Question about Panasonic Cameras
When i turn the camera on it attempts to get into focus about 2-3 times then a message pops up that says "please turn camera off and then on again"
  • lillshellie2 Nov 19, 2009
    Thank you so much for your advice. I will be sure to do that :)
    Top Expert:
  • Panasonic Master
  • 76,164 Answers
This is the most common failure in digital camera's next to battery problems, the fault is caused by a problem in the tiny electrically driven gear drive that moves the lens of the camera to auto focus, now you say great how do i fix this?? well there is the problem, Panasonic doesn't sell any parts or repair manuals for their camer's to the public, without the needed parts and information on how to take the camera apart u are stuck, the bottom line is you will have to send it back to a factory authorized repair station, the phone number for this is in the user manual for the camera, they may also offer an exchange program or discounted upgrade to the newest version of your camera, call them for more information
Posted on Nov 19, 2009
System Error (Focus)
The systems control board has detected a problem with the auto focus lens, the focus is controlled by a tiny motor that has jammed or there is a mechanical issue with the camera lens. It will require a technician that is highly skilled to deal with the situation, but the repair cost would probably not be justified.
Jan 12, 2011 | Panasonic DMC-FX37 Digital Camera
Camera turns on, lens cyles (in and out) 3 times, then camera displays a message "Turn the power off and on again" superimposed on the display. Image is not in focus and camera will not take picture, just...
This is lens mechanism problem and lens assembly will be replaced to fix the issue.
Lens tries to correct its mechanical error three times then gives up and you see turn power off and on again display in lcd. If camera is under warranty, please call Sony to get it fixed or take camera to local camera repair shop if its out of warranty.
Thanks.
Jun 13, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Same message keep popping up
This means:
Force has been applied to lens (or other componant) and camera could not operate correctly.
Do the following:
1. Turn off the camera.
2. Remove your SD card, and battery
3. Wait a few minutes.
4. Insert the card and battery again.
5. If it lets you, change the settigs to the original position. (Reset the camera)
6. If the problem persist then compare the warranty and the usage period. I
7. Consult the dealer or your nearest service center if display still remains.
Regards.
Apr 13, 2010 | Panasonic Lumix DMC-TZ5A Digital Camera
Message PLEASE TURN CAMERA OFF THEN ON AGAIN
Sometimes this message appears when force has been applied to the lens. Here are some things to try. Go into the setup menu and find "reset" to reset the camera. If that doesn't work, remove the card and battery...press all the buttons...insert the card and then the battery. You may have a lens problem that can only be repaired at a service facility.
Aug 13, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
'Please turn camera off and then on again'
The barrel is defect inside,dit it fall on the lens? A new barrel will cost about 175 euro.
Jun 07, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Focus error
The zoom and focus operate on screw thread drives. 1 of these has detatched resulting in "ZOOM ERROR" and locked the camera up. Dis-assemble lens and re-attach drive.
May 25, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
When I turn on my panasonic digital camera DMC-LZ7 (with fresh batteries) it attempts to focus but cant then displays a message saying "turn off camera and turn back on again". If i do this, the same...
Looks like a problem with the CCD sensor. Try removing batteries, and SD card for 5 minutes. Replace new batteries and try again.
If issue persists, you will have to get the piece serviced.
May 24, 2008 | Panasonic Cameras
Problem
I had the same problem and fixed it.
The problem is related to the lens not working properly and jammed up.
When powering on the camera, the focus goes in and out and the lens spin and then the message is displayed to turn camera off.When I turn the camera off, I noticed the lens did not fully hiberate into the camera like it did before the error message.
So to fix the problem I did the following:
Turn the camera on, when the lens extended out, I slightly rotated the outer most lens clockwise and counterclockwise to free the lens from the jammed position.
The error no longer appeared and the camera stayed-on.When I shut the power-off the lens completely hibernated again like normal.
Hope this helps.
Pete
Dec 25, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Cameras Logo
13 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
