Question about GE Ovens
I have a GE oven M# PGS908SEM1SS, serial # SM230987Q The lady was self cleaning and very shortly into the process the oven and stove top both died. I took apart the oven, and I found that p# WB24T10140, ( which is similar to a non resettable thermal fuse) was no good. Before I change it I wan't to know if there is a reason this would go bad. The cooling down fan motor is OK.
  • All Make Appliance Nov 19, 2009
    Thanks so much for your help. by the way GE has the part for $29.5...
    Thanks
  • 10,865 Answers
The most common reason for it to go bad is due to the act of self cleaning. the immense amount of heat generated during this procedure is too much for an older thermal fuse to take.
Posted on Nov 19, 2009
  • GE Master
  • 19,396 Answers
Hi.
The WB24T10140 is an high limit switch that will cutoff when temperature is too high.
Allow the high limit to cool down. Read Ohms on the part. If it still has no continuity( infinite Ohms) then the high limit has blown and must be replaced.
The reason why the high limit has blown is the high temperature generated in the self cleaning cycle.
Self cleaning generates high temperatures to clean the oven. Sometimes this can damage parts as thermal cutoff/high limit, probe, or even control board wiring.
Here all parts and diagram for your oven.
Here one of the cheapest sellers at $40.
Please do not forget to leave feedback.
Regards.
G.
  • Ginko
    Ginko Nov 19, 2009
    Hi.
    Thanks. Good you found the part cheaper, we do not sell parts.
    I am sorry you gave negative feedback.
    Bye.
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
I have a problem with the control panel on my GE Electric oven.
Sounds like you have a control board issue. It should give you some kind of code instead of nothing. You can order a new one if you want but they are about $200 and up plus shipping.
Dec 03, 2013 | GE Ovens
Ge oven control panel problem
Sounds like a control board issue. Check to see if that particular gives any error codes if you can. FYI a new board is probably about 200 bucks.
Dec 03, 2013 | Ovens
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
How to self clean a GE PGS968BEMBB 30 Truetemp Stove. Is there a manual that I can download? Thank you judy
self cleaning a stove is bad, the worst oven scam ever. just use oven cleaner
Jul 14, 2009 | Ovens
Have a GE Electric Cook Top oven with digital
Unplug the stove. plug back in and program a short clean cycle. If this does not fix it is eithe the selector switch or the electronic control. Verifying the switch contacts with a meter is the only way to be sure.
Eric
Jun 21, 2009 | Ovens
Oven will not get out of the self-cleaning mode
Ok, unplug the unit for 5 minutes to reset the main circuit board. if the error continues to plague the unit, replace the control board.
May 31, 2009 | GE Ovens
Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Feb 02, 2009 | GE Ovens
Oven
Neal, the only thing I can bring up with that model number is a built in wall oven. You said the top burners work fine, so we are missing something here. Sounds to me like a stuck or shorted keypad. Catriver..post back
Sep 14, 2006 | GE JKP15 Electric Single Oven
Ovens Logo
118 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
