Question about Honeywell International Honeywell& Tradeline Thermostat
I WANT TO HOOK IT UP TO A FAN,BUT ARE NOT SURE WHICH CONNECTIONS TO ATTACH TO.
  • 308 Answers
In order to hook this up to the fan on your furnace, you will need to either have or install a Fan center @ the furnace. (Unless it is gas, and has a circuit board that will simplify the process) All this is, is a transformer, a relay, and a set (or two) of NO and NC contacts. You will need to run 3 wires from the thermostat back to the furnace, if you do not have them already. If you have a gas furnace with a circuit board then all you have to do is connect the three wires from the thermostat to the board. (R to R; W to W; G to G. If you are using an older furnace, or a oil fired appliance, power should go out of the transformer (secondary side) to the thermostat on R. It should then come off W and another wire off G back to the furnace. Connect to the appriately marked terminals on the fan center. Hope this helps
Posted on Nov 19, 2009
Computer was running . but the processor area was very dusty so i open the processor fan and clean then i locked the fan and when i on the computer then fan some moves then stop.what i do
how did you lock the fan ?
you might need to replace the fan
check the power lead/s to the fan
this could be a problem with your power supply unit and electrical leads
if the PSU units fan is not working the psu is fauty
check all leads that attach from motherboard to you hard drive
check that your dc/dvd drives are working
make sure the electrical leads and connections are secure
and clean all dust from electrical connections
hope this helps
Oct 12, 2011 | Intel D945GCNL Motherboard
System powers up and doesnt do anything else. the fan goes really fast. no beeping at all
your computer is trying to connect to an operating system and cant find it
test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Aug 30, 2011 | Dell (58GGC) Motherboard
No beep on A8N5X motherboard, CPU fan works, green led on motherboard is on, nothing is on the screen
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
hope this helps
May 09, 2011 | ASUS A8N5X Motherboard
Can't load bios and chipset detected not working/not any warm but power switch and all fan working properly.
im not sure if you can or you cant but here goes
hope this helps
Apr 27, 2011 | ASUS P5LD2-VM Motherboard
I have interl board.the fan of processor is working after some time disply come but after this the board not working.pl.help
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
hope this helps
Apr 25, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I plug it in and hook it up to the computer and the blue power light doesn't come on and there is no power at all just blackness
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 27, 2011 | Computers & Internet
3 beeps and fan will not stop running. Will not boot up
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
dont forget to vote
hope this helps
Feb 07, 2011 | Gateway GM5260 PC Desktop
I am trying to hook up an hpxl953 desktop and it just beeps... one long and two short. Any ideas?
make sure your ram is properly seated
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
good luck
Sep 27, 2010 | HP Computers & Internet
Cpu fan and smps fan working no beep no display no sound pentium 2.4 ghz d845gvsr desktop motherboard
good luck
Sep 03, 2010 | Intel D845GVSR Motherboard
I have a model 5BS520C. The light works but when I pull the chain for the fan, I hear the sound of three speeds but the blades do not turn. ed.pfohl@gmail.com
Here some toubleshooting:
Problem 1. Fan will not start.
Probable Cause
1. Fuse or circuit breaker blown.
2. Loose power line connections to the fan, or loose wire connections in the switch housing.
3. Reversing switch in neutral position.
Suggested Remedy
1. Check main and branch circuit fuses or circuit breakers.
2. Check line wire connections to fan and switch wire connections in the switch housing.
3. Make sure reversing switch position is all the way to one side.
WARNING: Make sure main power is turned off.
Problem 2. Fan sounds noisy.
Probable Cause
1. Blades not attached to fan.
2. Loose screws in motor housing.
3. Screws securing fan blade flanges to motor hub are loose.
4. Switch housing binding against the blade hub.
5. Wire connectors inside switch housing rattling.
6. Screws holding blades to flanges are loose.
Suggested Remedy
1. Attach blades to fan before operating.
2. Check to make sure all screws in motor housing are snug (not over-tight).
3. Check to make sure the screws which attach the fan flanges to the motor hub are tight.
4. Check to make sure that the switch housing does not bind against the blade hub.
5. Check to make sure wire connectors in switch housing are not rattling against each other or against the interior wall of the witch housing.
6. Tighten screws securely.
Problem 3. Fan wobbles
Probable Cause
1. Setscrew in motor coupling is loose.
2. Setscrew in the hanger ball/downrod assembly is loose.
4. Fan blade flanges not seated properly.
5. Hanger bracket and/or outlet box is not securely fastened.
6. Fan blades could be out of balance.
Suggested Remedy
1. Tighten the setscrew in the motor coupling.
2. Tighten the setscrew in the hanger ball/downrod assembly.
3. Check to be sure screws which attach the fan blade to motor hub are tight.
4. Check to be sure the fan blade flanges seat firmly and uniformly to the surface of the motor hub. If flanges are seated incorrectly, loosen the flange screws and retighten.
5. Tighten the hanger bracket screws to the outlet box, and/or secure outlet box.
6. Interchanging an adjacent (side-by-side) blade pair can redistribute the weight and result in smoother operation.
WARNING: FOR YOUR OWN SAFETY TURN OFF POWER AT FUSE BOX OR CIRCUIT BREAKER BEFORE TROUBLESHOOTING YOUR FAN!!!
Hope helps.
Sep 02, 2010 | Monte Carlo Dryers
Honeywell International Honeywell& Tradeline Thermostat  Logo
219 people viewed this question
Top Honeywell International Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Honeywell International Electrical Supply Expert? Answer questions, earn points and help others
