Question about Sony Playstation 3 (PS3) Console
My PS3 stopped reading disks/games. Everything else works fine.
J4XXN
  • 182 Answers
SOURCE: game
a patch is coming out the 8th of jan, this tuesday to fix it i spoke to sony yesterday and they assured me it would fix it, and thats why they didn't send out a new unit. wait till tuesday, download patch and hopefully this will sort it. if not return it to where you got it from or phone sony as it has 1 year warranty. and their service is very good just make sure you back up game saves and other data. hope this helps you
Posted on Jan 06, 2008
marked
  • 6487 Answers
SOURCE: PS3 won't recognize disks after update
You can back up ANYTHING you wish to keep via the backup utility what I'm about to tell you to do will essentially erase your harddrive. After backing up any data you wish to keep, restore your PS3 system and to a FULL ( not quick ) format of your harddrive ( this will probably take a couple of hours ). After that, if it still doesn't work call SONY.
Hope that helps..........
Posted on Aug 07, 2008
  • 3 Answers
SOURCE: ps3 not reading any disc
what you have to do is turn it on and go on to settings. then format the system and wait for it to reset then start it up again and try it. (back up your info first!)
if that doesnt work ring sony and state the problem they should send you a new or refurbished ps3. but you'll need it in warrenty.
Posted on Oct 29, 2008
SOURCE: ps3 wont read disks
If YOUR WARRANTY IS UP. taking the ps3 apart is easy as long as you have the rght screw drivers. getting the plate off is the hardest part. there is a hex screw under the warranty sticker. after removing the screw, simply slide the plate down and it will pull off. then there are about 8 philips head screws on the casing itself. after removing these screws the top is hinged on the front side of the system... lift the back untin it is at a 90 degree angle and and remove the flat wire that goes to the SDcard slots by lifting the black flapwith your fingernail, then the top is removed. at this point the disk drive is no longe fastened by any screws of clips. pull the plug from the left side toward the front out to diconnect that set of wires. then there is a big flat silver strip connected to the bottom of the drive. once again lift the black flap to release this strip.now you are ready to open the drive itself. there are 2 silver screws on the bottom rear of te drive and 3 black ones at the front. you will need a very small philips head screwdriver for these. then the gray casing will come off. thelense is not exposed yet. there are still 5 or 6 tiny black screws on the top of the drive that will remove the black plastic case THERE ARE 2 TINY WIRES COVERED BY TAPE BE VERY CAREFUL NOT TO PULL ON THESE WHEN TAKING THE BLACK COVER OFF
. now the lenseis exposed. simply clean it with rubbing alcohol and q-tips and reassemble the machine. BE SURE NOT TO GET ANY OF THE WIRES PINCHED WHEN SETTING THE DRIVE BACK IN PLACE AND DONT FORGET THE LITTLE METAL GROUND ON THE RIGHT REAR OF THE DISK DRIVE. ANY ?S E-MAIL ME AT hartsedustin@yahoo.com
Posted on Apr 03, 2009
SOURCE: PS3 stopped reading PS3 games
This is most likely do to a previous freeze up while on the PS3. All you have to do is to first disconnect all of the plugs and wires. Then you put them back in and turn on the PS3. It should read your PS3 game discs.
Posted on Nov 27, 2009
Playstation 3 (PS3) Console: disks are not reading. The ps3 is working fine oth...
This is quite a common problem with the PS3 and is caused by a problem with the laser on the Bluray drive which is malfunctioning and can no longer 'see' or read the game disk properly.
The PS3 uses a dual laser system. This consists of either a dual refractor type lens or two entirely seperate lenses depending on which pickup is fitted to your particular system. One laser is for reading ordinary DVD disks and PS2 disks and the other for Bluray and PS3 games.
The symptoms you describe are quite typical of a failure of one or both of these lasers.
For more information on how to resolve the problem please have a look at this FixYa Tip on the subject.
Many thanks for using FixYa
May 18, 2010 | Sony Playstation 3 (PS3) Console
Nov 27, 2009 | Sony Playstation 3 (PS3) Console
Hello my sons ps3 has stopped loading games,
I have seen lasers burn out shortly after 1 year. They are available online for purchase. It would be the laser for sure if the system starts up fine, disks go into and out of the console and if there is an icon in top right of screen like it is trying to read. I have fixed a few but laser replacement usually cost $150. Good Luck
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
Wont read disk
PS3 is The amazing device by sony but it has some common problems like Disc read Error etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Dec 06, 2008 | Sony Playstation 3 (PS3) Console
Ps3 not reading any disc
Oct 21, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
54 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
