Question about Panasonic Televison & Video
I have a 46 inch panasonic hdtv that i brought 5 years ago, recently it went out, i think it was attributed to the lamp but not sure. when i turn it on you can hear it come on but thats it no picture or sound
    President:
  • 1,284 Answers
If it is a model that uses a lamp and it has never been replaced then I suspect the lamp first. The sound on these lamp driven sets will not come on until the lamp fires up. If you have your owners manual, take the lamp out and physically look at it and see if it has blown. Please take a few moments to rate my answer. Thank you....
Posted on Nov 19, 2009
Hello I have a dlp samsung hlp4663wx/xaa. Last week the picture went black the sound is good . I replaced the lamp and the problem continues . I also replace the color wheel a year ago. know everything is...
It is the DMD board especially if the lamp stays lit. If the lamp is not lit... Be sure you have the lamp in properly...that is plugged in good and the door has the door switch engaged. Be sure door switch is still good and did not get damaged when replacing the lamp. DMD board can be found at encompassparts 1-800-638-3328 for 318.51 plus 150.00 for the core but right now is on FACTORY BACKORDER Part number
BP96-00678DCurrently on Ebay for 179.00 plus 15.00 shipping. Enter part number in search
Oct 24, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
My Samsung DLP HD 46" TV just went Black &
Defective Color Wheel- Encompass parts Distribution 1-800-638-3328
Mar 06, 2011 | Samsung HLP4674W 46" Rear Projection HDTV
I have a Panasonic 60 inch TV, which I just changed the bulb less then two months ago. I called the bulb distributor and they said send back the bulb for tests. My problem is that I am not sure if it is...
i believe that the lamps on this model are warrantied for 5 years and labor for 3 years from panasonic i suggest calling panasonic for advice on where to go further.
Dec 23, 2010 | Panasonic PT-61LCZ70 Television
My 62 inch dlp tv came on and was working then with out any noise or notice the picture went to black and a steady red light came on under the word "lamp". We looked at the bulb and it does not look burned...
The tv lamp was replaced when? The tv on about 4 or 5 hours a day right?The lamp was replaced about a year or a year an a half ago?The projection lamp is dead,the life span is over.Must replaced with a new lamp.
Jul 01, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Lamp will not ignite
Two possible causes. First. The Color Wheel is going bad. Second. The Digital bd is going bad. Color Wheel part# is BP96-96-00674a and the Digital bd is a BP94-02065a.
Jul 09, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
46 inch projection lcd, says tempature is to hot at bottom of scr
If you replaced TV lamp recently then check lamp cover and make sure to seat it properly.
Need further info, let me know.
Jul 02, 2009 | Zenith E44W46LCD 44" Rear Projection...
Brief picture for 30 seconds, then lamp button blinks
Found that the thermistor/temp measuring device is suspect, no resistance across legs. There is a label there that says F701 see service manual
http://www.goodmans.net/get_item_th-tf117c_thermal-fuse-117-degrees-celsius.htm
I went here for a tech manual for the Panasonic
tv.
http://www.ManualsParadise.com
then ordered
Manufacturer: Panasonic
Part Description: FUSE
Part Number: LSJA0411-1
from
PartStore.com
it was mounted to the case that holds the lamp. had to remove the back panel, etc. Also think I had to splice in the fuse or something. was a while ago.
i purchased a NTE8115 from my electronics supplier, closest I could find.
Radio shack also has them.
remove the back cover and measure for continuity across the thermal fuse
above the lamp housing.
if open jump it wth a 5 amp fuse, be sure to close the safety switch with
the small blue lever then try to power on.
If comes on ok you will need to replace the entire ballast assembly to get
that fuse.
Panasonic does not have a part number for just the fuse on the PT40LC
series.
It is possible to cut off the fuse and replace with another but dont solder
Dec 22, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Turning on problem with Panasonic Viva PT-43LC14
Sounds as you have a bad ballest. The ballest is the power supply that turns your lamp on. You can check your lamp by removing it and it should be clear and no broken pieces of glass. With the lamp removed install the cover and turn it on you should hear no noise and when the power light turns red you should see a LAMP red led blink every 5 seconds. If no noise then the lamp is bad. If you do hear noise you have a bad ballist. Hope this helps. Frank
Sep 05, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
