Question about Brother HL-5240 Laser Printer
New toner, starts, but STATUS button lights red and toner orange light comes on
    Genius:
  • 1,011 Answers
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Nov 19, 2009
What are the steps to reset toner lights for Brother HL 2240
Try this Toner reset sequence (worked on Brother HL-5350DN)
With Printer off open the toner door
Hold the Go button as you turn the printer on.
All lights will turn on. Keep holding Go until status light goes off.
Press the Go button 2x.
The Paper, Drum & Toner light will come on
Press Go 6x
Status light will turn red
Close the front.
Jul 02, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
After printing several hundred sheets, status light went red. There was no paper jam. Let printer "cool down" overnight. Status light still red. Drum has never been replaced. Toner light is on. However, in...
Well, if the toner light is on, you're probably out of toner and the only reason it ran, was because it was low but not completely depleted.
Try new toner drum off of Ebay or Amazon for the best prices for your brother printer.
Jul 05, 2010 | Brother HL 5140 Laser Printer
Brother 5250dn and all light are blinking
That series of lights indicates a main circuit board failure. You will need a shop to replace the main logic PCB. Could be caused by anything, static shock, bad input power from power strip or power failure, just plain CPU failure. If it's under warranty, 1 year since purchase, you need a Brother service center, out of warranty a new printer would cost less than repair.
Feb 02, 2010 | Brother HL 5250DN Laser Printer
My Brother HL5250DN shows toner light on (yellow) and status light on (red) even after toner cartridge replaced with new one. Already tried reset by holding down go button. Is the printer dead?
Try this..
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Oct 07, 2009 | Brother HL 5250DN Laser Printer
Drum and error light are on - got new cartridge - installed as directed - blue light will not stay on - printer will not print - red and orange lights will not go out
I can't recall the buttons on Brother laser printers but leaving the cartridge door open and pressing and holding down one of the buttons for about 5 seconds will clear the drum light error.
I've done this to clear the same error on aBrother HL5250DN laser printer.
If this doesn't work please post your printer's model number.
Sep 21, 2009 | Brother HL 5250DN Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Red status light came on red and toner light --orange
I have solved my own problem, I have a second identical printer that just developed the same problem, so this seems like a common problem. The solution was to replace the "toner sensor pcb assy" model # lj9935001. It is located in the left side panel which is easily removed (2 screws), I had it replaced in half an hour and that was the first time. It clips in ,the wire needs threading a little then then connector . if you take your time and think it through it is easy then turn it on and presto nothing but green status light. costs $18.50 with shipping ground. Contact Brother 901-379-1000, get customer service and ask for parts dept. Best of luck.
Aug 26, 2008 | Brother HL-5240 Laser Printer
Status red and amber Toner light
This problem you are getting is to replace the toner cartridge. Have you recently changed the drum unit as well. If so exchange it back to the other one.
After installing new toner or full toner cartridge and removing the yellow plastic cover press the go button this should start the printer on a cycle and add the toner. If this doesn't work then the toner sensor has malfunctioned and will need replacing. This will in turn out way the cost of a new machine.
Hope this helps and not too late for you.
Thanks Jason
Aug 09, 2008 | Brother HL-5240 Laser Printer
Had it a while and it stopped working.
Come on copier tec you should know better, need to know which light is showing orange, Drum,toner,paper,status?
Intuition tells me that you have a orange toner light and a red status showing, and you are using a non OEM toner, but thats guessing.
Dec 26, 2007 | Brother HL 5140 Laser Printer
Can't print
no other lights if you hold start/go button then replace toner with Gen New one
Oct 18, 2007 | Brother HL 5140 Laser Printer
Brother HL-5240 Laser Printer Logo
260 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
