Lexmark x264dn, i get a 922.80 fuser error! Tried on/off a few times then waited 10-20 seconds and i still get it. Sometimes i get 920.20 fuser error. And it's new! Help!
  • 22 Answers
If less than a year old it's under warranty. Call the 800 number in the owners manual that came with the printer. You will be able to mail it back and receive a new one. You will have to secure the deal with a credit card but they won't take out anything if they get the printer back.
Posted on Nov 19, 2009
Lexmark t644 is showing "920.06
920 error is cold lamp on fuser replace fuser will clear problem
Sep 25, 2011 | Lexmark T644 Laser Printer
920 service error fuser
This problem (920 Fuser Error) occurs when the Fuser is below temperature while printing. The 920 error caused by low line voltage can sometimes be cleared by turning the machine off and on. You should replace the fusser and reassemble it.
You can also follow these steps:
Note that you do this on your own responsability.
Remove the fuser heater cable from the power supply (CN602). If there is no continuity in the heater wire, replace the fuser heater and thefuser oil coating roller. If there is no continuity in the thermostat, or it does not equal 240K Ohms at25 degrees C (room temperature), replace the fuser thermostat and the fuser oil coating roller. If the thermal fuse is open, just replace it.
If there is continuity, and the thermostat is good, only replace the power supply. If this doesn't fix the problem, replace the printer controller board.
May 17, 2011 | Lexmark E342n Laser Printer
Lexmark T644 920.16 Service Fuser Error What do I need to do to repair this problem?
Lexmark gives the following list of all fuser errors and recommends what action you should take (Lexmark Knowledge Base). that the fuser unit failed to reach the standby temperature.
  • If this is the first time you have seen the error, turn the printer off and on. Leave the printer off for at least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
  • If this is an intermittent error, you may want to check how the printer is plugged in, even if it has worked on this surge device for months. Make sure the printer is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer which can trigger a false fuser error.
  • If this does not help or if this error appears every time the printer is powered on, you will probably need service on the machine.
  • 920 Fuser Error message indicates that the fuser unit in the printer is below the proper temperature for printing.
  • You may need to replace the fuser: watch this video:
    http://www.youtube.com/watch?v=RjQkR4x9fqw
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
    Jan 24, 2011 | Lexmark T644 Laser Printer
    920.06 SERVICE FUSER ERROR
    A 920 fuser error indicates that the fuser unit in the printer is below the proper temperature for printing. Turn off the printer for 30 seconds. Bypass any surge device or power strips, plug the printer straight to the power outlet in the wall. Make sure the printer is an operating environment where the temperature is above 16°C (60°F). If none of the steps above correct the issue, the fuser unit or possibly the power supply unit on the printer will need to be replaced. This will require a service action on the printer. I hope I can assist you more on this.
    May 26, 2010 | Lexmark T640N Networkable Mono Laser...
    I have a c920 lexmark with a fault code 920.000. my guess is that the fuserisnt heating up... based on the fact that its not getting hot... im guessing the fuser lamp has blown.... is there any other...
    Hi, Majorly this Error 920.X display for a cold fuser. Some 920.xx error codes may be cleared by turning the printer on and off.
    In general, fuser errors require replacement of the fuser. Fuser errors can be from a cold fuser or an overheated fuser. In your case you need to replace the Fuser.
    Feb 22, 2010 | Lexmark C920 Led Printer
    920.07 code on a t642
    a 920 error means your fuser is under temperature at standby. you should replace the thermistor it cycles the fuser on and off to maintain these temps
    Nov 06, 2009 | Lexmark T642 Laser Printer
    "922 SERVICE FUSER ERROR"
    920, 921, or 922 Fuser Error:
    The printer thinks the fuser unit is not heating up to the correct operating temperature. This can be due to a bad fuser lamp or possibly no power getting to the fuser unit. As a customer, the only other thing you can do is to check the connections on both the fuser unit and where it goes into the printer. Make sure neither connection is damaged. If you are a technician working on the printer, you can check the voltage coming off the system board and Low Voltage Power Supply (LVPS) to make sure power is getting to the fuser unit.
    Don
    Jun 04, 2009 | Lexmark T520 Laser Printer
    Lexmark E342n Laser Printer Fuser Error
    920 Fuser Error
    Indicates that the fuser is below temperature when printing
    Do a Fuser Service Check
    Jun 26, 2008 | Lexmark E342n Laser Printer
    31 missing or defective cart.
    Try changing the photoconductor kit
    Jun 02, 2008 | Lexmark E342n Laser Printer
    ERROR
    921 Fuser Error Indicates that the fuser is below standby temperature when the printer is idle.
    Error codes 920, 921, and 922 may display for a cold fuser failure. A 920 error caused by low line voltage can sometimes be cleared by turning the machine off and then on again.
    Service Tip: Set the Fuser Temperature to NORMAL before starting this service check.
    Manually spin the fan and check that
    it rotates freely. Check the cable
    connection to the engine board, J13
    for correct installation.
    Jan 23, 2008 | Lexmark Optra M410 Laser Printer
    260 people viewed this question
    k24674
