Question about Hotpoint Ultima WF860 Front Load Washer
Will not spin the machine panel says check outlet pipes have done and cleared water out but machine spin programme will not complete
  • Gerry Harvey
    Gerry Harvey May 11, 2010
    Could be worn motor brushes ..Carbon wears away after about 4 years causing motor to stop, parts cost about £15
  • Hotpoint Master
  • 3,463 Answers
You probabl;y need to clean filter.
Remove lower rearcover of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump.
Please rate my solution.
Thanks.
Posted on Nov 19, 2009
My washing machine has not diained. When I set the programme to drain a code ‘0’ has come up above the spin signage machine is AWO/C0714
I would look underneath the machine to check the water pump for free running and has no debris blocking the water outlet pipe as that's the best advice to give you eric
Dec 24, 2017 | Washing Machines
The machine is displaying ELoOOOO and making a noise. How do I clear/fix this? Cheers, Phil
its clearly trying to empty the drum of water maybe there's a blockage problem in the outlet water hose as the machine cant advance till the water censor switch tells the programmer that the machine is ready to fill by being empty first please blow into the water outlet pipe to perhaps clear the blockage eric
Dec 21, 2017 | Washing Machines
Washing machines problems
please check if the water outlet pipe is clear by blowing down it to see weather the pipe is clear as the machine wont move on until the water is emptied from the last cycle it needs to empty the wash water first before spin cycle can start, its worth a try eric
Dec 09, 2017 | Washing Machines
Indesit wil143s will not final spin
check to see if there is not a blockage in the water pipe as if the water level in the machine is to high the water censor cannot switch to the next cycle try blowing down the water outlet pipe to see if you can there could be a button or other debris blocking the flow until the water is expelled from the machine it cant go on(theres a song in there somewhere) best of luck eric
Dec 23, 2017 | Washing Machines
Fridgedare front end washer! Water don't seem to drain for washer, looks like the spin cycle do not spin water out.
if you can hear pump motor, then there is a blockage somewere, check see if filter is clear,check outlet pipe is not kinked,disconect outlet pipe hold over pan as close to floor as posible see if water comes out if it does then there is a problem with pump.
Aug 12, 2011 | Washing Machines
Spin not working properly, sounds ok but clothes are too wet once complete and the independent spin cycle leaves clothes soaking!!!
Sounds like a small blockage in the outlet pipes, possibly just in the filter but check all outlet pipes. Just done one the other day and it was a clothes button that had passed out of the machine through the pump to the outlet pipe but had turned sideways inside the outlet pipe.
Jan 25, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint aquarius ultima 1000, when wash cycle is comple the rinse cycle wont start and displays message check outlet pipe which i have done but it seems to be clear as i can syphon water from the machine...
It sounds as though the pump is not draining the water out.
If you have checked outlet pipe and it is clear, then you need to check the filter, if there is no filter at front of m/c, then remove the rear panel, and unfasten the large black hose that goes to bottom of drum, remove filter and clean, check pump at same time.
Watch out for water from the drum.
Refit filter and hose and test.
Plz rate my suggested solution, and feel free to leave a comment.
Thankyou.
Jan 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washer will not drain
Check out your outlet pipe from under tub to filter. Keep bucket to collect water if it drains from the hose, clear the hose; if possible look also into filter to remove any clogging. Fit back. You could pour some water into the machine (where u put your clothes) and try 'spin' only for a short time. See if water drains. Try half a load to see if the machine rinses and drains. This symptom is usually when your outlet drain pipe or out filter is blocked with something.
Apr 21, 2007 | Kenmore 24432 Top Load Washer
Not Pumping out water
Possible your outlet filter is blocked. After disconnecting electrical input from wall socket, remove the back panel of washer to see if the pipe from the tub is blocked, clear, also check the outlet filter, clean. If u have the users' manual check how to clean your outlet filter
Nov 14, 2006 | Creda W120VW Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
47 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
