Question about VMware P2V Assistant 2 Starter Gold (A432537)
Cranking i tried to crank my car but all it is doing is click every time i turn the ignition(nothing). 3 months before i noticed it clicking maybe once or twice before it actually cranked. 3 days before it actually died on me i smelled what seemed to be burning wires. i looked beneath and noticed that some wires running to the (starter) i guess maybe the ones that were smoking. because of the blackness that was on my hand when i felt it.
    Novelist:
    Scholar:
  • 108 Answers
Yep....unless you are a mechanic you need to take it to a repair shop (does not sound like you are). The click click is indicative of a starter problem....if a wire burned (and it was any one of those to the starter the starter would probably not have worked at all...sure the blackness was not grease oil and roaddust mixed together.
Posted on Jan 27, 2008
2003 dodge caravan 3.3l cranks but no spark have replaced timing chain my bad...but i have a clicking noise sounded like chain.....replaced crank sensor it had evidence of being smaked maybe causing my...
probably forgot to reinstall camshaft sensor which located on timing cover or forgot to reconnect camshaft sensor because crankshaft sensor and camshaft sensor work together to control fuel timing and spark timing.make sure ignition coil getting 12 volts.
Aug 11, 2013 | 2000 Dodge Grand Caravan
Car has trouble cranking up.
replace the ignition switch
Aug 07, 2017 | 2005 Chevrolet Impala
My 2006 buick lacrosse wont start radio and lights work but its not saying nothing when i try to crank it
Hello! Do you hear a click when the key is turned?...If no click is heard either the ignition key, the Crank relay, the starter, or the battery are suspect...Having lights and radio does not mean the battery is capable of running a starter motor......Put a meter on the battery...should read 12.5 volts...Turn key...Does voltage drop to 8 or 9 volts? Bad battery...If all is well with battery and connections to it...Check the starter fuse # 33 in the under hood fuse/relay box...If the fuse is good that click you should hear is from the Crank Relay in that box...If all of the above is OK connect your meter to the Purple wire that is connected to the starter motor...When the key is turned 12 volts must be on that wire...If there is the starter motor is defective...So, #1...Do you hear a click when key is turned...That would point at a bad starter or weak battery...#2...If you do not hear a click bad fuse #33, bad Crank Relay, bad ignition switch...#3...If fuse is good Bad Crank Relay or Ignition switch; Crank Relay is a low cost item ($10)...Replace Relay...Stop there and send a comment as to results...Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
May 06, 2012 | 2006 Buick LaCrosse
My Car has been sitting for 2 months on "E" but i have cranked it 3 times out of the 2 months and it started fine. then i cranked it again later, it started an i drove but i shut the car off...
There could be 2 reasons for this. One is that the fuel pump burned out (you would be able to recognize this if you turn the ignition key over and get close to the gas tank you will hear it spinning). The other is there is a sensor on the bottom of the gas tank that reads when you are completely out of gas and you will need to contact the dealer on how to get it reset. Hope this helps you out! Have a good one!
Feb 20, 2011 | 1992 Lexus Ls 400
I drove my H3 yesterday and it did great! Parked in driveway.... Was going to go to store today & to my unexpected surprise it would not crank.... Just click, click, click (radio works). We tried...
Do a test 1st they are easy turn lights on and crank it if lights dime or go out it is the battery if lights stay bright it's most likely the start
Nov 06, 2010 | 2007 Hummer H3X
1993 lincoln mark viii wont crank
replace the starter and solenoid
Apr 07, 2009 | 1993 Lincoln Mark VIII
99 olds silohuette/ Hard to start
When you turn the key to start position that 2 or 3 times does starter click? or does it do nothing? If it clicks starter selanoid on starter is bad, If it don't click at all its ignition switch thats bad.
Feb 07, 2009 | 1999 Oldsmobile Silhouette
Engine will not crank intermitantly
Crank sensor can translate heat. Not allowing restart after the turbo heat radiates in the area. Try a wad of aluminum foil in front of the crank sensor(on the block behind the turbo) . It protects it from heat and its a cheep test. If this works you can make a better sheild or leave the foil.
Dec 21, 2008 | 2004 Saab 9-3
No crank
no crank or crank and no start? There is a difference
Sep 22, 2008 | 2000 Jeep Grand Cherokee
VMware P2V Assistant 2 Starter Gold (A432537) Logo
46 people viewed this question
Top VMware Computers & Internet Experts
matt
matt
CarlosIjalba
Tproverb
Level 1 Expert
Are you a VMware Computer and Internet Expert? Answer questions, earn points and help others
