Question about Poulan Garden
I hve a Poulon wildthing and I am geting no spark . It is about 4 yrs. old and I cut about 2 cords of wood a year. This year it started . then quit, to start no more. Now it refuses to start.... no spark. Naturally, I trie3d a new plug and fresh gas. How now brown cow?
    President:
  • 2,220 Answers
You don't provide a model number. Wildthings come in various engine sizes and configurations. Given your description it is almost certainly a bad coil, but might also be a defective switch or interconnecting wiring. Try this first: It tests all parts.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
Still no spark, coil is bad. You can find an IPL (Exploded Parts List) for your saw here: (LE is code for Wildthing)
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
The one I chose 1 at random follows:
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
"Engine Assembly Type 2" detail page, item 8, pn 530039198, $24.14 each. This may not be your saw!!!
HTH
Lou
Posted on Nov 19, 2009
  • dontbother10
    dontbother10 Nov 19, 2009
    If you replace the coil, an index or business is a good gapping tool. Rotate the flywheel until the magnets pinch your gap tool. Tighten all screws and rotate the flywheel to ensure nothing hits or drags. Lou
I have a poulan 2375 wildthing it sat for 2 yrs primer ball went bad. replaced it. it is getting fuel and has compression but spark seems weak and it will not start
Get a can of Nulon starter fluid and spray in the carby or a bit down the plug hole,it,s probably dried out.the Nulon is called Start you ?????.The spark appears weak on those machines ,that's normal.
Oct 01, 2016 | Poulan Garden
Victa2stroke cuts out after about 4 minutes of cutting grass
check the carb is clean and the spark plug is in good condition, also the air filters block up quite easily on those so remove it and blow it out. of course being a 2 stroke it could be that the piston /rings are scored up but you would need to remove the exhaust to inspect.
Feb 26, 2015 | Garden
Saw quits after cutting wood for about 5 minutes
Are you sure you have the correct amount of 2-stroke oil mixed in the gas? It sounds like it is overheating. Also check the engine to make sure the fins aren't clogged with wood shavings.
Mar 29, 2014 | Poulan PP3516
Poulan 18" wildthing chainsaw wont start
have you tried spraying Starter fluid into the Carb to see if it will at least try to run and verify you have good spark?
Dec 05, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Engine is stalling
Hi Chris, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below and good luck:
Harley Diagnostic Codes 04 to Present
Sep 04, 2012 | 2005 Harley Davidson FLHTCUI Electra Glide...
Need to thread the cord on a poulon 031pro
Remove the side coverto get to reel Remove any broken cord. Turn reecounter clockwise till it nestops then slowly let turn back till the hole li nes up then use a c clamp to hold the reel. Feed the cord through hole about 3 to 4 inches and tie a double knot in cord. Release c clamp very slowly to take up cord. Measure old cord if possible and subtract about 1 half inch cut it and thread it through the handle. replace the side cover.
Apr 30, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Have an old Home Lite chainsaw not used since before I had it running when I had some woods to cut a long time ago. The chainsaw (over 25 years old) won''t start when I try....not sure if it just needs a...
Replace the fuel filter, fuel lines, primer button (if equipped), and disassemble the carburetor, clean, and re-kit. Jet needles are preset at 1-1/2 turns CCW from stops (lightly). Make sure the spark plug fires a snappy blue spark when pulled through. If nothing, ignition parts prices and availability may justify replacing the saw with a new one. If sparks ok, start the engine and let warm up. Open the throttle and adjust H needle CW till the engine speeds up, but still 4-strokes. Proper setting is when the engine will 4-stroke, but immediately 2-stroke when cutting. Let the engine idle and adjust L CW so that the engine idles fairly well, but allows the engine to 'follow the throttle' Hope this helps!
Apr 17, 2010 | Garden
Having hard time with new poulon 18" chainsaw starting.
Since you have good spark and good gas the only things left to check are the air filter and the carbeurator. If the air filter is dirty, replace it. While you are at the auto parts store also pick up a can of a gasoline additive called seafoam which will keep your carb. clean. Finally get a can of spray carb. cleaner and put a couple short squirts directly into the air intake which is right there when you remove the air filter.
May 20, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Remington electric chain saw 3.5 -14''
I just had my Rem. EL-8 (Mod#107624-02, 3 HP 11.5Amp) quit, too. It was less than 2yrs old, had very low hours and no abuse. I pulled it apart and found that a motor brush was burned out (at the brush electrical lead; the braided wire connecting to the winding). Unfortunately, I checked with Master Distributors (http://www.nbmc.com/ ) and the brush assembly is no longer available. (For a less than 2-year old saw!!) They do have some parts for Remington saws, however.
Premature burnout seems to be a function of some combination of:
- using a too-light gauge extension cord for the amperage of your tool / length of extension. You can find recommendations for proper minimum gauge on the web. (This shouldn't have been the problem in my case because I used a 12-ga. 25' extension.) See: http://www.askthebuilder.com/B174_Extension_Cord_Size_Chart.shtml
- running too hard (big wood) for too long. I admit this seems pretty subjective; if the saw is cutting, why quit, right? But it's probably important to ease up and not let it get too hot.
- poor saw design. (internal parts don't match the power/amperage involved.)
~Roger
Nov 17, 2008 | Remington Electric Chain Saw
Garden Logo
209 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
