Question about Hobart D300 Stand Mixer
I HAVE A HOBART MIXER D300 ML#11627 I NEED TO KNOW WHAT KIND OF GREASE TO USE FOR TRANSMISSION,AND WHERE CAN I GET IT
  • Amir Orellana
    Amir Orellana Aug 17, 2017
    I have a DT300 hobart and the 1 gear does not work i can hold it with my hand what can i do to make it work
  • 640 Answers
Goto hobartcorp.com,create a username and then you will be able to find out what your looking for.I know that these mixers used oil when they where new but now changed to grease.Any ? let me know as im a hobart tech a repair these often.
Posted on Nov 22, 2009
My d300 hobart mixer is dripping oil when I am using it. How can I stop the oil from dripping out
It uses grease which breaks down over time. The transmission has to opened up and all of the old lube removed and replaced with fresh lube and the bottom seal replaced. Contact your local Hobart office. www.hobartservice.com to locate your local office.
Nov 04, 2010 | Hobart D300-6036 Mixer
What kind of oil i can used for hobart d300
Transmission uses #0 weight grease, best to get direct from Hobart (their grease is the correct weight and approved by U.S. FDA & USDA as safe for use in food equipment) but if you insist on not doing so, at least obtain an Extreme Pressure #0 grease and don't overpack the transmission, I believe it should have 35 oz. if memory serves right.
Uses a heavier grease for the planetary gear, use #2 weight. Don't need much, just a light coat on the planetary gear.
Bowl lift rails use medium weight oil, again use food grade oil supplied by Hobart.
Aug 02, 2010 | Hobart D300 Stand Mixer
Have an old hobart 140 mixer and i want to chang oil what kind of oil do i use
you need to replace it with a "FOOD-GRADE" mineral oil or FOOD-GRADE white lithium grease, you can get this from "Lubri-Plate" at their web-site
Nov 18, 2009 | Hobart D300 Stand Mixer
Hello i would like to know what kind of oil to use on a Hobart mixer d300 its a 3 speed mixer the problem im having is 3rd speed runs like 1st speed could it be the clutch that is bad thank you
d-300 and d-340 mixers dont use oil they use grease -47 can be bought @any hobart office. there are several reasons why this problem can happen. try tighning the planetary nut all the way then back off 1/4 TURN .also do the same with the top main shaft nut if that doesnt work contact me back
Nov 16, 2009 | Food Mixers
From what part of the mixer do we change the oil? And what kind of oil does it use?
Use food grade grease and you may have to split the motor housing.The grease is for the gearing in the head. At an Appliance parts store That's where to get some. :-)
Oct 26, 2009 | Hobart D300 Stand Mixer
My Hobart D300 mixer appears to be leaking oil/grease
Hi,I'm a hobart tech and repair these mixer's often.If you see oil in the drip cup then the center shaft seal in the transmission is worn.If there is oil near the transformer then the motor shaft seal is also bad.Hobart doesnt release their service manuals to the public but if you go to their site www.hobartcorp.com you can register for free and get a parts manual thats helpful.If you need help with the repair let me know,i can step you through it.
Mar 17, 2009 | Hobart D300 Stand Mixer
Hobart D300T mixer oil change.
Call your local hobart branch and tell them you need grease for a d300 mixer.Yes this mixer uses grease now.If it's older they used oil but is no longer available.
Mar 15, 2009 | Hobart D300 Stand Mixer
Transmission oil
this unit uses grease if it is leaking out the grease has broken and needs replacing
Sep 09, 2008 | Hobart D300 Stand Mixer
Transmission Grease for A120 and D300
Thanks,, great info..
I took mine all apart and the oil was just at the point of turning into grease. Nasty,, brown smelling ****.... I cleaned it all up and just used a sync 50w gear oil.. I over filled it and the extra ran out of the motor end of the gear box... It might have been about 2 table spoons too much.. Now it does not leak anymore.
Thanks again,, jaybeesee
Daniel from Penokee
Jun 13, 2008 | Hobart D300 Stand Mixer
How do i lubricate my 20 qt Hobart mixer and what kind of oil do i use?
you can call your local hobart branch for the part number,but you use lithium grease in the unit.in order to change the grease the transmission needs to be opened and so does the planetary. i service these mixers alot i work for hobart.if you need any more help/questions let me know.
Dec 23, 2007 | Kenwood KM400 / KM410 Chef Classic Stand...
Hobart D300 Stand Mixer Logo
584 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
