Question about Fujitsu LifeBook N6100 Notebook
Having a problem installing new memory. I'm not
Having a problem installing new memory. I'm not sure that I seated it correctly. The computer just beeps when I turn it on, but noting happens. I don't want to break something by forcing it. Trying to install two 1-gig memory chips
    Novelist:
  • 154 Answers
Make sure to open up the RAM compartment and pull out the memory sticks. Once you pull out the memory sticks, be careful to replace the memory sticks properly as the previous memory sticks were located before you removed them. If you are unable to do that, then you may need to take it into a shop for a professional to place the sticks in properly.
Posted on Nov 19, 2009
How to clean memory in dell 531s
If you think you're having a memory problem, you have these options:
1. Re-seat the memory chips and make sure they're in the socket correctly.
2. Go to www.Dell.com/support. They have diagnostics that will test Memory and all systems in your PC and show you what might be wrong.
3. You can run a memory Clean or defragmentation yourself. Go to Start, then Computer, then right click the C drive and select "Properties" then look for "Clean Memory" and/or "Tools" to do the "defrag".
Hope this helps.
May 08, 2014 | Dell Inspiron 531 Athlon 64 X2 4400+...
HP Pavilion dv6000t will not reboot after installation of added memory. Produced a series of "beeps" one time only, but not again.
click start
right click my computer
properties
hardware
device manager
?ports
scan for hardware changes
Aug 30, 2008 | HP Computers & Internet
When I put memory in, it beeps at me & nothing comes up on the monitor
Is this a new memory module you are installing (are you REPLACING or ADDING memory)? How many memory slots does this computer have?
Make sure that the module is seated firmly by gently tugging at it after the locking mechanism is in place to make sure it doesn't fall off. Sometimes the lock engages even though the module is not correctly seated.
You may want to try the module on a different port and if it still beeps, the module may be faulty (if there are any other working and compatible computers to try it on, it will help isolate if it's the memory module or the motherboard's memory ports at fault).
If you have any other spare memory modules, you can try those as well. Whichever component (either motherboard or memory) the problem is isolated to will have to be replaced.
Feb 08, 2012 | eMachines W4685 PC Desktop
I have a ASUS M4a77TD - tried to install new memory. BIOS recognize it, but computer won't boot, and does not even activate screen. Tried to reset BIOS (jumper), did'nt help. Any suggestions?
The issue most likely lies within the new memory.
Try to get to a bios boot screen without memory installed.
If that works, the new memory is defective.
Report back if you have any issues.
May 05, 2011 | ASUS Computers & Internet
How do you install memory hp pavilion a1620n
Unplug all cables from the computer. Open the access panel (the side panel) by removing the retaining screws from the back (just a couple on that edge). Plant your feet and ground yourself to the computer (use an anti-static strap for maximum safety for your computer). Locate the memory slots. Remove old memory module if needed by pulling the clips on the ends of each memory stick out and then pushing them down. Align the new memory module so that the notches in the memory stick line up with the ridges on the slot. Push the memory module straight down until it is fully seated. The retaining clips will lock into the module when it is properly seated.
The memory will only go in one way. Do not force it - if it doesn't fit, check your alignment (try rotating the module 180 degrees). Also make sure you have the correct memory (240 pin DDR2 DIMM).
I hope this helps.
Jul 02, 2010 | HP Pavilion a1620n (882780664494) PC...
DIMM connection prob
You probaly have them installed in the wrong socket. HERE a page that will tell you how to seat the memory. You have to be sure that they are installed correctly.
Good Luck
Mark
Oct 17, 2009 | Intel D865GBF Motherboard
Put two gegs of ram in my toshiba satellite a55-s1063
1. The ram you put into your computer man not be compatible with the computer itself. You can find out what kind of memory your computer takes by doing a google search or asking a technician at your local computer store.
2. You may have put too much ram in. www.pcmemorystore.com sells as its largest ram chip for your computer a 512meg stick. This likely means that the most memory your laptop can take is 2x512meg, or 1 gig.
3. The memory may not be correctly seated. Installing memory isn't rocket science, but you have to make sure you have the chips seated properly before trying to boot your machine.
Aug 14, 2009 | Toshiba Satellite A55-S1063 Notebook
My mother board is not accept ram plz tell me how can i repair my board
Make sure you are trying to install the correct type of memory , new systems use DDR2 , older systems use DDR , Very old ones use SDRAM
Also , make sure the memory is seated firmly and is the correct way round.
If you found this post helpful , then please rate my solution below
Kind Regards
1234s282
Jul 02, 2009 | Dell Computers & Internet
Montior in Sleep mode
Take out the newly installed memory chip... If your sure its compatable with the motherboard, reseat it correctly into it's slot and fire up the computer. OR try rebooting with just the old memory installed. Monitor blackouts happen when the incorrect Memory is installed OR when the Memory is not seated properly.
stop chasing video and monitor problems...... :)
Regards..
Mar 27, 2009 | E-Machines eMachines Desktop PC
Continual reboot with second memory module
Your memory isn't an exexact match. The 512MB you have in is probablyis Kingston, part # KT3311/512, PC2100/2700, 512MB DDR. You should get Kingston part # KT3311/1G, PC2100/PC2700, 1 GB DDR. You can use another manufacturer but everything must match exactly execpt the size of course. The speed, DDR, everything. Make sure you have the new chip seated correctly and in all the way first. Of course if it doesn't match the specs of your other chip it won't matter. Best thing to do if buying locally is take the first chip with you. If not buying locally, have it with you when you order to make sure it matches.
Mar 29, 2008 | Toshiba Satellite P35-S605 Notebook
Fujitsu LifeBook N6100 Notebook Logo
137 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
