Question about Moen YB2808 Eva Paper Holder - Chrome
How does the holder detach? Allen wrench,star, push with a screw driver?What do you use to remove the holder from the wall?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 36 Answers
There is no set screw or allen key for this. It is mounted in the anchor bolt by use of a mounting screen, pressed in until it clicks and difficult to remove
Posted on Sep 22, 2012
    Top Expert:
  • 12,744 Answers
The set screw is either a very small flat screw driver or allen key they used both styles
Posted on Nov 26, 2009
How do I remove gear stick on 2008 Mitsubishi l200
For the handle. Pull it back, on the front there will be a slot or set screw in the front. Set screw takes an allen wrench to loosen. Slot, insert a small flat screw driver and push in and pull up. To remove the shifter , you have to remove the console first. Screws and bolts could be(I do to many, I just know where to look). Panels under the dash, under cup holder mats, remove the box and lid, some under them. At the back, remove the blower vent or cover. and on the sides, you have to move the seats forward to get to them. then 4 bolts to remove and the wires and cables.
Dec 18, 2016 | Mitsubishi L200 Cars & Trucks
How does the YB2808 holder detach from the wall? ......the above answer wasn't an answer....I need to know how to "unsnap" the thing....it IS NOT held on with typical allen screw, how does one...
The anchor is put into the wall in a pilot hole, a mounting post is inserted into the wall anchor, Afterwards the mounting post is pressed firmly until it clicks to stay in the mounting post with the handle down. The locking tab on the mounting post is faced down to fit into the specific area to stay put.
  • If this was over tightened it will be difficult to get off.
  • Try moving the handle from side to side, while pulling the unit off.
  • If all else fails, put tape around the handle, then slide a flat head screw driver under neath, and lift up. the anchor bolt will now want to come out but it can be cut off. Push it back in. Repair the hole and try again if you are moving it anyway.
Dec 10, 2010 | Moen YB2808 Eva Paper Holder - Chrome
How do I remove the chuck from the drill. I have removed the star screw and have tried to turn the chuck counter clockwise to remove the head.
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Sep 22, 2010 | Bosch PS312A 12Volt Max 38Inch DrillDriver
Can't remove the chuck retaining screw.
Place drill in vice with chuck in vice facing up . Clamp chuck lightly but with enough force to hold firmly.
put allen wrench in chuck and lightly tap down to make good fit to allen screw head.Clamp chuck jaws down onto allen wrench lightly to hold wrench steady. Take piece of pipe to end of wrench,10".
These chuck screws are tight. Hammer clockwise until screw brakes loose.Open chuck completely and remove screw.Chuck is threaded to spindle shaft . Place allen wrench with long end facing out of tool in chuck and tighten chuck securely. With hammer tap allen wrench sharply counter clockwise ( normal thread.)
Jul 08, 2009 | Makita Drills
Having problem to remove chuck to replace it on dewalt dc988 18v
Inside the chuck is a left-handed screw. torx (star) T20. When you get it out, take an allen wrench and (if you can tighten it up at all, tighten the **** out of it). If not, find an allen wrench, a tiny bit smaller than the space allowed. Now, get a nice big hammer. The chuck is right handed thread. And knock it, spinning the chuck off the spindle. May take a few whacks. Use the edge of a workbench to keep it stationery if need be. Please rate me
Jun 08, 2009 | Dewalt 18 Volt Compact Drill Kit
Hansgrohe 41533 wall mounted soap dish install
I had the same problem with a Hansgrohe set screw on my toilet paper holder. Thought an allen wrench would do to open it but it does not work, I had to use the end of a pointy dinner knife to coax it out, might have also used a flat edge glass repair screwdriver also to get it out. It almost look as if it was "stripped" in the opening. I'm now trying to find a replacement set screw and came across this page. Hope that helps.
Apr 15, 2009 | Hansgrohe 41535000 Axor Uno Toilet Brush &...
Can anyone give me step by step instructions on how to remove light engine from sony kdf60wf655 tv thanks
I have the same Sony TV and just replaced my bulb. I ordered the bulb from sony.com and the package included the allen wrench you will need and simple step by step instructions are also included. There are two hand tightened screws on the lower rear corners of your TB. Remove these screws by hand and remove the botton gray panel of the TV. You will see the light package in the bottom center. Remove the hand tightened screw and swing the metal holder away. The gray cover now will come off by pulling lightly on the bottom. This will expose the lamp. You will need the allen wrench supplied with the bulb to remove the allen screw on the left. Once removed, the plastic cage containing the bulb will slide straight out. Push the new bulb in and tighten the allen screw. Replace the gray cover and swing the hold back in place the hand tighten the screw that holds it in place. Replace the gray bottom panel and hand tighten the two screws on the lower rear corners. That's the whole deal.
Jan 17, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Trying to remove the filter screen to see if something is blocking
Try a Torx screw driver. It looks like an Allen but it is a star shape head.
Mar 29, 2008 | Kenmore 15872 Dishwasher
Moen YB2808 Eva Paper Holder - Chrome Logo
687 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
