Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
External Hard Dive suddenly not detected
I have a Western Digital External Hard Drive (My Book) that my PC suddenly won't recognise. When I connect the HD via usb 2.0 there is a loud clicking sound followed by some whirring. This happens three or four times then stops. Device Manager on PC says no drivers detected. Had WD Drive for about five or six years. Running Windows XP.
Thanks for any advice.
Jonathan
  • jw_leader Nov 23, 2009
    Hello Damilare,
    Many thanks for your response and advice. I kept on disconnecting and then connecting the external drive and suddenly it was recognised by my PC, despite all the clicking an whirring! I have now copied the contents on to a new external drive so my data is, once again, safely backed up.
    That said, I may, for the hell of it, follow up your suggestions at some point. If I do I will certainly let you know the outcome. For now, many thanks once again.
    With much appreciation,
    Jonathan
  • 358 Answers
From what I can deduce here, it seems that you the hard drive probably has a bad sector on it.
That clicking sound that you are hearing from the Hard Drive is coming from the read/write head inside the hard drive.
In this case, what I would advise you to do is, unscrew the hard drive case and remove the Hard disk from the case, connect it directly to a system, not externally or through USB this time around, then get a software called NTFS DOS Professional. It is a software that works like magic when it comes to hard drive repairs.
If you know any other hard drive utility, apart from this, you can also use it. I just recommend this personally because that is what I use.
Insert it into your PC, start up your CD-ROM and let your system boot from CD-ROM.
It works through DOS, and it should be able to help you with it.
If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
And if it repairs it, I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
If you cannot do this by yourself, just get a very good technician to do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck.
Posted on Nov 23, 2009
  • Dammy Ezekiel
    Dammy Ezekiel Nov 23, 2009
    Hello JW_Leader,
    I feel very happy to hear that.
    Although you forgot to cast your vote. :)
    Once again, as I've said, it is better not to rely on the hard drive again and just use it to store files that are not VERY important.
    Because its an indication of an impending total failure.
    Once again, let me know how it goes.
    Good luck and have a nice week ahead.
    Thanks for using FixYa.
My Western Digital 1 TB External Hard Drive isn't working. The light just keeps flashing, that's it. Help!
Was it working before with the same computer ? Try with a PC is you can, maybe the drive was has filesystem that mac cannot see by default (like NTFS).
Jun 21, 2012 | Western Digital My Book Essential 1TB...
Hard Drive not recognised
If you are trying this on XP or other Windows OS, find out if it gets detected or not. you will find a icon below in your desktop
If this icon is on your taskbar and you are still not able to find the drive then you might need to manually configure the drive and partition in your computer management.
To go to computer management and assign drive letter to your drive detected follow below
go to start->control panel-> administrative tools->computer management-> locate disk management-> on the right side pane you might find detected hard drive but no drive letter-> right click the drive and select change drive letter and path->click on add->from assign the following drive letter select a drive-> click ok-> and your new drive will be assigned a drive letter and you can access your drive.
Below are the screenshots to do it. Hope this helps
May 23, 2010 | Western Digital My Book Essential Edition...
Hello my hard drive quit working. It say it working properly but won;t show up on my computer can u help
Hello Klpook, Hi, 1. scan your PC with an antivirus software, if the action failed to work, 2. use another PC to check if your Hard drive is good. if the other PC failed to detect you hard drive. 3. Use Hard drive utilities, such as Disk manager for Western Digital to diagnose your HD. If by chance no positive work is done. Your drive is bad.
Feb 23, 2010 | Western Digital Elements powered by WD 320...
Western Digital hard drive
If this is an external hard drive, what has happened is the USB interface has actually malfunctioned. I had a similar problem with a Seagate one.
If your computer is SATA capable with your present hard drive, what you have to do is actually remove the casing of the external hard drive until you come to the physical drive. It is a SATA hard drive. I removed the casing off mine because the USB interface all of a sudden died.
When I did this and plugged it into my computer, it recognized it immediately and had all of my files there. As long as none of the folders were encrypted, this goes on without a hitch.
Just take your time in removing the casing and you will be fine.
Jul 27, 2009 | Western Digital My Book Essential Edition...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
Is my harddrive broken?
Unfortunately it may be that way Jake. The funny sounds may be from the needle on the hdd. Seek out a local computer store and ask them to troubleshoot it. Unfortunately I think it may be broken.
Apr 04, 2009 | Western Digital 500GB My Book Pro-External...
New external Hard drive
Open up My Computer and see if there is a new hard drive listed there. It should be automatically detected by your computer, you just need to know where to find it.
Feb 23, 2009 | Western Digital My Book Essential 1TB...
Not recognised malfunction
Sounds like your drive may be faulty with the rattling - if I were you I'd back up everything off it pretty quickly, then send the drive back to western Digital if under warranty. I wouldnt open it otherwise your warranty will almost certainly be void.
Mar 28, 2008 | Western Digital 320GB MyBook External USB...
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
597 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
