Question about Kodak EASYSHARE M1063 Digital Camera
My camera cannot turn on or off is only 3 months old tried what might be the problem? i tried to charge the battery nothing happened i tried to take the battery out and back on still it did not work. i need some help please. Thank u.
    Scholar:
  • 78 Answers
1. Remove the batteries from the camera and the memory card
2. Batteries should be Li-Ion Rechargeable Digital Camera Battery KLIC-7001 3. Verify batteries are inserted correctly
4. Place the camera in Auto Mode (Its green camera icon on the dialing mode)
5. Turn on the camera (if it failed try charging the camera)
6. Plug the USB AC adapter into a working power outlet.
7. Connect the USB cable to your camera and to the USB AC adapter.
a. If lights on battery charging light [solid green]
>charge the camera until light turns off or (up to 3hours)
b. If lights on battery charging light [red or flashing red]
>camera batteries are weak; replace with recommended batteries
c. If lights on battery charging light has [NO light]
>Try new set of supported batteries to test the camera one last time
>If already tested with a new set of batteries, set up the camera for repair
8. After all the step still camera will not work contact Kodak support line at 1 800 235 6325 (23KODAK) ** since the camera is less than a year it can be sent for repair in warranty. To receive warranty entitlement, you need to include a photocopy of the receipt or proof of purchase
NOTE: If Kodak repair center finds out customer induce damage, you will pay for the repair cost
Posted on Nov 19, 2009
Testimonial: "very helpful thank u very much, i will definitely refer my friends to u! marilyn u.k"
  • 846 Answers
Try to measure the battery with a voltmeter, if it's 3.7V and you still don't get any life from the camera, it's a broken logic board. There is a camera repair guide that shows you how to open a Digitial Camera and replace the part. The part is on Ebay. There is also a camera repair service that can do it for you.
Posted on Nov 25, 2009
D60 will not turn on - why?
If the camera has only been off for a few months, I would recommend that you take the camera and the battery to a camera shop, verify that the current battery is holding a charge and then check the camera with another battery.
Dec 25, 2014 | Nikon D60 Digital Camera
My go pro hero 3 wont switch on, wont charge and shows no red light. basically does nothing. was working 4 days ago but seemed to have short battery life. the camera is only 3 weeks old! Could it just be...
I have the exact same problem. I was able to charge the battery twice, but both times it ran empty after 20-30 min., and now the camera is dead as a brick. Absolutely nothing happens when I try to charge or turn it on. :(
Three weeks old Hero 3 Silver.
Jan 14, 2013 | GoPro Digital Hero 3 Digital Camera
Nikon Coolpix: can't charge battery
Charge up the battery. Most digital cameras use a lithium battery and the battery needs to be removed from the camera and inserted into a charge adapter to be charged.
May 31, 2012 | Nikon COOLPIX L20 Digital Camera
Camera is new ... only two months old... will not stayed charged, I give it a full charge, put it away but next time I want to use it, the battery is dead.. it is turned off, nothing is on, but battery is...
This could be caused by a short circuit in the camera. As the camera is only two months old, don't recommend that you try fixing this yourself. Instead contact Olympus directly to inquire of warranty repair. If you live in the US, here's the contact info.
Jun 11, 2011 | Olympus Stylus Tough 6010 / ? TOUGH-6010...
Help! My Samsung PL70 which is 6months old has
Mine just did the same thing. It is frozen on and stopped working while I was trying to change the flash setting. Even the image of what I was pointing at is stuck on the screen. Mine is only about 3 months old. I tried holding down the power button and it did nothing. Taking the battery out and putting it back in worked. I hope this doesn't happen again!
Jun 07, 2010 | Samsung PL 70 SL720 Digital Camera
Turns on then off. I have bought a new battery. Still didn't work. Charged it for hours. Still nothing. Only 4 months old.
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair w.4 months and no cust damage it is covered under the warranty.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 13, 2009 | Kodak EasyShare M1073 IS Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
Kodak EASYSHARE M1063 Digital Camera Logo
698 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
