Question about Sharp Notevision XG-P20XU Multimedia Projector
The fan just started to make scraping noises, as
The fan just started to make loud scraping noises, as if it is out of round. I am unable to access the fan to see the problem. Can you repair it, and/or is it worth repairing?
  • 2,237 Answers
It is definitely worth repairing. but if you can't get to the fan, you'll have to send it to a sharp service center. try av solutions in ny. they're really good. www.avsolutionsny.com
Posted on Nov 24, 2009
I have a model 51049 Hunter Louden brushed nickel low profile ceiling fan with light; my electrician installed it, but there is a noise like a piece of metal being hit, a scraping noise, which occurs
I have the exact same fan with the exact same problem. I kept taking it apart and could not find the problem until I got it completely apart and took the big housing off. I saw the problem immediately. A couple of the wires were hanging too low and scraping on the round drum that spins. I'm glad I found it, because over time this would have worn the insulation off the wires and created a problem. A potential fire hazard even. I took one of the stiffer solid wires coming from the ceiling and used it to loop around the flimsier stranded wires that were hanging down and scraping. I rolled it all up tight as close to the ceiling as I could and put it all back to together. The fan is beautifully silent now.
I installed it myself. That's my excuse. Your electrician should know better and if he made the rookie mistake of not clearing those wires, he should take it apart and fix it himself for free.
May 06, 2014 | Hunter Dryers
Toro ccr3650 wont start
Did you mean the AC adapter/battery charger made a loud noise? It means the ac adapter is bad and you need to buy a good working ac adapter.
Feb 11, 2014 | Sony VAIO VGN-FS690P Notebook
Brakes have been squealing off and on, but now has sudden loud scraping noise while driving
Brake shoes/pads worn out. Replace now. Be careful dangerous situation
Aug 13, 2017 | 2000 Suzuki Grand Vitara
Carrier Air V unit with loud noise
If it sounds like a scraping noise it could be the motor bracket ah broken and the squirrel cage (fan assembly) is hitting the fan housing, if it is more of a squeal than it very well could be a bearing. Very hard to guess without seeing or hearing it.
Nov 02, 2009 | Carrier Heating & Cooling
Fan started making noise
I have one of these, and every so often, the fan would start making a loud clicking noise. I discovered that if I shut the fridge off for a while and left the door open to defrost it, it'd work fine again for a while before the noise came back. Apparently, some ice was building up between the metal heat-sink and the fan, causing the fan blades to scrape against the ice/frost build-up and make the "tick, tick tick" noise.
There is no compressor in the Avanti EC15W-2 mini fridge. It uses a simple Peltier junction device to transfer heat from the inside of the fridge to the outside/rear of the unit. So it should never get very loud at all, unless one of the two fans in it is acting up in some way.
Aug 15, 2009 | Avanti EC15W-2 Compact Refrigerator
Loud noises
did you size the gas line properly? sometimes if the gas pipe isn't sized properly it will cause some pretty loud wistling noises. also if you have something in the fan like bugs or lots of dust it will cause alot of problems with noises
Jul 24, 2009 | Rinnai Digital Remote Water Heater Control...
Dishwasher making loud noise during wash cycle
It's noisy If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
thanks and accept the solution accordingly
Apr 03, 2009 | Kenmore Dishwashers
Loud noise at end of Draining
1. Water-inlet valve
2. Motor
3 Heater fan
4. Pump
Water-inlet valve
Motor
Heater fan
Pump
good luck
thanks for using FixYa
Jan 28, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
I have an electrolux icon double wall oven. I turned on the self-clean function for 3hrs and it making a very loud noise during the cleaning process. Is that normal?
yes, if the humming is not the loud sound then the fan may need some lubrication or if it is tripping the circuit it will need replacing , but if it seems like it is a viberating noise from the fan , then it could be that its bearings are bad , but the whole fan motor would still need to be replaced , but if it sounds like it just may be a loose fan motor , then tightening up the screws on the motor would stop the vibrating sound and or the fan blades from scraping metal( another sound you may be hearing )
Dec 24, 2008 | Electrolux ICON 30 in. Double Wall Oven
Loud Whining/Humming noise while washing
Water-inlet valve
Motor
Heater fan
Pump
Feb 13, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Sharp Notevision XG-P20XU Multimedia Projector Logo
227 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
