Question about The Times ROYAL TC100 TimeMaster Time Clock
Will not print date 11-19 sample - The Times ROYAL TC100 TimeMaster Time Clock
  • 113 Answers
Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting:
Date & Time: Press the Mode button. The Hour will start blinking. Press the Setting button
until the correct hour is displayed. Press Select to set the hour shown.
The Minutes will blink. Press Setting until the correct minutes are displayed. Press Select
to set the minutes shown.
The Seconds will blink. To set the seconds at 00, press the Setting button. Press Select.
The Year will blink. Press the Setting button until the desired year is shown. Press Select
to set the year shown.
The Month will blink. Press Setting until the correct month is shown. Press Select to set
the month shown.
The Day blinks. Press Setting until the correct day is shown. Press Select to set the day
shown.
Print Method: Press the Mode button until P5 (Program Mode 5 for Print Format) is displayed.
Press Setting to choose one of the following Print Methods.
The TC100 has two settings for print activation: Manual or Automatic
1 = Automatic (default setting) - The TC100 automatically prints when the time
card is inserted.
2 = Manual - After inserting the time card, press the Print Button to activate
printing.
Press Select to confirm the Print Method chosen. Press Mode to return to normal operational. hope this work for you best regards happy holidays : - )
Posted on Dec 12, 2011
Royal Time Master TC100 Time Clock. Power outage. Can't re-set the date. Help???
Posted on Jan 20, 2010
Im a freshmen on a programming course and my assignment is this,my professor wants us to do a program out of this sample input input your name cheryl input birth month july input your birth date...
You will create a program that asks your Name, then your birth month and birth date, you need to store them into the programs memory.
You will have to also store into the program the months / dates for each sign, and then have the program look up the according sign for that date and print it out.
Very very simple. Everything needed to programm the program you should already know? visit your notes / other material from the course and it should be fairly easy for you, unless you have slept all the classes?
Jul 13, 2011 | Computers & Internet
We just put new ink in and it prints out fuzzy . how to fix it ?
Every time you replace ink you need to do an alignment. To do this follow these simple steps:
  1. Press the Ink or Ink Management key on the control panel.
  2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
  3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
  4. Press Black (Mono) Start or Color (Colour) Start. The machine begins printing the Alignment Check Sheet.
  5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
  6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
    If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
  7. Press Stop/Exit.
Mar 02, 2011 | Brother MFC 210C All-In-One InkJet Printer
My PictureMate printer is printing with a discoloration border on each end of the print; blue on the left and pink on the right. I have used photos downloaded from a SD card and also sample pictures from...
You often fix this by going to settings and going to things concerning ink and often their are cleaning options, like head cleaning and stuff like that.. It should fix it :)
It is great to set up dates when you will make your printer perform this cleaning.... It makes the printer perform better and just keeps it clean :) God Bless :)
Jan 08, 2011 | Epson PictureMate InkJet Photo Printer
How do i align my printer, it's printing blurry
Setting the Alignment:
  7. Press Stop/Exit.
Apr 01, 2009 | Brother DCP-120C All-In-One InkJet Printer
After replacing the ink cartridges ran out I replaced them for new ones and the machine is not telling me that cartridges are empty tried and tried to rereplace them and I still keep getting the same
  1. Press the Menu/Set key.
  2. Press the up or down navigation key until TEST PRINT appears on the LCD.
  3. Press Fax Start. The DCP/MFC begins printing the Print Quality Test Sheet.
  4. By reviewing this Test Sheet, you can determine if the print quality or alignment needs improvement or adjustment.
StepA - Checking the print quality:
  1. The display will read "IS STEP "A" OK?" 1.YES 2. NO.
    Before choosing YES or NO, closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
    If all lines are clear and visible, press 1 (YES) and proceed to StepB. If you can see missing short lines, press 2 (NO).
  2. The display will then ask you if the print quality is OK for each color. Press 2(NO) for any color with the problem.
  3. The display will then show START CLEANING? 1.YES 2. NO.
    Press 1(YES) and the DCP/MFC will start cleaning the color ink cartridges.
  4. After the cleaning is finished, press Fax Start. The DCP/MFC will print another Print Quality Test Sheet.
  5. If you can see missing short lines in any of the four color blocks press 2 (NO) and repea the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
StepB - Setting the Alignment:
  1. The display will then read "IS STEP "B" OK?".
  2. Examine the 600 DPI and 1200 DPI test prints on the Print Quality Test Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1(YES).
  3. Print another Print Quality Test Sheet by following the steps provided at the top of this page and check it.
  4. Press Stop/Exit.
Aug 11, 2008 | Brother MFC 420CN All-In-One InkJet...
Printer
ejwetzker,
Many things could be the problem, but check the basics (power, paper, toner, cable). If still a problem, check driver (is it installed?) If driver is OK then try printing sample page. If sample prints your application may be the problem.
Aug 05, 2008 | Computers & Internet
Printer alignment
From Brother's website, I found the following regarding alignment:
  4. Press Black (Mono) Start or Color (Colour) Start. The MFC/DCP begins printing the Alignment Check Sheet.
  7. Press Stop/Exit.
The webpage for this is:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000059/faq000259_007.html?reg=us&c=us&lang=en&prod=mfc420cn_us
I hope this resolves your problem.
May 20, 2008 | Brother MFC 420CN All-In-One InkJet...
It prints a sample but it won't print for me when I try to print something
Go to printer properties setup your printer......
then test print.... or a 2page file print current page.......ok
Feb 10, 2008 | HP DeskJet 6988 Printer
Printing Problem
The 8i is a line printer only printer. It does not understand EZ print code. You need to just send a line of ascii text for it to print.
Apr 08, 2007 | O'Neil Printers MicroFlash 8i Matrix
The Times ROYAL TC100 TimeMaster Time Clock Logo
411 people viewed this question
Top The Times Office Equipment & Supplies Experts
jasbo
jasbo
Are you a The Times Office Equipment and Supply Expert? Answer questions, earn points and help others
