Question about Motorola Mobility Q9h Smartphone
Backlight does not stay on long enough - Motorola Mobility Q9h Smartphone
I thought I asked this already but it does not show up. I have a 15" lcd tv that will only stay lighted for a few seconds on each channel then goes dark. I can kinda see a image on the dark screen. I...
the backlight is either going out or the capacitor for the backlight is bad to where its not storing enough power to run the backlight the start capacitor must be good but the run capacitor might be bad usually the backlight itself goes bad but not if it turns on for a few seconds it would have to be the capacitor.
Oct 04, 2013 | Philips Magnavox 15MF400T 15 in. LCD...
Tip
Harmony Remote Glow Light Fix
Logitech Harmony Remote Control Glow light / Backlight Fix
Does your Logitech Harmony Remote Control Glow Light / Backlight stay on and won't turn off?
The problem is the timing crystal.
This is a solid state component that is responsible for telling the remote when the light has been on long enough.
It is very common in these remotes for the timing crystal to fail, thus your glowlight stays on until the batteries are dead.
If your Logitech Harmony is under warranty, contact Logitech Support (1-866-934-5644) to have your remote replaced.
If you are handy with soldering solid state electronics, the part you want to replace looks like a capacitor. You can buy what you need from any electronic parts store or hobby shop, just ask for a 32.768KHz crystal.
I hope that helps.
__________________________________________
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Firmware Update
Logitech Harmony Safe Mode Fix
on Apr 27, 2010 | Televison & Video
Samsung LED backlighting turns off
The only cure for this is to get it repaired and stop smacking on it before you do some real damage.
Jan 24, 2013 | Samsung NP300E4C-A02US Laptop
DX-LCD32-09 green light and backlight comes on for about 5 seconds and then backlight goes off green light stays on
Hallo there
You could try to adjust the colour setting in the PICTURE menu and keep a enough distance between the tv and other electronic objects in the room.
Give it a try
Kolbrun
Mar 17, 2012 | Dynex DX-LCD32-09 LCD TV
No backlights
The T-Con board is dead.This board sit right in the middle in the bottom of the LCD screen panel.This board is dead,require replacement.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con board for the replacement.
May 24, 2010 | Toshiba REGZA 47HL167 TV
Backlight is screwed up
there is a short in it this is typical of flip phones. If your savy enough order a replacement lcd and get your self a T-set (screw drivers) for phones
Jul 23, 2009 | LG Shine KE970 Cellular Phone
Motorola Razr V3a Backlight Stays On
From the manual, p. 31:
"BACKLIGHT
Set the amount of time that the display and
keypad backlights stay on, or turn off backlights
to extend battery life.
Find it: (on menu) > Settings > Initial Setup > Backlight"
Jun 22, 2009 | Motorola Mobility RAZR V3
I was chaging setting and I turned of backlight
If its just the backlight then you can stay in a well lit area and look at the screen that way to change the setting, also you could try plugging it in to keep the backlight on.
May 19, 2009 | Nokia 1600 Cellular Phone
Backlight behind numbers
in the case of your phone, you have to replace the keypad membrane of your phone, if you cant find a spare keypad membrane, you have to replace the whole flex. you can buy a flex in motorolla service centers near your place.
Jun 12, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Back light and sound
have you checked your settings and made sure have the backlight and dimmer setting high enough there in your settings under personalize then choose backlight and check your tme
Feb 28, 2008 | Sony Ericsson K800i Cellular Phone
Motorola Mobility Q9h Smartphone Logo
26 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
