Question about Ricoh Aficio 1515MF All-In-One Laser Printer
We have message to Replace Photocondutor. Is that toner? If not, s it self-install or do we call for Tech?
  • 532 Answers
The Photoconductor is a separate part.
You can order it online:
http://www.nextag.com/Ricoh-Type-1515-Photoconductor-80870776/prices-html
Posted on Nov 19, 2009
    Genius:
  • 1,018 Answers
Most photoconductor assemblies are what they call "CRUs". That means that they are Customer Replaceable Units.
Check with the Ricoh web site "Support" to verify the installation process and order the part.
Don
How to replace Konica Minolta Page pro 1580 mf toner. please tell us
is the toner 3rd party or OEM. Replace with OEM cartridge. Well the toner is not the drum you bought a drum it needs toner. ????
go this site for operator manual
Self Help Product Support Konica Minolta Business Solutions Inc
Dec 18, 2015 | Konica Minolta Office Equipment & Supplies
Konica minolta page pro 1580 mf toner low message.how to reset?
Replace toner cartridge or did you fill it your self, if there is a chip on the cartridge and you refill your self then the old cartridge is still old. Are you using 3rd party or OEM? replace with oem
Aug 02, 2015 | Konica Minolta PagePro Office Equipment &...
The printer continues in Self Test, the printer is stuck at this point as it tries to continue to cycle through the power up.
Try to power on the printer without the toner kit and the waste toner box. If the printer stacks again at self test. Next step.... remove one part at time and check if the printer displays any message. First remove the developer unit and power on the machine (normal message "Missing Developer Unit"). Then pull out the fuser unit and power on the machine (normal message "Close Rear Cover"). And finally, remove the Drum Unit and power on the printer (normal message "Call Service 7410").
If the printer still stacks at Self Test, then that is not a good sign. Try to upgrade the printer' s firmware (system + engine). There is a possibility to go further from Self Test.
If it does not, then you have to replace the main pwb.
Oct 28, 2014 | Kyocera Fs-3920dn Laser Printer
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
SCX-4521F All-In-One Laser Printer: toner empty after replacing new toner of samsung s...
Clear/reset the settings on the printer. Press in this order w/o pausing:
menu
193
start
If you do it correctly, the LED will say "Select Country, US", then you press "OK", then it will clear the settings and the error message should go away unless you have a dirty sensor or your toner is installed incorrectly.
Good luck-
May 18, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Bought a new Lexmark cartridge for my E120n. After about 300 copies it prints with big white streaks on the paper. Have shaken the cartridge several times, but nothing changes. Is it likely to be the...
You may need to replace your photoconductor unit part number 12026XW they only last up to 30,000 copies and it is what gives your the nice clean print. If you are having issue with your print quality this is what I would try replacing first or see if it has a build up to toner on it which you can clean off with a dry soft cloth. The photocondutor unit is in behind your toner and can be pulled out and replaced by you.
Feb 26, 2010 | Lexmark E120n Laser Printer
Code "ap"
means copier is adding toner. you maybe able to install new toner and message will go away. also may be bad developer or sensor. replace the toner firsrt. if it does not fix it call a tech
Dec 30, 2009 | Copystar CS-1530 Copier
Install photoconductor
the photoconductor is commenly refered to as the "drum" .. its the cylindrical part that picks up and transfers the toner to the paper .. the error message might be telling you its time to replace the drum (they do wear out) or perhaps its not detecting the fact that it is in place .. the photo conductor drum is user replacable so it comes out without too much trouble .. sometimes its part of the replacable toner tank .. it would get automatically replaced when you change toner in that case .. be very careful with the photoconductor drum .. any scratches, finger prints or other damage will show up in the printed output .. dont expose it to bright light ...
Oct 01, 2009 | Epson AcuLaser C4100 Printer
Replace waste toner tank message
the sensor for the waste toner cartridge is faulty or the waste toner cartridge is faulty it's self.
Apr 26, 2009 | Samsung CLP-510 Laser Printer
ERROR: INSTALL TONER
Toner Empty Message If a Toner Empty Message is Still Displayed After a New Print Cartridge Has Been Installed, Enter the Tech Mode and Perform a Manual Reset CAUTION: Make sure to follow this solution carefully as incorrect settings made in the Tech mode can cause the machine to become inoperable. The Tech mode is intended to be used by service and support personnel only.
Before performing this solution, make sure a new Xerox PE220 SmartKit Print Cartridge has been installed into the machine. Other print cartridges are not compatible with the machine and a manual reset should not be attempted.
If necessary, see the Related Items below for additional information on ordering supplies, consumables, and parts.
To enter the Tech mode and perform a manual reset:
  1. Enter the Tech mode:
    1. Press the [Menu] button on the Control Panel.
    2. Press [#], [1], [9], [3], [4] using the numeric keypad. 'Tech' will be displayed on the Display Screen.
  2. Press the [Menu] button until 'Data Setup' is displayed.
  3. Press the [Enter] button on the Control Panel.
  4. Press the [Left] or [Right] arrow button on the Control Panel until 'Clear Counts' is displayed.
  5. Press the [Enter] button.
  6. Press [1], [9], [3], [4] using the numeric keypad.
  7. Press the [Enter] button.
  8. Press the [Left] or [Right] arrow button until 'Used Toner Cnt' is displayed.
  9. Press the [Enter] button.
  10. Power OFF the printer using the power switch on the rear, right side of the printer.
  11. Wait 30 seconds and then power ON the printer
Aug 28, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
783 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
