philips SPC230NC Webcam
Out of focus pictures on FinePix 50fd
Your lens is stuck, you have two years warranty on this camera, ask your Fujifilm dept in your country or look at the fujifilm support pages.
Regards.
Rob
Apr 16, 2009 | Fuji Finepix F50FD Digital Camera
Minolta maxxum 7000 troubleshoot camera wont take pictures
There are several possible reasons, it could be the body or the lens. Check the shutter blades without film. Are they smooth and in place, (flat)? It could also be related to the film, a mis-load of the roll. The lens could have some failure, possibly try another.
Jun 14, 2008 | Minolta Maxxum 7000 35mm SLR Camera
FOCUS ERROR
I also had this problem. When starting the focus error alert came. Trying to move the focus button also triggered this. When I turned it off, the lens did not pull back.After being close to trowing it away, I used a little bit more force than before and turned the lens manually. I heard a click, and than it worked again. PS: Follow this tip on your own risk.....
Mar 11, 2008 | Fuji FinePix F410 Digital Camera
Cameras Logo
37 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
