Question about Refrigerators
Older model g e profile 21.5 cu ft will not cool below 50 degrees and will not freeze below 20 degrees. just sterted last night.
  • Mike Smith
    Mike Smith May 11, 2010
    Need your model number and further information to help . Do you see frost on the inside rear freezer wall ? Are the coils clean under the refrig ? Do you hear the freezer fan working ? Is the fan which cools the compressor working ?
    President:
  • 2,702 Answers
This could be the thermostats playing up, but i fell its most likle to be the compressor giving up the gost on you,,,and a new compressor is pricy so try turning down the thermostats first
Posted on Nov 19, 2009
FREEZER WORKING FRIDGE NOT COOLING
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Jul 20, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Fridge side working but only cooling to 50 degrees
My 14 years old GE profile refrigerator keep cooling above 50 degrees and not going down to below 40 degrees. I did clean condenser coil and fans are running fine. I adjusted temperature control to maximum cold .Do you think it my be short of refrigerant?
Jun 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Refrigerator does not cool model rb215labp when toatally defrosted freezer freezes but refrigerator never gets below 50 degrees has had this problem on and off since it was in warranty samsung...
Most likely one or more of your defrost component have failed which are defrost heater, defrost thermostat, and defrost timer or Board depending on model
Nov 02, 2017 | Samsung 18.8 Cu. Ft. Bottom-Mount...
Gladiator ref is not cooling properly
Check to see if there is cold air coming from the freezer to the refridgerator side through the vent holes The compressor maybe getting weak or the freon charge maybe low. Does the unit run a long time before it shuts off? 50 degrees is not cold enough for a freezer. You should be around 32 or less.
John
Sep 28, 2009 | Gladiator Freezer GAFZ21XXRK
Fridge part is 50 and Freezer part is 40
If your refrigerator is the model TFX27PRBWW then in photo below you see the defrost timer inside the fresh food compartment hidden by a cover. Turn the timer slowly clockwise until refrigerator stops. This should be defrost cycle. 30 minutes later the refrigerator should restart again, if not we need to replace the defrost timer. Go to link below and enter your model number that will take you to many of the same type just pick the one nearest yours. On left of screen choose the 4th photo down that is the part I'm focused on now. Let me know what you find, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Temp is erratic too warm, too cold ....
Sounds like the defrost timer is not working correctly or the start capacitor is malfunctioning,Both are cheap and easy fixes.
May 09, 2009 | Refrigerators
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Believe my compressor is bad
bite the bullet. or get a repiar person who know how to fix it.
Oct 12, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
