Question about Dishwashers
Kenmore Dishwasher 17533200
We received an almost new Kenmore dishwasher from a friend. My husband installed it where our old dishwasher was. It lights up, and if you believe the lights, it says it cleaned the dishes. But when I opened up the dishwasher this morning, it hadn't even gotten them wet. The soap was still there, etc. We don't have a manual. What are we doing wrong?
  • brian c
    brian c May 11, 2010
    I don't want to question your intelligence.. but you ARE locking the door, right?
    The reason I ask, is some models will time through the cycles even with the door unlatched, but just wont do anything.
catriver
  • 878 Answers
SOURCE: Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Posted on Mar 08, 2007
SOURCE: Maytag jetclean eq plus dishwasher: soap problem
clean the filters
Posted on Jun 19, 2008
SOURCE: No clean dishes
DETERGENT DOOR DOES NOT OPEN DURING CYCLE?
Posted on Nov 03, 2008
SOURCE: dishwasher is not getting dishes clean. Water is
follow this link:
http://www.fixya.com/support/t2390397-dishwasher_acts_up
that guy gave me some good advice!
Posted on Jun 30, 2009
  • 677 Answers
SOURCE: my viking dishwasher does not rinse the soap scum off the dishes
Its not soap, its actually calcium from hard water. There is a new product out at www.dishwasherfilter.com that solves this problem once and for all. It is a small filter that goes under the sink and filters out the hard minerals that cause these spots from the water before they enter the dishwasher. It is very affordable (like 70 bucks) and even has a money back guarantee. After just one load you will be amazed how your dishes look.
Posted on Aug 12, 2009
Tip
For 3 weeks we've been without a dishwasher because of this. My husband went to...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Oct 27, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a Kenmore builtin dishwasher model 17533200 , when I run it it doesnt seem to use the detergent even though the cleaner compartment opens.
Check your wash arms - make sure the holes or nozzels are clear (not blocked), and make sure they are free to turn. Make sure you are not over-loading the dishwasher or placing a large pan in front of the soap dispenser. Next is to check to see if enough water is going into the DishWasher (DW). This varies with different models, so it's hard to tell you how much is enough. Also, what kind of detergent are you using? We find that powders seem to work better than liquids and gels , and tablets sold by Finish Corporation and Cascade work better than powders. Next thing to check is to make sure the heater is working to heat the water during the wash cycle. (Listen for the soap dish to open, then open the door 10 or 15 minutes later and see if the water is hot.) If your dishwasher has a removable filter, you need to take that out and clean it at least once a month. And finally, if your dishwasher is all encrusted with calcium and hard-water deposits, you probably need to run a dishwasher cleaner in the machine. (Use Dishwasher Magic, or Finish Corp's Dishwasher cleaner, or Glisten, or even Lemi-Shine detergent-booster powder or their dishwasher cleaner.
Hope this helps!
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Nov 18, 2011 | Kenmore 24 in. 17533 Built-in Dishwasher
Kenmore dishwasher 13749 needs a new electronic control panel
order sears on line / model & ser needed also instruction manual can be ordered .. not a hard job ..1/2 to 3/4 hr .. one wire or plug at a time new board is the same . hope this helps mm ..
Dec 07, 2009 | Kenmore 13742 / 13744 / 13749 Built-in...
Kenmore Elite Dishwasher not cleaning well
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
45jdgyhj
Jun 16, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
How to install dishwasher your self
Is there an old dishwasher where you are installing the new one? It must be connected to a water line, a drain T and an electrical connection. If you have never installed a dishwasher before, it would be a better idea to have someone install it for you (preferrably a licensed installer) or you could have leaks or other problems down the line.
Feb 21, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher and insulation...
I do not believe the insulation to be made of fiberglass. It is usually made of a yellow or tan colored foam material (not exactly sure what you call it). If there are concerns over the tears, you can reseal them with duct tape. Since the insulation wraps around the dishwasher tub and is mounted under the cabinet, there is no danger of any particles getting into the atmosphere and/or on your dishes. I would be more concerned about the insulation tears getting larger. That's why I would suggest you reseal them to insure the insulation provides the necessary noise buffering you need. If the tears are minor, I would save your money and continue to use the existing insulation. I hope this reassures you.
Jan 28, 2008 | Dishwashers
Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Jan 15, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
107 people viewed this question
Top Dishwashers Experts
