Question about Xerox Phaser 8200DP Thermal Printer
I have a xerox phase 8200dp. it was unplugged by
I have a xerox phase 8200dp. it was unplugged by accident and when i plugged it back in the fan runs and it has xerox in the display window. left it all night and no change this morning
  • Xerox Contributor
  • 185 Answers
Check on the back of unit, there are blinking lights. Check the light next to the PS label and see if it blinks.
If not ....then you've got a bad Power Supply 650-4024-01
That's the most likely situation
Whit
Item, Inc
Posted on Aug 10, 2010
Xerox 5755 Install Phase incomplete error appearing on display
enter in diagnostics mood
then touch DC-131
then 03-machine run Control
change value (03-005) change to 4 and save
also change (03-018) change to 4 and save
exit from diagnostic mod and restart the machine
Jul 13, 2017 | Xerox Office Equipment & Supplies
Software reset xerox printer phase 3155
reset xerox 3155 :
1. Connect the printer to the computer and turn it on
2. Wait until the printer is ready for work
3. Run the file "download.bat"
4. The reprogramming process starts automatically
5. Wait until the printer reprograms (1 minute) and restarts
6. After that the reprogramming process is finished, restart the printer
Sep 21, 2012 | Fuji Xerox Phaser 3155 Laser Printer
Hi i ned to reset the maintenance for phaser8200dp color printer
Without expensive equipment to reset the chip I don't know of anyway to do this. If it is "expired" by date you can try going into the printer setup and back dating the year to "fool" the printer. I understand many people have had success doing this.
Sep 28, 2010 | Xerox Phaser 8200DP Thermal Printer
Need to replace the fuser unit kit in a xerox m20 copy machine
First unplug the machine.
Open the right side door. there are four screws to remove. Unplug the two plugs to it.
Pull out the fuser modual.
Insert the new fuser modual, and release or flip the green jam tabs.
When put on the four screews make sure not to over tighten, just a gentle snug is needed.
Close the door, pug machine, and turn it on.
If the fuser fan is not working, this can cause the fuser to over heat again. Make sure the fan is truning by viewing it from the back.
Good luck.
Jul 14, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Using Phaser 8200 with Windows XP SP3 - when selecting CUSTOM paper size - Windows Explorer crashes
This happens most frequently with a bad driver install. You should go to Xerox.com and download the latest version of the device driver. Then reinstall the approrpaite driver and check to see how things go.
Oct 23, 2009 | Xerox Phaser 8200DP Thermal Printer
Powering Up My Xerox Phaser 8200DP
I assume no codes are coming up after leaving it on for a long time.
Most likely problem is the electronics module.
With the price of it you could buy 2 new dry ink phaser printers.
But what you are describing sounds like an electronics module issue.
May 27, 2009 | Xerox Phaser 8200DP Thermal Printer
Phaser 8200DP error 07,002.44:40280 Can you identify this fault for me and tell me how fixable it is?
07,002.44:
PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic test. Also exercise processes run with the process motor; transfix, drum maintenance and head tilt. This can be caused by the power control board. The process motor may have more than one task initiated. Reset all solenoids and the pressure roller prior to cycling power.
Aug 11, 2008 | Xerox Phaser 8400 Laser Printer
Fuser fan error?
The fan is likely bad. Time to replace.
Feb 22, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 8200DP Thermal Printer Logo
73 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
