Question about Kitchen Ranges
Magic chef smooth top electric free standing oven temperature
Magic chef smooth top electric free standing 5898xrb Oven temp is 150 degrees lower than touch pad set at 350 degrees. Had F-1 code, replaced the touch pad unit. Had this happen before and once the touch pad unit was replaced all was ok. Not this time. What else can cause this problem?
  • Kitchen Ranges Master
  • 3,361 Answers
Most likely a bad temperature sensor if the bake element is coming on and not reaching temperature.
The temperature sensor is in the back wall of the oven up high on the right or left side depending upon your model number. It is about 3 inches long and about the size of a thin pencil. It removes from the inside of the oven.
Posted on Nov 19, 2009
Testimonial: "Appreciate the quick and concise response. Will order a new sensor kit and see if that fixes the issue. Thank you very much!"
I set my magic chef oven at 400 degrees,and it shuts off before it reaches the temp.
Have you checked the internal temp with an oven thermometer?
The thermostat might need calibrating or replacing, or, (if electric) the oven might be seeing an "overload" condition and shutting off.
Dec 12, 2016 | Magic Chef Kitchen Ranges
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
I have a magic chef black electric stove and i never used the self cleaning but i cant stop the process the door is locked and the stove is getting very hot
Hello there:
Magic chef ovens and various other models of ovens have this no cancel feature this is due to the intense heatthat is generated during the cleaning process Normally if you press and hold the cancel button for 10 seconds this may cancel it out but the oven door will remain locked untill he temperature gets back to around 100 degrees see the cleaning temperature are almost around 600 degrees ok also you can unplug the oven and leave it set for at least 1 hour to allow the internal reset feature to reset the oven ok this has been known to take care of this problem too ok
Hope his is very helpful for you
Best regards mike
Oct 13, 2010 | Magic Chef CER3725AA Electric Kitchen...
I have a magic chef S68-3cxw electric stove/oven. It is flashing f2 can anyone advise what F 2 stands for
Hi, the F2 code on the Magic Chef Oven implies that the Oven temperature is too hot.
The solution is to replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness...
Oct 09, 2010 | Magic Chef Ovens
Oven is not reaching proper temperatures
You most likely have either a faulty thermistor or heating element that will need to be replaced.
Nov 10, 2009 | Magic Chef Kitchen Ranges
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chef manual
You can download it here but you need the right model #.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=MCF
As for the temp adjust it is best if you get an repair man out to do that.
Good Luck
Dec 18, 2008 | Magic Chef 9522 Electric Double Oven
Adjust temp level of the oven .. model 34ja-5tkxw
Press the bake key.
Adjust temperature to 550 degress.
Press the bake key again and hold it for 3 seconds.
The temperature +/- should appear.
You can then adjust temp +/- 35 degrees.
Mar 24, 2008 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
272 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
