Question about Kenwood KDC-PSW9524 CD Player
Can i get a internal image/ diagram of the cd player assembly?. upon fixing a problem a small black expansion spring (ABOUT 15MM LONG) & a single loop Q shaped compression spring came off the outer casing of the cd unit ( the separate unit inside the the main head unit). I am trying to find where they go?. also is there any modification avalible to stop the printed circuit ( j84-0154-15) splitting. i have recently replaced my 4th, they only seem to last a year before breaking again, it,s as if they are too thick & need to be made more flexyible?. thankyou matt.
    Sergeant:
  • 163 Answers
The 64 page manual is at http://manual.kenwood.com/files/B64-2464-00.pdf
Cheers
Sir Dana Taylor
jdtaylor@live.ca
Posted on Apr 23, 2017
4 Suggested Answers
SOURCE: USB and CD Player Stopped Working
Checa en el manual si no activaste un candado con el usb.
Posted on Apr 09, 2008
SOURCE: Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Posted on Jun 11, 2008
  • 773 Answers
SOURCE: Control head will not power up. I put power to the
make sure the face plate is in correctly. This unit has a removable face plate and it could be half way in. Also, check to make sure the little copper contacts are clean.
Posted on Dec 02, 2009
Sacd 1000 lazer alignment
There is no alingments to laser assembly. If it found faulty, must be repalced.
May 20, 2012 | Philips SACD1000 CD Player
Diaper genie 2 fell apart and can't figure how to get it back together. The flapper with spring attached to it will not go back together. Are there any diagrams to put it back together.
There are two parts to the diaper genie clamp mechanism. Look closely at the cutaway view of the diaper genie at this link: http://playtexbaby.com/App_Themes/PlaytexBaby/pdfs/DiaperGenieIIAdvanced_OwnersGuide.pdf One part that has the cutter, and one part has the spring attached to it. If you look closely at the illustration where it is labelled "clamp" and follow the black line it actually points to the spring - its just such a poor quality image you might miss that detail. Look at the orientation of the parts to each other in that illustration so you know which direction the parts go. To reassemble, starting with the part that has the cutter built into it, slip the end of that part that is opposite the cutter under the spring on the second part. When assembled, the smaller part of the clamp slides upon the other part, and when the clamp,is pulled apart the spring tension pulls the two parts back together. These two parts, once assembled, snap into place inside the top of the diaper genie.
Aug 20, 2011 | Playtex Diaper Genie II Elite Diaper...
Do not know how to connect my kappa 60.5cs to my pioneer cd player do they have to go through an external amp?what do i do with the power plugs on the oppisite side why are there 2 per speaker
You need to run RCA cables from the CD player to the CD or AUX input on your amp / receiver unit. If you have a standalone amp, you need some way to control the volume. Basically, if you have a volume control on the front of your amp, you're OK. If not, you should also have a preamplifier that the CD player feeds first.
From the amplifier, then, a single pair of speaker outputs feeds a single pair of inputs on your speakers. The reason for two jack sets on the speakers is for "bi-wiring" or "bi-amping", not necessary for basic stereo reproduction.
So -
CD red/white RCA out -> preamp/receiver red/white CD/AUX input. Amp speaker output (red + / black -) to one red/black input pair on the speakers. An input on the speaker is side by side...
Keep the red to red, black to black when connecting the speakers, or you will wind up with poor sound and weak bass.
Jan 18, 2011 | Infinity US-1 Main / Stereo Speaker
Disc brake spring
best advice is if brakes work then its got into box by mistake,unless its a small coil spring for the brake pad wear sensors
Jun 04, 2010 | 1983 Chevrolet Monte Carlo
Installing Team Sabre makes Black Hawk Down game unplayable
Try uninstall and reinstall, Having done that then update the game!! I take it that you have made the maps for single player?? If so take all the MIS.files and make then COOP like i guess you have? and also ( player type) teamsabre!! i also guess that you also have the coopmenow / no cd patch? ( www.novahq.com ) DO NOT USE IN STAT SERVERS!!!!
Install the patch and all should be OK!
I make all my own maps and try them out in single player..Good luck
Mar 16, 2009 | NovaLogic Delta Force: Black Hawk Down...
Cd player diagram mecanical assembly Car Radio Blaupunkt Sevilla
I had that same problem with my one but, the cd that i put in it, did not work anymore. but then i tried another cd then it worked. try using another cd.
Jan 03, 2009 | Car Audio & Video
Sony cd walkman reads but won't play
If you have a small enough screwdriver and some time it's not too hard. I just fixed one of my kids' walkman (same make & model) yesterday. The motor that spins the gears that makes the laser assembly move back & forth came loose. There is a single screw that holds this motor in place. They should use some lok-tite or similar when they assemble these things.
Jun 03, 2008 | Audio Players & Recorders
Installing audio or image files on an expansion card
You can transfer audio and image files to an expansion card in your handheld. It's easy; just perform a HotSync operation after placing the files into the Install Tool. Here's how: 1. Insert an SD expansion card into your device. 2. On your desktop computer, launch Palm Desktop (even if you normally synchronize with another application). 3. Click the Install button. 4. At the top of the Install Tool window, make sure the correct user name is chosen from the pulldown menu. 5. Drag and drop the audio or image files from your hard drive into the Install Tool window. 6. You'll notice that the destination for the audio files will always be "Secure Digital card." You can install audio files only to an expansion card, and not to the device's internal memory. 7. Perform a HotSync operation. 8. Launch your handheld's third-party audio player and open songs from your expansion card, or launch your handheld's image viewer and open images from the card. Please refer to the audio player's or image viewer's documentation to learn how to do this (it varies from application to application).
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Kenwood KDC-PSW9524 CD Player Logo
48 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
